obijon Posted August 7, 2024 Posted August 7, 2024 (edited) Hello everyone! It’s been a while since I posted anything as work and life has been rather busy. I have been building in that time just that not got round to taking photos (bad ones) writing this essay etc. I return with an update of 6 models from Seasons 2 &3 of The Bad Batch. Let’s start with season 2. AT-AC The All Terrain Armored Cannon (AT-AC), was a bipedal walker used by the ground forces of the Galactic Empire during the early Imperial Era. The walker was an early model in the production line that would eventually produce the AT-ST (RoTJ) and AT-DP (Rebels). The front of the head of this walker reminds me of the Imperial Troop Transport. There are no real tricks for this one although I have used the ball joints for the top joint of the legs. I don’t know why I have not used these before on walkers…… Displayed with an Echo minifigure. REMORA The Remora was a transport utilized by Echo during his time with the Clone Underground. The ship was once a mining vessel that had been retrofitted for stealth infiltration, making it ideal for insertion and extraction missions. The high-speed ship was also equipped with a detachable leech vessel (which I have also included). The design of this is based on the Meson Martinet captained by Sidon Ithano and briefly seen in Force Awakens and later in Resistance (I have built that too but that’s for another day). Again, no real tricks for this one, although I like the use of those technic pieces for the engines. A custom Fireball clone figure is used for the display. Now on to Season 3. CX DAGGER VESSEL The CX Dagger vessel was used by the Clone X trooper division of the Galactic Empire in around 18 BBY. It was dagger-shaped and featured twin red-colored engines in the back. A really simple little build. Only little trick is that the dark grey engine section is attached to the rest of the body by the two prongs at the back and is not connected to the large wedges at the front. This was to keep the thickness to a minimum. I am not overly happy with this one but not sure how else to build it in this scale. Displayed with a custom CX Trooper. The helmet is from the General Zod minifigure with the chrome removed using peroxide and then scraped gently with a craft knife. I would rather use official pieces but there was nothing close. IMPERIAL RESEARCH VESSEL This was a type of Imperial transport utilized for the capture, containment and transport of various cloning experiments conducted by the Advanced Science Division. It was manned by Imperial commandos led by Imperial royal guards. One such transport, transport 904, saw its Zillo Beast "Specimen A" escape while traveling in hyperspace forcing it to crash. Another fairly simple build and probably my favourite build of this batch (pun intended). There are a couple of little tricks, like using the door rail plates to fill in gaps when the model goes to 3 studs wide at the front. I also like the use of the horizontal hinge for the bridge at the front. The front prongs are attached using bars and bricks with one stud. Displayed with a custom Dr Hemlock minifigure. No mutilations this time, just labels. ASAJJ VENTRESS’ SHIP The ship had a unique silhouette due to the uneven wings of its fuselage. Outfitted with proton torpedo launchers for escaping dangerous entanglements, the uneven wings on either side of the fuselage cut a silhouette as unique as the ship’s captain. This was a fun build. It was a challenge to keep the wings only two studs high but managed with interlocking parts. The brackets for the engines also helped with the stability. The main trick was for the tie fighter like panels and how to attach them. Took a bit of tinkering but using brackets, clip tiles and plates with handles I finally found something that worked. I also like the use of those tooth pieces for the part of the engines on the wings. Due to the wingspan this model could have seriously got out of hand size wise. Displayed with a custom Ventress figure (all official parts!). PROVIDENCE The Providence was a starship owned by the pirate and treasure hunter Phee Genoa. It has that Star Wars Ugly feel with what is obviously the engine section from an Imperial Shuttle of some sort. Quite a simple build with the tail held together along an umbrella stand bar. The front section is built around brackets. The Phee minifigure for the display is built with all official parts. The hair is from a mini doll. Let me know what you think Cheers, Jon Link to the full Bad Batch Gallery below: https://bricksafe.com/pages/obijon/bad-batch Edited August 7, 2024 by obijon Quote
Sentinel_Brix Posted August 7, 2024 Posted August 7, 2024 Cool micro-ships (and walker). I like the larger ones - that would be the science vessel and phees transport - the most. The middle sections of the latter are looking very convincing. Ventress and Phee are greatly mixed together minifigs! Quote
