  • Replies 62
  • 4 years later...
The "prong" on the lid fits into a 1x1 cone (does need a bit of rotating to get the max friction point), and these are just built onto some tilted plates.
Underneath each vertical row of flippers, there is a 1x10 plate. The flippers fit into the underside of the plate, alternating between on the "pin" (between the studs on the other side) and the "hole" (directly beneath the studs on the other side). And this is repeated, but with a different offset for each vertical row.
For the curved roof, I used horizontal flex tubing with 1x1 clips.
And some more...
By Marian19, using popsicles -
I'm pretty sure I've seen someone using bars, flex tubing and string to make a roof, but that may have been a table scrap of mine :blush:
Please can you give me the bricklink number of your bricks from the roof.
Jonas
here are some of my most recent roofs.
and a small guide I made some time ago and never posted
OOF:
first up make a (preferably brown) "base" for your roof.
I have put together a small one. please note this will only be half a roof
at the back I have these parts that will clip onto the interior when the roof is done and hold it in place
the first I will show you how to do is using CMF plates for your roof
you could cover the entire thing with plates if you wish. I like to add some "damaged" plates for texture.
next I will add gables. these can be as complicated or simple as you want. my ones pretty basic.
this can be done not only with CMF plates but regular tiles in any colour
next up a wooden roof
more plates applied
then tiled. note how some tiles are a little misplaced, it gives a nicer look. you can get away with no gables for this technique.
last a thatched roof.
start by laying down dk/tan plates (the hole is not necessary)
next we add some plate variation, rising in the corners specifically, this gives the impression of a sagging roof.
lastly add some tiles
using round 1x1s has been shown before here, but this is my technique for attaching them to a house:
@Z: it'd be really cool if you could fix this along with the other tutorials!
Edited by kabel
I like the 2 x 2 round tiles stacked diagonally. I can't say I do a lot of building with actual bricks and I don't actually own any of said pieces, but I could post a picture of an LDraw model.
i'm quite interested in seeing this.. Ldraw would be just fine :)
@ Kabel : thanks for showing.. I can make nice looking roofs..but have a hard time getting them connected to the houses >_<
I seem to remember someone posting an interesting design for terra cotta roof tiles using plates and technic connectors if I remember correctly. I haven't seen it posted here yet, though I believe it should be.
Here's a four sided roof technique:
This is how I built the roof on my latest MOC, Imperial barracks. The 1x2 and 1x4 tiles are held on by 1x1 cones that slide into the gap that the tiles cover.
This is how it looks in action:
This is a great topic! The roof techniques are all interesting, but I'm still wondering how some of those roofs connect to the rest of the build. I'd love to see some "interior" shots or construction shots of some MOCs that clearly show how the roof is attached. Do you use those 1x2 hinge bricks? Or clips? Or does the roof just 'sit' on the structure without any connection at all? Enlighten me, please! :sweet:
It's not a question aimed at one person, but rather a general question fitting with the topic :classic: . I just always struggle when I get to the phase where I have to add the roof to the rest of the MOC. Seems kind of silly, I know, but still.. :tongue:
hinge bricks, cliphinges & actually, roofs that just are "wedged" in position all work pretty well..
Just with the last one..either you "block" it with a brick (internal or external) or make sure that the roof is 1 solid.
