May 2, 201113 yr On 5/2/2011 at 12:48 PM, Aanchir said: Skeleton Barbossa's shoulder accessory should be 26 Black rather than 140 Earth Blue.No idea why I made that blue. On 5/2/2011 at 12:48 PM, Aanchir said: Skeleton Barbossa's torso should be part 93060, not 60115.My bad. Forgot to check the number on that one On 5/2/2011 at 12:48 PM, Aanchir said: The 1x1 plate with clip should probably be part 60897 (BL's 4085b and 4085d) rather than 4085-- I don't trust Bricklink on this, since 4085d is the current version and the one all my 2011 sets use. However, you're welcome to continue using 4085 if you prefer to go by Bricklink's assessment. On 5/2/2011 at 12:48 PM, Aanchir said: In this case, you definitely ought to use 60897 instead of 4085. 60897 may not look correct, but it is the actual part number molded onto Bricklink's part 4085d. Other than that, no problems with this one. Great work! If they're called 4085c, or d, or whatever, surely 4085 is closer? Neither is right anyway.
May 2, 201113 yr On 5/2/2011 at 12:57 PM, ADHO15 said: If they're called 4085c, or d, or whatever, surely 4085 is closer? Neither is right anyway. Actually, Bricklink prefers to give old part numbers to what they consider "new versions" of older parts in a lot of cases. A better question would be why TLG will sometimes give new part numbers to these new versions (for instance, assigning #60897 to part 4085b) and other times re-use part numbers on a radically different mold (keeping the same part number for the newer 4085d). But yeah; I'm just sharing which one is the part number actually listed on the piece, which these days tends to be the one I go by regardless of appearance. It's your choice which you'd rather have on your sets, since it's a fairly subjective issue.
May 2, 201113 yr On 5/2/2011 at 1:02 PM, Aanchir said: Actually, Bricklink prefers to give old part numbers to what they consider "new versions" of older parts in a lot of cases. A better question would be why TLG will sometimes give new part numbers to these new versions (for instance, assigning #60897 to part 4085b) and other times re-use part numbers on a radically different mold (keeping the same part number for the newer 4085d). But yeah; I'm just sharing which one is the part number actually listed on the piece, which these days tends to be the one I go by regardless of appearance. It's your choice which you'd rather have on your sets, since it's a fairly subjective issue. I see. Well, thanks for your help anyway. I might as well just keep them as they are until LDD adds the different parts, if it does. I'll try to be more careful on the coming sets. EDIT: I might as well put the next ones here to save looking back. 4182 The Cannibal Escape (4.1) LXF File Errors: Replaced parts 95221pb01 with 40251, 95226 with 64807 and 95228 with 64644 Replaced Metallic Silver with Metalized Silver Incorrect/missing prints 4183 The Mill (4.1) LXF File Errors: Missing parts 95343, 95344 and x77cc30 Replaced parts 95221pb01 with 40251, 95226 with 64807 and 95228 with 64644 and Shell Headgear with 40235 Replaced Pearl Dark Grey with Titanium Metallic Incorrect/missing prints and stickers Edited May 6, 201113 yr by ADHO15
May 4, 201113 yr 5867 - Super Speedster (Bonus Alternate Hot Rod) - Theme: Creator LXF File As far as I know, this model is error-free. -Toa Of Justice
May 4, 201113 yr Author On 5/4/2011 at 3:33 PM, Toa_Of_Justice said: 5867 - Super Speedster (Bonus Alternate Hot Rod) - Theme: Creator Oh great I love this model! Thanks for the link to the instructions! :)
May 5, 201113 yr On 5/4/2011 at 10:02 PM, trevorgentry said: Invader Zim! LOL! Just a file I made real quick. Zim.zipUnavailable Either you didn't pay attention to what this index is, or you accidentally posted it in the wrong place. But this is for displaying sets designed by Lego. There is another index for displaying MOC's. =)
