der seb Posted August 6, 2009 Posted August 6, 2009 Hi there finally I got time to take photos from a few MOCs, which are standing around here for monts... Number one, a garbage Truck: More on Flickr Hope you like it. kind regards Sebastian Quote
prateek Posted August 6, 2009 Posted August 6, 2009 That looks amazing, just like a real one with the riged bucket Quote
BlueBard Posted August 6, 2009 Posted August 6, 2009 Really great! If I could make one criticism I would say it's a bit mono-coloured..., but as prateek says it's wonderfully close to the real ones Quote
Ralph_S Posted August 6, 2009 Posted August 6, 2009 Very nice truck. I like the SNOT work on the rear. I have one minor point of criticism: there's very little room between the wheels and the mudguards. I think that mounting the wheels one plate lower would probably make it look better. Cheers, Ralph Quote
prateek Posted August 6, 2009 Posted August 6, 2009 Very nice truck. I like the SNOT work on the rear. I have one minor point of criticism: there's very little room between the wheels and the mudguards. I think that mounting the wheels one plate lower would probably make it look better. Cheers, Ralph If you look at any official lego truck with these fenders, you would always see that the wheels are flush with the fenders. Quote
aawsum Posted August 7, 2009 Posted August 7, 2009 Great MOC, very recognising. I really like how you added the steps at the back (the one where the garbagecollectors are standing on) And I do agree with ralph, one plate higher would give it a bit more robust look, now it has a lowrider style :) Just give it a try, if you don't like it, don't do it Quote
Fumoffu Posted August 7, 2009 Posted August 7, 2009 This is a great MOC. Much better Lego's garbage truck. Maybe you can break the monotone up with some decals? But its no biggie. The monotone doesn't really take much away from a great MOC. Quote
Ralph_S Posted August 7, 2009 Posted August 7, 2009 (edited) If you look at any official lego truck with these fenders, you would always see that the wheels are flush with the fenders. They are flush with the mudguards, but that's not what I meant, as should be clear by the solution that I suggested. I was talking about the vertical space between the top of the tyre and the mudguard. If you want to refer to LEGO sets anyway, check this out: On the set the wheels are mounted one plate lower / the mudguards are mounted one plate higher such that there is a bigger gap between the top of the tyre and the mudguard, and in my opinion that is look that fits a truck better. Cheers, Ralph Edited August 7, 2009 by Ralph_S Quote
Milan Posted August 7, 2009 Posted August 7, 2009 Beautifully designed truck, great color. For the fenders, it may look better when vertical space is increased, but it may look somehow more off-roadish. with this original setup it looks more like city vehicle, which is good. Quote
der seb Posted August 7, 2009 Author Posted August 7, 2009 That looks amazing, just like a real one with the riged bucket thanks Really great! If I could make one criticism I would say it's a bit mono-coloured..., but as prateek says it's wonderfully close to the real ones I know, it's only orange and grey, but unfortunately it's like on the real truck. thanks for your comment Very nice truck. I like the SNOT work on the rear. I have one minor point of criticism: there's very little room between the wheels and the mudguards. I think that mounting the wheels one plate lower would probably make it look better.thanks for your comment To the point of mudguards. I tried it with 1 plate more space between fenders and wheels, but it didn't look right. I also tried 1/2 plate offset. Maybe I just set the driver's cab one plate higher. I think this lowrider style (as aawsum says) comes from the very low bumper on the front. @aawsum, Fumoffu, Milan: thanks for your comments Quote
Ralph_S Posted August 7, 2009 Posted August 7, 2009 You might indeed give raising the cab a try. That front bumper is very low. Anyway, it was just a minor comment and would have stayed minor if it hadn't been misunderstood. Cheers, Ralph Quote
Rick Posted August 7, 2009 Posted August 7, 2009 Very nice work! I agree with comments made here about the color and raising the cabin and fenders. Quote
Big Cam Posted September 3, 2009 Posted September 3, 2009 They are flush with the mudguards, but that's not what I meant, as should be clear by the solution that I suggested. I was talking about the vertical space between the top of the tyre and the mudguard. If you want to refer to LEGO sets anyway, check this out: On the set the wheels are mounted one plate lower / the mudguards are mounted one plate higher such that there is a bigger gap between the top of the tyre and the mudguard, and in my opinion that is look that fits a truck better. Cheers, Ralph I think for a cement truck that looks good, but for a garbage truck, it looks better with the lower fenders. Quote
rriggs Posted September 3, 2009 Posted September 3, 2009 You might indeed give raising the cab a try. That front bumper is very low. Anyway, it was just a minor comment and would have stayed minor if it hadn't been misunderstood. Cheers, Ralph I'm afraid that I have to agree that it sits too low. Looks like the suspension has collapsed and it's not going to get over any speed humps which would limit it's use somewhat! In fact, the dustcarts (garbage trucks) in the Uk tend to sit higher on their suspension than regular trucks as they need to be able to access and manouever in landfill sites and the like. The cabs tend to be low like service trucks at airports but the ground clearance is relatively high. I think that the one-colour scheme works well - again, the dustcarts in the Uk are predominantly plain yellow or plain white. That said, they have just started painting trees and hills on the side of my local ones... Nice MOC. Cheers Rog Quote
Still Raindrop Posted September 4, 2009 Posted September 4, 2009 Very nice, indeed! The realism is wonderful, and it doesn't look like it's too much bigger than the City scale. Quote
Legoliner Pilot Posted September 5, 2009 Posted September 5, 2009 Love it. I agree with the others, the wheels could be a bit higher. But other then that, it's great! Quote
BillytheKid Posted September 5, 2009 Posted September 5, 2009 Wow, this look realistic. Great job . Quote
Captain Stoneface Posted September 5, 2009 Posted September 5, 2009 Wow! Nice truck! It looks very relistic and it contains much play futures. You need to think about an sticker on the side of the truck, a logo or something. Quote
MetroiD Posted September 18, 2009 Posted September 18, 2009 Regardless of its height, this one is a great MOC and looks extremely realistic. The work you've done on the back is amazing... Quote
