name: wookie catch walker (wcw)
nike name: chicken walker
Pieces: 116
minifigures: twoo troopers
back ground story
When the Republic became the First Galactic Empire, the Empire was in need of slaves.
The Wookies were an obvious target, so the Empire invaded Kashyyyk.
The Empire was in need of a vehicle that could capture Wookies alive.
So they designed the Wookie catch walker.
This vehicle can paralize a Wookie with it's gun and than capture and keep it in the back.
new pic`s
I have made also 360 degrees
and you can find it here http://www.youtube.com/watch?v=mRLkWLy7ypg
i hope you will like it
This will get you disqualified if you don't resize the images. The images are way too large and Lord of Pies made a great tutorial on how to resize images using MS paint, here. :classic: Other than that I like your entry, but as CC77 said, the background story is a bit weak. You could try improving it and improving your entry as well, because I can see that it can be improved. :wink:
I've removed the pics.
The studio setup was okay, but the size and lack of focus has forced me to remove them.
Redo the pics and make sure they're sharp and within the size limit.
Well good idea! But there is still time so I suggest you work on your background story and your design. A good starter is the color, there are some bits of green and red and white. Can you make the color standard? That way it will look more professional. :classic:
You've "eaten" some of the MOC in the pictures and you need to ensure that they're:
Front - Rear - Right Side - Left Side - Top View
i think thats a problem i have break the wcw down for a moc ,so i can`t make new pic`s ,i am sorry but the i think you can see one of the pic`s as top-view
:cry_sad:
:cry_sad:
Mkay.
I'll let this one slip through then :classic:
