-R8- Posted July 6, 2010 Posted July 6, 2010 This I found to be extremely peculiar: A round 1x1 plate literally inside of a thin 1x4 liftarm. The glitch works with all of the thin liftarms, provided that they have round holes in them. Here's more: The round 1x1 plates can be placed into "thick" connectors and liftarms, but not the round 1x1 brick. The .lxf file if anyone is interested: http://www.brickshelf.com/gallery/rahkshi8000/LDDGlitches/technicroundpieceglitches.lxf
Superkalle Posted July 6, 2010 Posted July 6, 2010 This I found to be extremely peculiar: Wow, that was kind of neat, ha, ha. I have reported it to TLG (and from what I hear they really appreciate all the stuff we find). Oddly, a 1x1 plate will not fit at all. Regarding the full height brick, it might be because it's an illegal connection (i.e. connecting anything but a thin plate). I've reported that too and we'll see what happens. Anyway, this is a good read if you haven't seen it before
prateek Posted July 6, 2010 Posted July 6, 2010 Regarding the full height brick, it might be because it's an illegal connection (i.e. connecting anything but a thin plate). I've reported that too and we'll see what happens. But it works with the 1x2 brick with Technic hole(s)
Brickdoctor Posted July 6, 2010 Posted July 6, 2010 It's because minifig's toes are too long Okay... It's just weird because the 'figs toes aren't too long in real life, and he fits backwards.
Superkalle Posted July 7, 2010 Posted July 7, 2010 Regarding the minifig feet. I played around some and discovered the following: It seems we have two problems here: Firstly, the minifig feet themselves are not too long. Instead it's the combined geometries of the legs and the torso that creates the problem. Even if you first placed only the legs, they would still be off-set forward a slight amount in order to allow the torsos back (when placed) to be flush against the green brick-stack. So the base of the problem is actually the geometry of the minifig itself, combined with the fact that the LDD team have modelled the minifig as a complete unit (legs and torso). Secondly, there is the problem with the horse. This seems to be a boundary problem with the horse itself since, as correctly pointed out, a minifig can be placed backwards but not forward.
Brickdoctor Posted July 7, 2010 Posted July 7, 2010 Regarding the minifig feet. I played around some and discovered the following: [snip] It seems we have two problems here: Firstly, the minifig feet themselves are not too long. Instead it's the combined geometries of the legs and the torso that creates the problem. Even if you first placed only the legs, they would still be off-set forward a slight amount in order to allow the torsos back (when placed) to be flush against the green brick-stack. So the base of the problem is actually the geometry of the minifig itself, combined with the fact that the LDD team have modelled the minifig as a complete unit (legs and torso). Secondly, there is the problem with the horse. This seems to be a boundary problem with the horse itself since, as correctly pointed out, a minifig can be placed backwards but not forward. That's even more weird. I suppose it's because TLG doesn't want the youngins figuring out that they can swap out arms, hands, and legs; since that could lead to potentially dangerous cracks in the torso and wrists.
prateek Posted July 10, 2010 Posted July 10, 2010 Piece #48723 doesn't allow axles to go through it. In other words, you are only able to put this piece at the end of axles.
Zerobricks Posted July 10, 2010 Author Posted July 10, 2010 2 more here: The 4L long axle with stop can go all the way inside the beam, while the 8 stud one cant: Also you cannot smoothly rotate any axle inside this joiner, it skips angles: A close up shows, that the parts are actually in colision:
Aanchir Posted July 11, 2010 Posted July 11, 2010 Another minor render error: on this piece, the side with the two studs is supposed to have a pin/tube on its underside, just like a regular 1x2 plate. It's missing this pin/tube.
prateek Posted July 11, 2010 Posted July 11, 2010 Piece #2958 doesn't fit any parts in the cross hole thingy.
messiah1 Posted July 16, 2010 Posted July 16, 2010 (edited) I need some help figuring out why this piece: (2M FricSnap w Cross Hole) will not seat properly. No matter what I do, it won't go all the way through to the stop. Even if it's just the one brick, it still stops right where it's showing here: Another view: Alignment of the brick doesn't seem to be a problem...it just won't go any further for some reason. Any help would be appreciated. *And it looks like I put this in the wrong section...sorry. Can a mod please move to the LDD section? Edited July 16, 2010 by messiah1
Siegfried Posted July 16, 2010 Posted July 16, 2010 Not sure if this is a concern (I'm no LDD expert ) but isn't that pin more for going though 2 beams, not 1/2 + 1 + 1/2? In any case I'll move this for you.
