Does anyone have ideas on how to make tle clones look battle damaged?
They look rather plain in the white armor(I know I can put decals).
Edited by Legoroni
If you have mud around your house then take a little bit an really rub it in and it will look good if you do it right. Don't worry water fixes everything.
I found some types of ash work too. Can't remember which though, so you should go with brickme's idea instead. Some ash takes ages to come off. :sceptic:
Led zePPelin, just because you are a hard classic rock fan does not mean you have to answer everything like that. (But in all seriousness Stairway to Heaven is the best song ever made :cry_happy::wub: ).
I like the mud idea, I tried it with limited success, probably because I was doing it wrong. :sceptic:
What's wrong with burning them a little? It was a serious suggestion. They wear plastic armour and have hot blobs of gas fired at them, surely they'll get a little charred...
:laugh: Burning... probably not. Maybe a little singeing.
I do remember that someone on EB made a 'damaged' Rebel pilot helmet a while ago. Maybe try a seach? I remember it was very cool.
Another idea is biting them.
Well, if you have: eg an animal, a puppy would be the best, then let them do the battle damaging. :wink: They tend to bight the hardest! :laugh:
CommanderFox
Edited by CommanderFox
CommanderFox
Heh, no. I'm not letting my LEGO anywhere NEAR my puppies.
Normally to make BD I just get a hammer and a nail and scratch it up a lot then use the nail to make a small hole in the helmet.
A NAIL AND HAMMER? Thats about worse than burning them.
ummm... No I did that when I tried to make a zombie power miner and it worked perfectly! :grin:
Use a heated mini-screwdriver and press on the part of the armour that you want dented.
as for burns, as suggested before, use a pen which has "smudge-able" ink and just put a bit on the minifig and use a wee bit of tissue to smudge it up.
