prateek Posted August 19, 2010 Posted August 19, 2010 (edited) Yepp, that one has been noted earlier. It's needed also to complete the SW Darth VAder Tie Fighter. But interesting to know it's also used in Exoforce sets. Which one, BTW? It's used in 8114 Chameleon Hunter, but he did say he was going to use it in an MOC. Edited August 19, 2010 by prateek
Superkalle Posted August 19, 2010 Posted August 19, 2010 It's used in 8114 Chameleon Hunter, but he did say he was going to use it in an MOC. Oops, you're right!
pbk420 Posted August 21, 2010 Posted August 21, 2010 (edited) i can seem to find any piece to connect this to Edited August 21, 2010 by pbk420
Superkalle Posted August 22, 2010 Posted August 22, 2010 i can seem to find any piece to connect this to Hi First, to reduce bloating the forum, please reduce the size of screenshots before uploading them. About your question, no there is no piece in LDD that will connect to it. Normally it would be wheel 32007, but there is no connectivyt defined in LDD (yet). May be fixed in future versions though.
tiammath Posted August 22, 2010 Posted August 22, 2010 Hi all. I just noticed some weird connection between hinge plates. Don't know if there's just a rendering problem. Has someone else ever noticed that?
Superkalle Posted August 22, 2010 Posted August 22, 2010 Hi all. I just noticed some weird connection between hinge plates. Don't know if there's just a rendering problem. Has someone else ever noticed that? What where the steps you took to come to this situation? Did you just place them like that, or where they part of a bigger construction and you deleted the bricks around?
Aanchir Posted August 22, 2010 Posted August 22, 2010 (edited) As I mentioned here, I've found another error with part 32209. It cannot fit snugly into part 6538c. Here's a comparison between it and other axles: As you can see, the 5.5-length axles cannot be placed into the connector without leaving a gap in the middle. This is in addition to the known problems with the stop ring and smooth cylindrical area, which do not fit into Technic pinholes. The problem is not present with part 6538a. Edited August 22, 2010 by Aanchir
Zerobricks Posted August 22, 2010 Author Posted August 22, 2010 Works normally with ribbed axle connector though.
tiammath Posted August 22, 2010 Posted August 22, 2010 (edited) What where the steps you took to come to this situation? Did you just place them like that, or where they part of a bigger construction and you deleted the bricks around? I moved/deleted bricks around. I started at each end and joined where the weird connection happened. Here's the whole building (pieces with strange connection are the blue and the red one). I managed to have them switch properly but then the "width" of my window ins't exactly 7 studs anymore. Edited August 22, 2010 by tiammath
BrickWild Posted August 28, 2010 Posted August 28, 2010 The Pizza decal on the 2x2 round tile has been fixed!
prateek Posted August 28, 2010 Posted August 28, 2010 this needs fixing: Yes. So does the garbage can and the 2x2 radar dish piece.
SpiderSpaceman Posted August 28, 2010 Posted August 28, 2010 Yes. So does the garbage can and the 2x2 radar dish piece. yuck. come on LDD team, that's basic stuff.
roamingstop Posted August 29, 2010 Posted August 29, 2010 Might have been mentioned before. In Buzz Lightship there is a 1x2 plate with modified clip which does not exist (or I could not find under plate, modified).
Calabar Posted August 29, 2010 Posted August 29, 2010 Might have been mentioned before. In Buzz Lightship there is a 1x2 plate with modified clip which does not exist (or I could not find under plate, modified). Yes, it is a known lack! We simply used 1x1 plate and 1x1 plate with clip (of the same type) to replace it!
Makuta Plasmix Posted September 5, 2010 Posted September 5, 2010 I have 1 extremely aggravating Bug. Whenever I open LDD and try to click something or click something,the screen goes black 3 times, the graphics mess up, and then it finally registers what I pushed. I have Windows Vista also. I was able to use LDD 2.0 eaisly, but this one doesnt work at all. Any help would be appreciated.