May 5, 201113 yr Aye, har be some more sets: 4192 Fountain Of Youth (4.1) LXF File ERRORS: Missing part bb515pb01 Replaced parts 95221pb01 with 40251, 95222pb01 with 90538, 95354 with 2564, bb512pb01 with 60750 and bb514c01 with 60752 Replaced Flat Silver with Metalized Silver Incorrect/missing prints 4193 The London Escape (4.1) LXF File ERRORS: Missing parts 95343 and 95344 Replaced parts 2544pb01 with 2544, 94161 with 30046, 95220pb01 with brick-built solution, 95226 with 64807, 95228 with 64644, 95354 with 2564 and 99563 with 3069 Incorrect/missing prints 4194 Whitecap Bay (4.1) LXF File ERRORS: Missing parts 95343 and 95344 Replaced parts 87585 with 2542, 95220pb01 with brick-built solution, 95226 with 64807, 95228 with 64644, 95348 with 61976, 95351pb01 with 73200, 95351pb02 with 73200, 95354 with 2564 and 99563 with 3069 Incorrect/missing prints and stickers Edited May 6, 201113 yr by ADHO15
May 5, 201113 yr On 5/5/2011 at 1:57 PM, ADHO15 said: Aye, har be some more sets: 4192 Fountain Of Youth (4.1) LXF File ERRORS: Missing part bb515pb01 Replaced parts 95221pb01 with 40251, 95222pb01 with 90538, 95354 with 2564, bb512pb01 with 60750 and bb514c01 with 60752 Replaced Flat Silver with Metalized Silver Incorrect/missing prints Flat Silver parts in 2011 sets should actually be 315 Silver Metallic. This is the new pearl silver color that debuted during summer 2010. Bricklink is very inconsistent with what they call it (in some instances I've seen it called Pearl Dark Grey, despite an entirely separate color existing that also gets that label), but thankfully this year they've somewhat standardized it so that Flat Silver is used for most parts in 315 Silver Metallic. The two brown slopes should be 308 Dark Brown rather than 192 Reddish Brown. Barbossa's hands should be 1 White rather than 283 Light Nougat. Quote 4193 The London Escape (4.1)LXF File ERRORS: Missing parts 95343 and 95344 Replaced parts 2544pb01 with 2544, 94161 with 30046, 95220pb01 with brick-built solution, 95226 with 64807, 95228 with 64644, 95354 with 2564 and 99563 with 3069 Incorrect/missing prints The prints for the white horse's face are actually available. To access them, click View>New Themes>LEGO DesignByMe to switch to DesignByMe mode where you can generate the printed horse from the brick tray, or download my LDD Decorations file which includes all decorated parts that function on LDD (including many others that can't be applied with the decoration tool). Technically, the 1x1 plates with clips are a version of part 60897 rather than a version of part 4085. The appearance of part 60897 on LDD is misleading and depicts an older version of this piece, but the underside of the part labeled as 4085d on Bricklink actually confirms its part number as 60897. The 1x2x2 panel pieces should be part 87552 rather than 4864. There is a 308 Dark Brown 1x2 plate (3023) that should probably be 192 Reddish Brown. The coachman's waist should be 26 Black, not 199 Dark Stone Grey. Quote 4194 Whitecap Bay (4.1)LXF File ERRORS: Missing parts 95343 and 95344 Replaced parts 87585 with 2542, 95220pb01 with brick-built solution, 95226 with 64807, 95228 with 64644, 95348 with 61976, 95351pb01 with 73200, 95351pb02 with 73200, 95354 with 2564 and 99563 with 3069 Incorrect/missing prints and stickers Just a single error with this one: the button on the back of the light brick should be 194 Dark Stone Grey rather than 199 Dark Stone Grey
May 6, 201113 yr On 5/5/2011 at 4:48 PM, Aanchir said: [*]Technically, the 1x1 plates with clips are a version of part 60897 rather than a version of part 4085. The appearance of part 60897 on LDD is misleading and depicts an older version of this piece, but the underside of the part labeled as 4085d on Bricklink actually confirms its part number as 60897. So all 4085d parts should be 60897 and the rest 4085? On 5/5/2011 at 4:48 PM, Aanchir said: Just a single error with this one: the button on the back of the light brick should be 194 Dark Stone Grey rather than 199 Dark Stone Grey You mean Medium Stone Grey? Thank you very much for your help. There are two sets further up the page that you may want to check. The rest of the errors have been corrected. And finally: 4195 Queen Anne's Revenge (4.1) LXF File ERRORS: Missing parts 75c12, 95343, 95344, bb511pb01, sailbb48, sailbb49, sailbb50, sailbb51 and x127c11 Replaced parts 90398pb01 with 85863, 95220pb01 with brick-built solution, 95222pb01 with 90538, 95227 with 2560, 95228 with 64644, 95229 with 6020, 95352pb01 with brick-built solution, 95354 with 2564, bb512pb01 with 60750, bb514c01 with 60752 Replaced Pearl Dark Grey with Titanium Metallic Incorrect/missing prints and stickers Enjoy! Edited May 6, 201113 yr by ADHO15
