In that case, I'd like to push it.
I thought there was something special about that brick.
*Donna pushes the center of the desk. It acts like a lever and a mechanism is engaged. The sound of a large concrete block moving can be heard behind the bank of panels that will not open.*
I'll check the tiled pattern to the left of the wolf head, seeing if any pieces can be removed or pressed.
*Diana notices that the tile in the upper left hand corner is actually black and not dark grey like the others. She pushes it a little and it easily falls out and shatters on the floor. It was not the correct tile for the pattern...*
Oh. And... I'd like to slap Sheldon. :tongue:
*Sheldon receives a nice hard slap from Sandy. His face stings for quite some time afterwards.*
  • Replies 381
Do my old eyes deceive me, or are there two other black tiles in the pattern as well? I'd like to try removing the other black tiles, then look at the space left by the piece I already removed. After that I'll search among the rubble on the ground for a piece that fits where the other fell out.
*The other two tiles are correct. The rubble on the ground does not yield a dark grey tile.*
I'd like to try the panels again, now that something happened. :tongue: I'm sure it won't be that simple, but why not, right?
Also, where's Tony Peck? Has anyone seen him around?
Oooh, I haven't seen him since page 6! :wacko::cry_sad: Ooh, now I'm worried. Tony? Where are you dear?
*Waves hello* Here I am dear. No, no philandering for me, I'll always be true. :wub: I've just been mulling things over in the corner over there.
I'd like to try and pull off one of the teeth from the fallen wolf head. If that works, I'll attempt to stick it into the other wolf head that's still on the wall.
I probably deserved that.
Makeup sex? :wink:
*It's not that simple. The panels are still stuck.*
*Tony removes a tooth from the wolf head on the demon bike. He places it in the empty space on the remaining head. It's a bit loose. Nothing happens.*
*I'd like to gently pull out the tooth that was just put in, then feel inside where it was to see if there's anything there*
*There are some small notches carved into the stone. It seems only the correct tooth will lock into place.*
I'll climb through the break in the wall and see if there's anything worth noting behind there.
*Before climbing the wall you take a good look at the terrain.*
The surroundings appear to be quite unstable. How will you like to climb over? I can give you some help.
*William helps Tony up the wall.*
*Tony prods the "tentacle" to find it is only a vine. Searching for the source of the vine provides no clear results. It appears to be growing up out of a large hole in the rock. Tony looks down the hole and cannot see the bottom. A cool blast of air hits him when he looks down the hole and he is chilled to the bone.*
*Tony climbs over the wall and outside of the temple...*
*A few moments pass and Tony re-enters through the break in the wall. He looks slightly shaken. Scaling back down the wall he knocks a brick loose, which falls to the floor...*
I'd like to take the brick that Tony knocked off and examine it.
*It seems to have come out of the wall. It's not as thick as you would've imagined. As a matter of fact, it doesn't seem as thick as the other bricks on the ground.*
Err, this may seem pointless, but... Dianna, do you have a last name? :wacko:
*Diana's hearing aid must be malfunctioning on that side. Perhaps you should ask her again.*
DO I HAVE A MAST CANE? WHAT? SPEAK UP!
Of course I have a last name. Everyone has a surname. I suppose mine just isn't important enough to share. :wacko: I don't know what to tell you.
In that case I would like to examine the area on the wall that the brick fell from.
Maybe its as thin as a tile? i.e. the missing tile from the mosaic?! Wonderous. *rides the demon bicycle around the room to see if that does anything and because it's fun* :laugh:
I want to ride my bicycle, I want to ride my...
*There is an empty compartment on the wall where the brick was removed. There appears to be something inside...*
I would like to take a look in the compartment that is apparently empty but also apparently has something in it. :wacko:
If there is anything inside the (empty :grin:) compartment, I'd like to take it out and inspect it.
