Well I was building the Mobile Command Center, hooray for Christmas, but anyhow, I seem to have put the door to open the cabinet backwards. I don't know why I did something like that, I guess I'm just tired. I got a scuba thing inside so I can't really push in to make the piece come out. So what should I do? Any help would be much appreciated.
Mhm, I see. Well I don't have a camera at hand, maybe some time later. I can find pictures of the pieces, though.
http://www.bricklink.com/catalogItemPic.asp?P=4532a
http://www.bricklink.com/catalogItemPic.asp?P=4533
The colors aren't the same, but that isn't the point.
Anyways, I put on the door on backwards, where I can't use the handle to open it. There is something in it, scuba gear (I could show a picture), so I can't merely push it in. So far a skinny, long object isn't able to pry it open, so I could use some help. In general, I cannot open the door because the handle is on the wrong side... sorry for being unclear.
Hah a suction cup gun! No, I don't have one of those unfortunately. I'll see to it sometime when I'm not so lazy to look for something. Anyways, thank you for your help. Other ideas would be appreciated as well!
Another idea-- If I remember right, there should be some kind of little hole behind the handle. You could try sticking a toothpick back inside there, or something... :look:
OR
Chuck Norris :tongue:
Edited by Faramir
Hah Faramir, Faramir, I already tried that! It didn't really turn out that well, but I might try finding something skinnier. I have tried shaking it as well, and I'm not sure if I want to gum up my Lego. No, a suction cup is good enough, which I suppose I should try.
EDIT: Woah, tried the Faramir Idea again and it worked. Yay!
Edited by ptdapen
Hahaha that happens to me ALL the time. You just gotta stick a pin in the little hole and open it. Be very carefull or you'll scratch it.
Edit: Oh, I didn't relize that you got it open. :blush:
Edited by Mocha
Great, glad I could help!
