jimmyhoppityhop Posted May 9, 2009 Posted May 9, 2009 well what i want to do is edit the clone commander of the battle pack to either look like commander bly or a red corasant guard, i have paint but are decals better?? tell me what you think Quote
Ras 74 Posted May 9, 2009 Posted May 9, 2009 (Somebody obviously beat me to move this as well) I really don´t like the painting idea at all. If you are not super talented at this. I would prefer decals all the way. This question belongs here. There isa alot of exelent guys there that can help you out there. Have a look around, and you will get the feeling for it. -Ras- Quote
CommanderFox Posted May 9, 2009 Posted May 9, 2009 Hi jimmyhoppityhop Welcome to EB you can always try "Sharpie" Permenent Markers they are good but some times tend to rub off alittle with damp-wet hands Decals are good from what ive heard but ive never tried them it depends what kind of paint you have, is it specifically for plastic material? because if it is then maybe give it ago but if you stuff up with paint then try "Sharpies" because If you use them and stuff up bad, then you just use alittle Methilated Spirits and it comes off just like that but be careful how much meth you use because it tends to spread RAPIDLY on the "Sharpied part of the clone" and is annoying if you just wont to apply it to a small area, also another good thing about using Meth on the sharpied clone is the meth doesn't even hurt the clone or the printed pieces so its great Hope this helps. CommanderFox Quote
jimmyhoppityhop Posted May 9, 2009 Author Posted May 9, 2009 well my paint is gameworkshop, you know warhammer paint, i might go with that sharpie tip. ill see what happens but when come to the special armour like the vicor, can i use the sharpie for that or would i have use the paint??? Quote
Shadows Posted May 9, 2009 Posted May 9, 2009 If you're trying to do something that involves changing the helmet, you're going to be stuck with the paint method, just don't expect great results. If you're changing torso patterns or want to put a pattern on a new colour, that's definitely a decal job. There are a number of useful tutorials and plenty of great customizers around who can probably lead you in the right direction. (Somebody obviously beat me to move this as well) No busted flipper, here Quote
Darth Legolas Posted May 9, 2009 Posted May 9, 2009 I suggest you use Sharpie. It's the easiest, and it's removable. They even have White Sharpie Paint markers so you can really change the color of anything. Thee only problem is that blue and black come out purple. Quote
jimmyhoppityhop Posted May 9, 2009 Author Posted May 9, 2009 ok, im got my sharpies, i got my clones, now im gonna start with a commander bly and il post him up in here when hes done. Quote
KimT Posted May 9, 2009 Posted May 9, 2009 well my paint is gameworkshop, you know warhammer paint, i might go with that sharpie tip. ill see what happens but when come to the special armour like the vicor, can i use the sharpie for that or would i have use the paint??? Are you talking Citadel paint? If so, then I hope you're skilled.. That's one super cool, but extremely difficult and thick paint to use on minifigs. There's plenty of good tutorials around on making regular or water-slide decals and I suggest you read a few of those before molesting your figs with permanent markers. As a general rule, I suggest you skip paint and markers. Try making and printing some decals and add them to old torsos before handling expensive Star Wars torsos. Skill comes from trying and failing several times... Quote
jimmyhoppityhop Posted May 9, 2009 Author Posted May 9, 2009 http://i387.photobucket.com/albums/oo315/J...pg?t=1241895671 im posting the link cus its bigger and its a bad pic well i went for bomb squad cus i didnt have a yellow the thing is, for decals, to print them yourself you have to have that see through paper, at it has to be sticky on the back and i dont even know the ink would be like in my printer ahhhhh Quote
Mraz Skintas Posted May 9, 2009 Posted May 9, 2009 (edited) You don't have to have see through paper. Since Clones are primarily white, you just need white paper. What I do is use a program called Photostudio 2000. I can edit colors, making this look like this . I print them out on standard white printer paper, and run them through one of these. It works quite nicely and is relatively cost efficient. Edited May 10, 2009 by Mraz 'Skintas Quote
Darth Legolas Posted May 9, 2009 Posted May 9, 2009 Looks like someone hasn't read my tutorial on cheap customizing. All you need is white paper and glue! Get them out of the decal index LuxorV provided for us. Elmer's glue works like a charm, just cut and paste! Also, I suggest you do not paint the legs, it's usually past to go over only in places that aren't touched a lot. If you want to unpaint it, use Rubbing Alcohol. Okay? Quote
jimmyhoppityhop Posted May 10, 2009 Author Posted May 10, 2009 does rubbing oil take away some of the affect on the clone??? cus i use surgical spirit which takes away a tiny bit which is bad but its better than having it look like rubbish lol, but ill try that stuff but its still gonna be hard to start of Quote
jimmyhoppityhop Posted May 10, 2009 Author Posted May 10, 2009 ok, i took of the sharpie with surgical spririt, i now need a decal for him as the torso doesnt look to good, i like the bomb squad that you have done but cann you make a helmet for him or should i post this in the deacal wish list thread??? Quote
Mraz Skintas Posted May 10, 2009 Posted May 10, 2009 (edited) Decal wish list thread, and thats 212th Attack Battalion. Cody's boys. Thats the bomb squad. Edited May 10, 2009 by Mraz 'Skintas Quote
jimmyhoppityhop Posted May 17, 2009 Author Posted May 17, 2009 hey guys, can someone tell me what size you print out decals in cm's????? Quote
jimmyhoppityhop Posted May 18, 2009 Author Posted May 18, 2009 (edited) this is my new bomb squad clone, thanks mraz for the decal. here he is from the front: and here is him from the side: and the thumbs up pose : Edited May 18, 2009 by jimmyhoppityhop Quote
Dutch Posted May 18, 2009 Posted May 18, 2009 (edited) Hi, jimmyhoppityhop here is how I use to do decals Step 1: print decal Step 2: Take some packing tape and apply it on to the decal Step 3: cut decal out Step 4: apply glue to the back of decal and place it on the minifig hope this helps you oh I just forgot to say here is a commander bly decal for you. Edited May 19, 2009 by clone killer Quote
Mraz Skintas Posted May 18, 2009 Posted May 18, 2009 The fig looks good. But I think you should do paint/ colour the helmet with orange sharpie to finish it off. Quote
jimmyhoppityhop Posted May 19, 2009 Author Posted May 19, 2009 The fig looks good. But I think you should do paint/ colour the helmet with orange sharpie to finish it off. actuly, i used orange sharpie to finnish of on the helmet!!! the color dont match but it doesnt matter the look pretty much the same Quote
