ADHO15 Posted November 20, 2010 Posted November 20, 2010 (edited) You should rightfully be proud. That's one beeeep of a task you set out to do seven months ago. So, what's next? Any ideas? Thank you very much, Superkalle. Oh, don't worry. There'll be more sets on the way soon! Admittedly, the headgear you chose for him looks pretty cute and feels appropriate for a less fancy sort of chef selling... barbecue drumsticks... on the street... for some reason. I agree. That hat looks much better. Edited September 15, 2012 by ADHO15 Quote
XimenaPaulina Posted November 21, 2010 Posted November 21, 2010 (edited) Why modified headgear for the chef? The chef's hat is available on LDD- it's part 3898 MINI BAKER'S HAT, and appears in the minifig parts category. Admittedly, the headgear you chose for him looks pretty cute and feels appropriate for a less fancy sort of chef selling... barbecue drumsticks... on the street... for some reason. EDIT: Also, his drumstick should be dark orange, not reddish brown. I was looking for that damn baker's hat repeatedly last night and can't seem to find it (maybe I was just tired or something). I'll try to fix it later, as well as the drumstick color. Thanks for pointing out. EDIT: There you go, already edited the entry. Thanks again for the help. Edited November 21, 2010 by KielDaMan Quote
C3POwen Posted November 21, 2010 Posted November 21, 2010 I can't download the file. Is it a problem of mine or other users can confirm it? It appears to be a problem with Windows SkyDrive, which occasionally changes the URL to the file to avoid direct linking. I'm going to start transferring all the files over to a Brickshelf account, so should have that done by the end of the evening. Quote
Aanchir Posted November 21, 2010 Posted November 21, 2010 Here's another construction set: 7746 Single-Drum Roller from the City theme! LXF File Errors: The mirrors use part 4735 which has a known alignment error. They have been left to the side. Due to a boundary error, the hexagonal plates (64566) will not fit inside the giant wheel piece (55817). They have been left to the side of the model. I couldn't get the minifigure to hold the handlebars of that smoothing machine (don't know what you call it). Stickers are not available as decorations. Any parts that should be decorated with stickers have been left blank. Quote
C3POwen Posted November 21, 2010 Posted November 21, 2010 (edited) 5563 Racing Truck Model Team LXF file Notes: - LDD is missing Hose, Ribbed 7mm D. 6L, Vehicle, Grille Guard, Door 1x6x8 Left and Door 1x6x8 Right, all of which have been substituted. - One of the Conical Wheel Z12 (6589) parts won't align, and has been left underneath the model. - No stickers. Edited January 23, 2011 by C3POwen Quote
Superkalle Posted November 21, 2010 Posted November 21, 2010 Errors: The mirrors use part 4735 which has a known alignment error. They have been left to the side. Why not place the 4735 on the model? I mean, the piece works, and it's not that big of an issue that is slightly misalingned? Or is there a reason why you don't do it? Quote
Aanchir Posted November 21, 2010 Posted November 21, 2010 Why not place the 4735 on the model? I mean, the piece works, and it's not that big of an issue that is slightly misalingned? Or is there a reason why you don't do it? I'm just pretty OCD about my hinges. Getting clip-and-bar hinges to align right on LDD is hard enough on its own (usually they won't be centered properly unless you create a scaffold). Since I can't exactly create a scaffold for a hinge that is out-of-alignment with the rest of the piece it's on to begin with, I prefer to leave the things incomplete and fix them when the piece in question is repaired in a future version or patch. Quote
Plastemaurer Posted November 21, 2010 Posted November 21, 2010 (edited) Hello everyone, just recently discovered LDD and even managed to make it run on my Linux box (via Wine). So here is my first official set made in LDD: 6851 - Tri-Wheeled Tyrax - Theme: Space, Blacktron II Download here. It should be complete, except for the decorations of course. If a part has a wrong color, please tell me and I'll correct it. Update: Colors of transparent parts corrected. Update II:Re-checked the .lxf file and original instructions and found following error/modification: - Brick, Modified 2 x 2 with Pin and No Axle Hole replaced by Brick, Modified 2 x 2 with Pin and Axle Hole. Edited November 22, 2010 by Plastemaurer Quote