Zerobricks Posted September 5, 2010 Author Posted September 5, 2010 I have 1 extremely aggravating Bug. Whenever I open LDD and try to click something or click something,the screen goes black 3 times, the graphics mess up, and then it finally registers what I pushed. I have Windows Vista also. I was able to use LDD 2.0 eaisly, but this one doesnt work at all. Any help would be appreciated. Your computer specs? Are your drivers up to date?
xSergio74 Posted September 5, 2010 Posted September 5, 2010 Hi, try disabling some graphics features of Vista like the desktop composition in PerformanceOptions.VisualEffects from Control Panel. This might solve the problem and anyway give you a performance boost from 10% to 30% to any graphic intensive applications. byes Sergio I have 1 extremely aggravating Bug. Whenever I open LDD and try to click something or click something,the screen goes black 3 times, the graphics mess up, and then it finally registers what I pushed. I have Windows Vista also. I was able to use LDD 2.0 eaisly, but this one doesnt work at all. Any help would be appreciated.
alienwar9 Posted September 5, 2010 Posted September 5, 2010 Well, I've sort of found a bug. LDD and my large model worked together to fry my graphics card and I had to get it replaced. That was fun. I've worked my computer to death but apparently LDD is worse than anything else and is the spear that stabbed my card, lol. Please please optimize the next LDD so it uses multi-core processors and doesn't hog memory. I have LDD open right now and its using 1,170,000k of memory. It's painful
Superkalle Posted September 5, 2010 Posted September 5, 2010 Well, I've sort of found a bug. LDD and my large model worked together to fry my graphics card and I had to get it replaced. That was fun. I've worked my computer to death but apparently LDD is worse than anything else and is the spear that stabbed my card, lol. Please please optimize the next LDD so it uses multi-core processors and doesn't hog memory. I have LDD open right now and its using 1,170,000k of memory. It's painful I'm not sure I understand how LDD can fry a graphics card, even if it's a huge model. Was the GPU cooling adequate? But I agree LDD is not great on huge models. There are just to many polygons that need to be rotated and re-drawn, and I guess it's a matter of optimizing those, while still having a full editable model. I know that LDD does have some optimization. For example, surfaces that are not seen are removed (for example when putting two bricks together the inside parts that are not visible anymore are not drawn). But I'm no expert in this field, so maybe someone else has better insights. Also, it'd be kind of interersting if LDD would be much faster with a professional graphics card that has hardware OpenGL support.
roamingstop Posted September 6, 2010 Posted September 6, 2010 On the 851 Technic tractor, 1x2 bricks are connected to the large gear wheel with their studs pressed into the various holes (step 7), however in LDD this will not work. Sample image here For the model I have used technic studs, connected the bricks upside down and used 2x2 tile plates instead. Getting the gears to mesh in LDD was a pain - but worked eventually.
CMP Posted September 11, 2010 Posted September 11, 2010 I was asked to post this bug here. It may have been posted before, but I'd rather not dig through 14 pages. The blue technic pins will not fully go into the clicky hinges (gray part of the wings) as you can see.
Superkalle Posted September 11, 2010 Posted September 11, 2010 I was asked to post this bug here. It may have been posted before, but I'd rather not dig through 14 pages. The blue technic pins will not fully go into the clicky hinges (gray part of the wings) as you can see. Well spotted. Once of the worst bugs in a long time. I even had to bring out the some real parts to try it out. Concider it reported to TGL!
prateek Posted September 11, 2010 Posted September 11, 2010 (edited) Well spotted. Once of the worst bugs in a long time. I even had to bring out the some real parts to try it out. Concider it reported to TGL! Hmm... I found this out a long time ago. I thought it was already posted, so I didn't bother. BTW, I found some more errors: No pieces can fit on this piece in a certain location (don't know how to describe it) Bricks can't fit in on the last stud of the outer rows inside the wall of this piece. I was trying to build 3222 and I couldn't because of these problems. Edited September 11, 2010 by prateek