Rick Posted July 16, 2010 Posted July 16, 2010 (I'm no LDD expert ) Me neither, but you're probably right. Because it won't be 'in click' in the middle, it's an 'illegal' construction that isn't allowed(?) by LDD.
AndyC Posted July 16, 2010 Posted July 16, 2010 Not sure if this is a concern (I'm no LDD expert ) but isn't that pin more for going though 2 beams, not 1/2 + 1 + 1/2? Yep, that's an illegal use of the pin, since the middle will be in permenant compression. You can solve it by replacing the beam with two 1/2 width liftarms, since the pin can then safely 'snap' into place in the middle.
messiah1 Posted July 16, 2010 Posted July 16, 2010 (edited) Figures. The directions call for that piece in connection with those other three. If LDD won't allow an illegal build, why does the official LEGO directions call for it? Seems they ought to be consistent...Oh well, I'll see if I can work around it somehow(I'll look at the above suggestion). Is there a non-compression match piece? btw, even when I pull apart all three pieces, it won't go all the way to the stop on any of them by themselves. Can someone else try the combination, and the single instances and see if they get the same issue? Edited July 16, 2010 by messiah1
Vincent Kessels Posted July 16, 2010 Posted July 16, 2010 I don't have any problem with the single instances, but the the combination does not work.
messiah1 Posted July 16, 2010 Posted July 16, 2010 I don't have any problem with the single instances, but the the combination does not work. I wonder what the heck is wrong then. I'll try a new creation and see if I can get a single instance to work. Frustrated over here.
Zerobricks Posted July 16, 2010 Author Posted July 16, 2010 You can pull the pin through the half beams first and than rotate the middle part in its place, but that will result in a colision and removal of the part.
AndyC Posted July 17, 2010 Posted July 17, 2010 Figures. The directions call for that piece in connection with those other three. If LDD won't allow an illegal build, why does the official LEGO directions call for it? Seems they ought to be consistent...Oh well, I'll see if I can work around it somehow(I'll look at the above suggestion). Is there a non-compression match piece? Sometimes illegal connections slip through the net, or possibly it predates TLG really clamping down on them. I don't recognise the set and can't see enough in that picture to recommend a swap, other than suggesting swapping the middle with two thin liftarms. A 3L rod with stop and a bushel on the end might also work in place of the pin.
Siegfried Posted July 17, 2010 Posted July 17, 2010 I don't recognise the set I believe it's the 10186 General Grievous set.
CP5670 Posted July 17, 2010 Posted July 17, 2010 We were actually discussing almost the same assembly here a few days ago. It does appear to be illegal if you think about how that piece works, but at the same time TLG is actually using it in a few recent sets.
Siegfried Posted July 17, 2010 Posted July 17, 2010 We were actually discussing almost the same assembly here a few days ago. It does appear to be illegal if you think about how that piece works, but at the same time TLG is actually using it in a few recent sets. Indeed you did! As it's said in that topic, everyone has oodles of pins so any piece damage is a small matter. But from a LDD point of view it's a real annoyance.
Superkalle Posted July 17, 2010 Posted July 17, 2010 It certainly looks like a brick error in LDD. I'll report it to TLG.
messiah1 Posted July 17, 2010 Posted July 17, 2010 I believe it's the 10186 General Grievous set. That is the set in question. Other than that, it's moving along nicely...I've had some frustration getting things lined up at times but it's going good for my second model.
messiah1 Posted July 17, 2010 Posted July 17, 2010 Seems most of my time in frustration is trying to find parts...does this piece exist in LDD anymore? I can't seem to find it. If it doesn't, is there a work around?