Superkalle Posted November 21, 2010 Posted November 21, 2010 I'm just pretty OCD about my hinges. Getting clip-and-bar hinges to align right on LDD is hard enough on its own (usually they won't be centered properly unless you create a scaffold). Since I can't exactly create a scaffold for a hinge that is out-of-alignment with the rest of the piece it's on to begin with, I prefer to leave the things incomplete and fix them when the piece in question is repaired in a future version or patch. OK, but please note that there is nothing wrong with the part as such. It is a just a few degrees off, but fully usable since LDD takes up the "slack". It's only if you use it the way privat_lego showed that it is a problem (and that must be very, very rare since no-one saw the problem before private_lego told us) Quote
Aanchir Posted November 21, 2010 Posted November 21, 2010 (edited) Hello everyone, just recently discovered LDD and even managed to make it run on my Linux box (via Wine). So here is my first official set made in LDD: 6851 - Tri-Wheeled Tyrax - Theme: Space, Blacktron II Download here. It should be complete, except for the decorations of course. If a part has a wrong color, please tell me and I'll correct it. All the transparent parts should be color 49 Transparent Fluorescent Green (the second option when you hover the cursor over Transparent Green). 311 Transparent Bright Green is a new color for 2010 used in Atlantis sets. Otherwise, great job! Nice to see a set this classic that can be built without errors! Edited November 21, 2010 by Aanchir Quote
Plastemaurer Posted November 21, 2010 Posted November 21, 2010 All the transparent parts should be color 49 Transparent Fluorescent Green (the second option when you hover the cursor over Transparent Green). 311 Transparent Bright Green is a new color for 2010 used in Atlantis sets. Otherwise, great job! Nice to see a set this classic that can be built without errors! Ah, thanks. Corrected them.. Quote
Superkalle Posted November 21, 2010 Posted November 21, 2010 Hello everyone, just recently discovered LDD and even managed to make it run on my Linux box (via Wine). Hi, welcome to the LDD forum. Cool that you got LDD to run on Linux. Good to know if anyone asks if it's possible in the future. Quote
Plastemaurer Posted November 21, 2010 Posted November 21, 2010 It does not work 100%, though. Most of the time, the browser on the right panel shows nothing/is just black, and clicking on links there (if there is something) has no effect. Also, the font on the interface (buttons, tool tips, etc.) is difficult to read. Aside from that, it works quite well. Anyway, here is another one: 6812 - Grid Trekkor - Theme: Space, Blacktron II Download here. Errors: - Plate, Modified 2 x 2 with Wheels White is not available in LDD, replaced them with Plate, Modified 2 x 2 with Wheels Holder and Wheel 8mm D. x 6mm - The balloon tyres could not be fitted onto the aformentioned replacement. - No decorations. Quote
Daedalus304 Posted November 22, 2010 Posted November 22, 2010 (edited) I haven't posted anything in a while... but I've made a few. Here's a couple more, hopefully I'll back into the swing of things soon! First up is: 30051 X-Wing - Theme: Star Wars Already been posted by ADHO15 Download the LXF! No errors to report here! Mostly just built it because I recently bought a few and thought it was pretty nifty. Next up, a new one! 7262 TIE Fighter and Y-Wing Download the LXF! The only errors in this set were substituted prints, and both pilot's helmet are missing. As a note, this set is not to be confused with the 7150 set of the same name. This was the 2004 (?) Re-release of the set, featuring the new greys and an entirely re-designed TIE Advance, now built in the same modular fashion as the rest of LEGO's TIE fighters. Edited November 22, 2010 by Daedalus304 Quote
