HumanPackMule Posted June 4, 2009 Posted June 4, 2009 Is there anyway to add a countdown to our signature for this site? I've Googled it countless times with no success. I wonder if anyone here knows a code that works for countdowns. Any help would be appreciated. Quote
VBBN Posted June 4, 2009 Posted June 4, 2009 There is n real code you can enter, really. Most countdown sigs are embedded into the sig itself. You could always ask anyone who has experience in countdown banners to help you with that sort of thing. I will see if I can find any sites to make countdowns on, but no guarantees. Also, some countdowns are made using HTML, which, can't be used on the site, or at least not that I have tried. Hope that helps. -VBBN Quote
Captain Zuloo Posted June 4, 2009 Posted June 4, 2009 Actually, I think you'd be looking at a piece of JavaScript. Your best bet is probably to ask someone to write it for you, then request an admin to add it to your sig. Quote
Quarryman Posted June 5, 2009 Posted June 5, 2009 The easiest way would be to link to an offsite dynamic picture in your signature that shows the countdown, which is a pretty simple thing to hack together. Something like this (that should count down to Christmas): import Image import ImageDraw import ImageFont from datetime import datetime from django.http import HttpResponse def countdown(request): delta = datetime(2009,12,24,17) - datetime.now() img = Image.open('background.png') draw = ImageDraw.Draw(img) font = ImageFont.truetype('arial.ttf', 12) draw.text((30,30), u'%d days till Christmas' % delta.days, 'red', font) response = HttpResponse(mimetype='image/png') img.save(response, 'PNG') return response The above of course hides away a lot of gritty details, but it should be valid Python code that works with Django. And since I had already written all the code I of course had to put it to use: Actually, I think you'd be looking at a piece of JavaScript. Your best bet is probably to ask someone to write it for you, then request an admin to add it to your sig. Pretty sure the board software will strip away any javascript from signatures, since allowing it would be a nasty security hole. Quote