May 6, 201113 yr On 5/2/2011 at 1:06 PM, ADHO15 said: I see. Well, thanks for your help anyway. I might as well just keep them as they are until LDD adds the different parts, if it does. I'll try to be more careful on the coming sets. EDIT: I might as well put the next ones here to save looking back. 4182 The Cannibal Escape (4.1) LXF File Errors: Replaced parts 95221pb01 with 40251, 95226 with 64807 and 95228 with 64644 Replaced Metallic Silver with Metalized Silver Incorrect/missing prints As always, the 1x1 vertical clips in current sets would be 60897 rather than 4085, but of course you know that and it doesn't affect the model whether you go by LDD appearance (as you have done) or by part number. Anyway, Bricklink lists it as 4085c, which if that's really the type in this set would be 4085 (although I'm extremely skeptical, and almost certain it would be 4085d instead). The 1x1 horizontal clips have the same deal. Modern sets will use 61252, and on LDD the two bricks are pretty much identical so there shouldn't be any problem. But again, Bricklink lists the older version, and again, I'm not too confident in the assessment of whoever inventoried this set. Metallic Silver parts should be 298 Cool Silver Drum Lacquered rather than 309 Metalized Silver. 309 Metalized Silver is chrome silver, btw, if it helps you on future MOCs (to my knowledge it and 310 Chrome Gold may be the only two chrome colors to have material IDs at all). Quote 4183 The Mill (4.1)LXF File Errors: Missing parts 95343, 95344 and x77cc30 Replaced parts 95221pb01 with 40251, 95226 with 64807 and 95228 with 64644 and Shell Headgear with 40235 Replaced Pearl Light Grey with Titanium Metallic Incorrect/missing prints and stickers Good job getting the correct color on the fish; this is yet another set where Bricklink chose a completely illogical color for it. But then again, Bricklink also says the 2x2 corner slopes are 3x3 corner slopes, so here you are and there you go. On 5/6/2011 at 2:35 PM, ADHO15 said: So all 4085d parts should be 60897 and the rest 4085? Generally. 4085b should also be 60897 in any recent sets (as in, any sets in the last decade). Quote You mean Medium Stone Grey? My bad. I make mistakes too. Quote And finally:4195 Queen Anne's Revenge (4.1) LXF File ERRORS: Missing parts 75c12, 95343, 95344, bb511pb01, sailbb48, sailbb49, sailbb50, sailbb51 and x127c11 Replaced parts 90398pb01 with 85863, 95220pb01 with brick-built solution, 95222pb01 with 90538, 95227 with 2560, 95228 with 64644, 95229 with 6020, 95352pb01 with brick-built solution, 95354 with 2564, bb512pb01 with 60750, bb514c01 with 60752 Replaced Pearl Dark Grey with Titanium Metallic Incorrect/missing prints and stickers Enjoy! Your model includes 4 12M axles. According to Bricklink there should be 3 12M axles and 1 10M axle. But I can't be totally sure Bricklink is correct in this case. Better to double-check. You have one of brick 64644 in black which is not in the Bricklink inventory. Since you're using those as substitutes for the transparent brown bottle piece 95228, I'm guessing you may have colored it incorrectly? The cook's waist should be 308 Dark Brown rather than 5 Brick Yellow. Bricklink suggests that the cannon 84943 should be all one color, but it's hard to tell if it's accurate on this. Again the thing with part 4085-- BL says it should be 4085, while I'm pretty confident it should be 60897. Go by your own judgment. Same with 6019, which I believe would really be 61252. You have two of brick 48729 in 199Dark Stone Grey and 3 in 194 Medium Stone Grey. Bricklink says all of them should be 194 Medium Stone Grey. Great job on all these sets!
