Sithinious Posted December 11, 2024 Posted December 11, 2024 I seem to remember a lego piece that no one else does. I’m starting to wonder if I made it up in my head. It was a minifigure hand, only it wasn’t as mini as a normal minifig. The hand had a hole in the middle, standard size hole for Lego. The top of the hand was one stud in size, the bottom was able to attach to one stud. The whole was attached to a ball. The ball snapped into the end of an arm that was sort of split down the middle… it flexed enough for the ball to pop in and be held securely. I’ve attached a crude drawing of what I’m talking about. Anybody remember this? If I made this up in my head, it certainly is a detailed delusion. 😜 Quote
CastleRail Posted December 11, 2024 Posted December 11, 2024 It's not made up, rest assured. There's even two variants of it 3614a and 3614b and the wrist/arm it inserts into is 3613 Quote
Sithinious Posted December 12, 2024 Author Posted December 12, 2024 THANK YOU. I knew I couldn’t have made that up in my head. Not only could I distinctly recall what it looked like, I had a tactile memory as well. I remember having to use a bit of force to get the ball to pop into the socket with a satisfying click. Quote
ILoveSeatron Posted December 12, 2024 Posted December 12, 2024 Those hands where used in the Lego homemaker sets. They were brick built minifigs with special heads. Just look up "Lego homemaker" on the internate and they should come up. Quote
