Sam Vimes Posted November 18, 2010 Posted November 18, 2010 Have you guys thought of any other contests recently. Quote
LuxorV Posted November 18, 2010 Author Posted November 18, 2010 If you mean customisation contests, we just have one per year for now, but if it gets popular (as it seems), we may plan more than one Quote
Darth Jar Jar Posted November 18, 2010 Posted November 18, 2010 If you mean customisation contests, we just have one per year for now, but if it gets popular (as it seems), we may plan more than one Ooo more than one per year would be great the last one was great brought so many great customs Quote
piemaster1446 Posted August 2, 2011 Posted August 2, 2011 Should we make a Discussion Thread for Greek Mythology decals y'know like we could have the classic stuff and then some percy jackson? Quote
LuxorV Posted August 2, 2011 Author Posted August 2, 2011 Do you mean you have Greek Mythology decals to post or you'd like to see/request some? In the first case, open a new thread and post them there. In the second case, use the Decal Wish List topic. Quote
LuxorV Posted August 17, 2011 Author Posted August 17, 2011 After way too long, I finally up-dated the Indexes, adding a new ATLANTIS Decals Index in the process. Please, always refer to the Indexes before posting requests for new decals. Thank you. Quote
Scorpiox Posted August 21, 2011 Posted August 21, 2011 There seems to be a problem with the castle decal index. Whenever I view it I can only see the first post, the other post with more decals (e.g. faces and shields) is not there. Is this a problem with the index or my connection? Thanks for any help! Quote
LuxorV Posted August 22, 2011 Author Posted August 22, 2011 Must have been a mistake with the copy&paste for the up-date It's good as new now! Thanks for the report Quote
NickAb Posted August 28, 2011 Posted August 28, 2011 Hello. It seems that links to "Minifig siluette in Illustrator - by def" and "LEGO colours' plaette for Illustrator - by def" are broken. Quote
LuxorV Posted August 29, 2011 Author Posted August 29, 2011 Thanks for the report. It seems the site was removed or relocated. I'll have to contact def on these. Quote
purpleparadox Posted March 9, 2012 Posted March 9, 2012 I was thinking about using some of the decals in the index so I read the tutorial on printing decals. I had no trouble using Word to get Luxorv's decals to print in the right size. However, I could NOT make any of Severus's decals print at the right size. Has anyone else had this problem? Can anyone help me? Quote
LuxorV Posted March 10, 2012 Author Posted March 10, 2012 I just tried some of Severus's decals, and apart needing a bit of re-sizing (as described in the tutorial) at times, they work just fine for me. Please keep in mind that when you have to set the length, it refers to the torso; if there is a head/face design in the same image (quite common with Severus's decals), it may need to be printed somewhat larger. In general, make sure the torso length is right at 1.5 centimeters and all should be fine. If this does not help you, could you please be more specific as to which do not work for you? All? Theme specific ones? Thanks. Quote
LuxorV Posted July 27, 2012 Author Posted July 27, 2012 All the Indexes have been up-dated. We now have a new Ninjago Index, as well as new sections for Lord of the Rings and Power Miners decals. I also added the Depository of svg decals to the main MCW Index. A big thank you to all the dedicated decal designers who contribute to EB daily. Quote
AmperZand Posted September 11, 2012 Posted September 11, 2012 (edited) Is the Customisation forum the right place to post pictures of minifig MOCs that use unmodded LEGO parts? For example, if I combine minifig parts from different themes, where can I post pictures of those minifigs? Edited September 11, 2012 by AmperZand Quote
LuxorV Posted September 12, 2012 Author Posted September 12, 2012 Hi AmperZand, I moved your post to this discussion topic, where it fits better. On to your question, as long as you post figs only and not vignettes or larger MOCs, it is good to post the in the Minifig Customisation Workshop. As a further note, whet you describe as 'minifig MOCs that use unmodded LEGO parts' are commonly called 'purist' custom figures, whereas 'non-purist' ones are those which include modified parts or third party (BrickArms, BrickForge, BrickWarrior and the like; or simply home made) elements. Hope this helps you. Quote
AmperZand Posted September 12, 2012 Posted September 12, 2012 (edited) Hello, LuxorV, Thanks for your reply. That does answer my question. I suspected as much but wanted to be sure. I was told by another member (not a mod) that purist minifig-only MOCs can be posted in the forum of the theme to which they relate. But as I was once corrected by a mod for doing exactly that, I had a feeling the poster was mistaken. Incidentally, I'm very familiar with the term "purist". I just didn't want to get sucked into a discussion on what is/isn't purism. Thanks again, Amps Edited November 22, 2012 by AmperZand Quote
AmperZand Posted April 4, 2013 Posted April 4, 2013 Hello, LuxorV, Hope you're well. Can you please index the thread below in the Tutorials section of the Minifig Customisation Index and Guidelines thread? http://www.eurobricks.com/forum/index.php?showtopic=42306&st=0 A guide to turning fleshies yellow merits indexing. It's extremely useful to those of us who can't stand fleshies, includes know-how that isn't obvious and describes techniques that really work. Thanks for your consideration, Amps Quote
NickAb Posted May 11, 2014 Posted May 11, 2014 (edited) Hello. I've wrote a python script for conversion of Materials.xml (from LDD db.lif) into Adobe Illustrator swatches file (.ase). The most interesting part for the Index is resulting swatches file. Here is a download link for swatches file for Adobe Illustrator https://github.com/NickAb/ldd-to-ai-swatches/raw/master/LDDColors.ase All colors have RGB values directly form Lego Digital Designer files. I also add the swatches file to SVG Minifig Decal Repository. Edited May 11, 2014 by NickAb Quote
pittpenguin123 Posted November 11, 2015 Posted November 11, 2015 mandalorian decals (not the ones by mr mandalorian) are broken Quote
LuxorV Posted November 11, 2015 Author Posted November 11, 2015 Thanks for pointing this out. It would seem quite a few decals by clone killer are missing. I'll fix them asap. EDIT - Fixed. Quote
meepinater Posted June 25, 2018 Posted June 25, 2018 Hey luxor, is there any chance that you are able to add new decals to the index? I saw that a lot of the WWI and WWII decals were for yellow minifigures, and i was wondering if i could add some of my own, that are either fleshy or can be both. Thanks! Quote
LuxorV Posted June 26, 2018 Author Posted June 26, 2018 You'll have to post your decals in a dedicated topic, and I'll later add them to the Indexes. Only Admins, Mods and Regs can edit others' topics/posts, so you wouldn't be able to modify the Indexes directly.. Quote
meepinater Posted June 27, 2018 Posted June 27, 2018 19 hours ago, LuxorV said: You'll have to post your decals in a dedicated topic, and I'll later add them to the Indexes. Only Admins, Mods and Regs can edit others' topics/posts, so you wouldn't be able to modify the Indexes directly.. ok, thanks! Quote
BrobaFett Posted April 30, 2021 Posted April 30, 2021 Hi, I'm wondering if you have a blank minifigure template that includes the side of arms and legs? Thanks. Quote
