Chilly Posted January 13 Posted January 13 (edited) For Xmas I bought myself the instructions and the extra parts that I didn't already own, to build Nico's Manual Braiding Machine. It's great, works just as it should. Except. I got bored hand-winding the thread onto the bobbins, if it was too loose or too tight or wriggly, the machine couldn't make good braids. I needed to make a winder. First attempt was with bricks and plates, I didn't even think I needed gears. Then realised that gears meant more wound yarn for less winding time. The bobbin itself was being pushed away from the gears, so a little wall stopped that. I then realised it took up far more space than necessary, so swapped out some bigger bricks for smaller, and a smaller baseplate. Great, it worked, but I was winding in one direction and the bobbin wasn't winding the direction I expected it to. Added another gear and that problem was sorted. I was happy, my first bit of free-style LEGO since I was a child. Nico’s Manual Braiding Machine Nico’s original bobbin My alternative, side by side with Nico’s. Hoping to use the extra beam to create tension on the thread. And a longer axle, so could add a gear for winding Can’t attach the bobbin to bricks as connectors prevent contact. Need to add a 1 x 3 plate. One gear, but gears not meshing as bobbin pushed away. One gear, with wall to resist bobbin. And smaller bricks Second gear added, so handle winds in more intuitive direction. This works perfectly. Then I saw this contest. And read the rules, which seemed to imply I needed to remake my winder without using old-style bricks and plates. This proved to be a much harder task. How can something so small need so many parts. Edited January 17 by Chilly Fixed photos Quote
Chilly Posted January 15 Author Posted January 15 (edited) I've had two attempts at building the same winder, but only using new Technic, so no studs at all. First attempt was not rigid enough, I think the green baseplate is just too flexible. Tried putting the long beams around it to stop if flexing, but it wasn’t enough. The gears chattered more than often than they worked. Partially dismantled, showing base layer parts Technic Pin Connector Plate used as feet 3/4 pin used so can place on baseboard L beams used to try to stop bobbin being pushed away from gears Gears still not meshing nicely Abandonded Edited January 17 by Chilly Quote
Aurorasaurus Posted January 15 Posted January 15 Meshing gears along a half stud offset is quite tricky. Maybe you could use 32291, 69819, 63869, or 6536 with half bushes to get the offset to make some reinforced enough structure. Good luck with this project! Quote
Chilly Posted January 17 Author Posted January 17 Version 2 using new style Technic using more L beams and no baseplate. This one does work, no different to the original old-style Technic. Two and a half times as many parts as the old technic model Technic Pin Connector Hub Perpendicular 3L with 4 Pins to create holes for axles As an exercise I was quite surprised how many more parts were required to make this tiny model using new-style Technic compared with old-style. The old-style build was much more intuitive. Placing connector pins so each layer didn't interfere with the one above or below needed careful thought. I take my hat off to all those out there who design bigger models. You are amazing. Quote