BrickWild Posted November 22, 2010 Posted November 22, 2010 I couldn't get the minifigure to hold the handlebars of that smoothing machine (don't know what you call it). It's a vibrating plate compactor! Quote
ADHO15 Posted November 22, 2010 Posted November 22, 2010 Next up, a new one! 7262 TIE Fighter and Y-Wing I thought that was just the same as the other release. A tip for you: if you add the colours to the astromech's dome, save it and close LDD, when you reopen it, the rings should be all the way round instead of just parts. That's when you should take your screenshot. Quote
Calabar Posted November 22, 2010 Author Posted November 22, 2010 I thought that was just the same as the other release. It is almost identical, peeron state the same number of piece but one minifig more for the 7262. Quote
XimenaPaulina Posted November 22, 2010 Posted November 22, 2010 4899 - Tractor (Promo) / Theme: City (NEW) - LXF Modifications: - No errors --- 5620 - Street Cleaner / Theme: City (NEW) - LXF Modifications: 1) Modified Torso --- 5625 - Police 4X4 (Promo) / Theme: City (NEW) - LXF Modifications: - No errors Quote
C3POwen Posted November 22, 2010 Posted November 22, 2010 (edited) 7948 Outpost Attack Castle/Kingdoms LXF file Notes: - Metallic Silver, Pearl Gold and Pearl Light Grey colours have been substituted with best available match. - Stickers, and most of the prints, are missing. Edited January 23, 2011 by C3POwen Quote
Plastemaurer Posted November 22, 2010 Posted November 22, 2010 6832 - Super Nova II - Theme: Space, Blacktron II Download here. Errors/Modifications: - Hinge Plate 1 x 2 with 3 Fingers On Side replaced by Hinge Plate 1 x 2 Locking with 2 Fingers on Side. - Hinge Plate 1 x 2 with 2 Fingers replaced by Hinge Plate 1 x 2 Locking with 1 Finger On End. - Wedge, Plate 4 x 4 Wing Left and Wedge, Plate 4 x 4 Wing Right replaced by Wedge, Plate 4 x 4 Cut Corner. - The extra tile is a Tile 1 x 2 with Red and Yellow Controls Pattern and belongs into the storage compartment. - No decorations. 6933 - Spectral Starguider - Theme: Space, Blacktron II Download here. Errors/Modifications: - Hinge Plate 1 x 2 with 3 Fingers On Side replaced by Hinge Plate 1 x 2 Locking with 2 Fingers on Side. - Hinge Plate 1 x 2 with 2 Fingers replaced by Hinge Plate 1 x 2 Locking with 1 Finger On End. - Hinge Plate 1 x 2 with 3 Fingers replaced by Hinge Plate 1 x 2 Locking with 2 Fingers On End. - Windscreen 6 x 6 Octagonal Canopy without Axle hole replaced by Windscreen 6 x 6 Octagonal Canopy with Axle hole. - Wedge, Plate 3 x 4 without Stud Notches replaced by Wedge, Plate 3 x 4 with Stud Notches. - Hinge Tile 1 x 2 1/2 with 2 Fingers on Top replaced by Hinge Tile 1 x 3 Locking with 1 Finger on Top. - Hinge Tile 1 x 4 replaced by Hinge Tile 1 x 4 Locking Dual 1 Fingers on Top. - Hinge Vehicle Roof 4 x 4 replaced by Hinge Plate 3 x 4 Locking Dual 2 Finger. This, in combination with the Hinge Tile 1 x 4 Locking Dual 1 Fingers on Top causes the roof of the cargo module to not close properly (see .lxf file for details). - Brick, Modified 2 x 2 with Pin and No Axle Hole replaced by Brick, Modified 2 x 2 with Pin and Axle Hole. - Brick, Modified 1 x 2 x 2 1/3 with Spring Unit replaced by a construction with 1x Technic, Brick 1 x 2 with Hole, 3x Plate 1 x 2 and 1x Plate 2 x 2. It has no spring mechanism anymore (see .lxf file for details). If I just missed the part, please tell me and I'll correct it. - The extra tile is a Tile 1 x 2 with Red and Yellow Controls Pattern and belongs into the storage compartment inside the cargo module. - No decorations. Quote
Calabar Posted November 22, 2010 Author Posted November 22, 2010 (edited) Index updated. 3 new Themes added 117 Sets has been added to the index (16 alternative, 14 duplicate, 4 incomplete). Check your sets and report errors or inaccuracies! 1 Set has not been added to the index because irregular. Fix your sets in order to be added to the index! 1 Sets has not been added to the index because unofficial or still unreleased. Topic's Rules Revisited. Please read that again! List of Irregular Sets: (image exceed maximum size) - [star Wars] 7119 - Twin Pod Cloud Car - by BrickWild [Fixed] (unreleased set) - 8065 - Mini Dump Truck - by merman Lists of previously reported irregular posts here, here, here and here. Edited September 12, 2012 by Calabar Quote
