Posted October 4, 2024Oct 4 Hello everyone, I recently completed the Yellow Hot Rod, a car roughly in a 1:10 scale, not based on any specific design. The build centers around an adjustable front suspension that I developed some time ago, adding a unique functionality to the hot rod. Given the model’s size, I was able to incorporate additional features that I hope you’ll find interesting for this type of car. The biggest flaw is that the car only runs on a single power function M motor, but it is safe due to its low mass and high gear ratio. An L motor (or two) would be much better, which I believe would be doable with a bit more time. Check out the specs below: Size: Length: 37cm / 14.6inch Width: 20cm / 7.9inch Height: 13cm / 5.1inch Weight: 1kg / 2.2lbs Features: Openable doors & trunk Easily removable bodywork Front adjustable suspension & rear live suspension Motorized with a fake V8 engine 2x M Motor 1x BuWizz 2.0 I encourage you to check out the video to see the suspension in detail and watch the car in action! Edited October 4, 2024Oct 4 by Corrado
October 4, 2024Oct 4 That low profile adjustable front suspension is interesting, and looks cool, nice work!
