CPT. Jr Posted October 21, 2008 Author Posted October 21, 2008 it was why the guy holding the head was smiling, the french liked doing that sort of thing at the time, it was public entertainment. Quote
Erdbeereis Posted October 21, 2008 Posted October 21, 2008 Cpt. Jr, to deeplink your photos, go to the website where the pictures are hosted, click on the image until you can't anymore and copy the web address. Then, in the post window, click on the small image of a sunset above the post window and paste the address in there. Hope this helps! I've never seen a LEGO basket, but that certainly doesn't mean it does not exist. LEGO crates (and buckets for Sinner) I know exist. Quote
Legoking Posted October 21, 2008 Posted October 21, 2008 (edited) Opinion I like the improvements that you have made from last time. The blood pouring out of the head is a really good touch to your MOC and makes it look gorier. But it is mostly the same as the last contest entry. Possible Improvements they are mostly the same as what I said before. 1) You could change the head with pouring blood out of it to a screaming head. I think you still need to do some improvements on your MOC. LegoKing My PTV Entry- Medium Edited October 21, 2008 by LegoKing Quote
Lt. de Martinet Posted October 23, 2008 Posted October 23, 2008 I have but two criticisms! 1. Only official LEGO elements are allowed, and I'm almost positive that the blood and string aren't. 2. For the dead head, I suggest that you either use a blank head (or the back of a head) or one of the asleep heads. Quote
Captain Zuloo Posted October 23, 2008 Posted October 23, 2008 I have but two criticisms!1. Only official LEGO elements are allowed, and I'm almost positive that the blood and string aren't. 2. For the dead head, I suggest that you either use a blank head (or the back of a head) or one of the asleep heads. True - I don't think the blood is valid, but string is one of the only non-lego exeptions. So he's fine with that. Quote
CPT. Jr Posted October 24, 2008 Author Posted October 24, 2008 (edited) True - I don't think the blood is valid, but string is one of the only non-lego exeptions. So he's fine with that. ?????????? what blood, the only non lego elements were some tan string and a bunch of very fine red string, is there a problem with that??? Also I did not change my entery, I just posted my own pictures, one of the mods, must have posted the other one before. :pir_laugh2: Edited October 24, 2008 by CPT. Jr Quote
Erdbeereis Posted October 24, 2008 Posted October 24, 2008 You need to resize your pictures so you don't get disqualified. Here's a tutorial on this. Resizing tutorial I suppose since the blood is string it's allowed, but you might want to ask a moderator just in case. Quote
Zorro Posted October 27, 2008 Posted October 27, 2008 You still need to resize your pictures: it even loads slow on my broadband connection. If you don't, your entry will probably be disqualified... I like the improvements you made BTW. Quote
CPT. Jr Posted November 1, 2008 Author Posted November 1, 2008 You still need to resize your pictures: it even loads slow on my broadband connection.If you don't, your entry will probably be disqualified... I like the improvements you made BTW. Ok will do tomorrow Quote