Superkalle Posted November 22, 2010 Posted November 22, 2010 Hinge Plate 3 x 4 Locking Dual 2 Finger. This, in combination with the Hinge Tile 1 x 4 Locking Dual 1 Fingers on Top causes the roof of the cargo module to not close properly (see .lxf file for details). Interesting case. You can see a small fragment of a milimeter difference (circled in blue), causing it not to close. I wonder if this building technique in system or not? EDIT: To Calabar - I'll delete the picture shortly. Quote
Tore M Posted November 23, 2010 Posted November 23, 2010 (edited) 8421 Mobile Crane - Theme: Technic - LXF file Errors: Piece does not fit: The second Black Technic Wedge Belt Wheel (Pulley) left next to the model because it will not fit properly on the Black Technic, Pin with Friction Ridges Lengthwise at the back of the truck. The available engine parts have been left next to the model because the pieces (Light Bluish Gray Technic Engine Crankshaft, Dark Bluish Gray Technic Engine Crankshaft Center and Red Technic, Axle 2 Notched) do not fit properly together and thus does not fit in the available space. 2x Black Technic, Axle and Pin Connector Angled #3 - 157.5 degrees from the driver's cab left next to the model because the axle holes in the connectors seem too shallow. 1x Light Bluish Gray Technic, Gear 24 Tooth (New Style with Single Axle Hole) from the crane mechanism left next to the model because of a collison bug with Light Bluish Gray Technic, Pin Long with Friction Ridges Lengthwise and Stop Bush directly above it. 1x Dark Bluish Gray Technic, Gear 16 Tooth with Clutch from the crane mechanism left next to the model because those gears can't be rotated and thus will not fit. 1x Light Bluish Gray Pneumatic T Piece New Style (T Bar) left next to the model because there are no pneumatic hoses to connect it to. 2x Black String with End Studs 31L Overall left next to the model because these strings do not bend in LDD. Piece missing, but replaced: 2x Yellow Pneumatic Cylinder with 2 Inlets and Rounded End Medium (48mm) not present in LDD. Replaced with a slightly modified version of Zblj's custom piece for better looks and grouped for easy removal. 1x Dark Bluish Gray Pneumatic Switch with Pin Holes not present in LDD. Replaced with a slightly modified version of Zblj's custom piece for better looks and grouped for easy removal. 1x Black Electric, Motor RC Race Buggy not present in LDD. Replaced with Zblj's custom piece for better looks and grouped for easy removal. 1x Yellow Pneumatic Pump New Style with Black Top not present in LDD. Replaced with Zblj's custom piece for better looks and grouped for easy removal. 1x Yellow Electric 9V Battery Box 4 x 14 x 4 with Dark Bluish Gray Base Complete Assembly not present in LDD. Replaced with custom built piece for better looks and grouped for easy removal. Piece missing: 1x Dark Bluish Gray Technic, Gear Differential, 24-16 Teeth missing, not present in LDD. 6x Light Bluish Gray Technic Engine Cylinder missing, not present in LDD. 2x Yellow Pneumatic Cylinder Bracket missing, not present in LDD. 1x Black Hose, Pneumatic 4mm D. 16L and 1x Blue Hose, Pneumatic 4mm D. 16L missing, not present in LDD. 2x White Technic, Gear 24 Tooth Clutch missing, not present in LDD. 1x Black String, Cord Medium Thickness 250cm missing, not present in LDD. 2x Black Bionicle Bohrok Shoulder, Liftarm 1 x 3 x 7 missing, not present in LDD. 1x Black Technic Hook Large Metal missing, not present in LDD. 1x Black Electric, Wire with Brick 2 x 2 x 2/3 Pair, 20 Studs Long missing, not present in LDD. No Stickers. Edited November 23, 2010 by Tore M Quote
Zerobricks Posted November 23, 2010 Posted November 23, 2010 Great job with this one! Nice use of custom bricks too. You forgot to put axle 3M and bush on outrigger levers ends and i think there is eomthing missing by the worm to 8 tooth gear tranmission on far top.. Other than that all I can say is AWESOME! Quote
XimenaPaulina Posted November 23, 2010 Posted November 23, 2010 5610 - Builder / Theme: CITY (NEW) - LXF --- 5627 - Mini Bulldozer (Promo) / Theme: CITY (NEW) - LXF --- 5642 - Tipper Truck (Promo) / Theme: CITY (NEW) - LXF Quote