May 6, 201113 yr On 5/6/2011 at 7:38 PM, Aanchir said: As always, the 1x1 vertical clips in current sets would be 60897 rather than 4085, but of course you know that and it doesn't affect the model whether you go by LDD appearance (as you have done) or by part number. Anyway, Bricklink lists it as 4085c, which if that's really the type in this set would be 4085 (although I'm extremely skeptical, and almost certain it would be 4085d instead). The 1x1 horizontal clips have the same deal. Modern sets will use 61252, and on LDD the two bricks are pretty much identical so there shouldn't be any problem. But again, Bricklink lists the older version, and again, I'm not too confident in the assessment of whoever inventoried this set. Alright. I'll just leave them as they are for now. On 5/6/2011 at 7:38 PM, Aanchir said: Metallic Silver parts should be 298 Cool Silver Drum Lacquered rather than 309 Metalized Silver. 309 Metalized Silver is chrome silver, btw, if it helps you on future MOCs (to my knowledge it and 310 Chrome Gold may be the only two chrome colors to have material IDs at all). Ah, right. I'll remember those. I'll probably need to make some corrections to the HP sets now then. It never ends this LDD building, does it?! On 5/6/2011 at 7:38 PM, Aanchir said: Good job getting the correct color on the fish; this is yet another set where Bricklink chose a completely illogical color for it. But then again, Bricklink also says the 2x2 corner slopes are 3x3 corner slopes, so here you are and there you go. That must have been coincidence. I notice I wrote Pearl Light Grey instead of Pearl Dark Grey in my post though, so I'll change that. The BL inventory for this set appeared literally less than a minute after I finished the set, so I had to build without it. I noticed the slope error there, but went with the instructions that definitely showed that they were 2x2. On 5/6/2011 at 7:38 PM, Aanchir said: Generally. 4085b should also be 60897 in any recent sets (as in, any sets in the last decade). Right, I'll remember that for future sets. On 5/6/2011 at 7:38 PM, Aanchir said: Your model includes 4 12M axles. According to Bricklink there should be 3 12M axles and 1 10M axle. But I can't be totally sure Bricklink is correct in this case. Better to double-check. Yes, it was half over the angled mast that should be 10 rather than 12. Missed that. On 5/6/2011 at 7:38 PM, Aanchir said: You have one of brick 64644 in black which is not in the Bricklink inventory. Since you're using those as substitutes for the transparent brown bottle piece 95228, I'm guessing you may have colored it incorrectly? I did that by accident when I was checking the part number to report the errors here. I clicked on it first with the Paint tool and didn't notice the change. When I updated the file with Angelica's feather, the black part was still there. On 5/6/2011 at 7:38 PM, Aanchir said: Bricklink suggests that the cannon 84943 should be all one color, but it's hard to tell if it's accurate on this. Yes, my fault. I forgot they were two separate parts and forgot to change the back colours. On 5/6/2011 at 7:38 PM, Aanchir said: Again the thing with part 4085-- BL says it should be 4085, while I'm pretty confident it should be 60897. Go by your own judgment. Same with 6019, which I believe would really be 61252. Seeing as it's difficult to run back through the set to find all these parts and change them, I'll just leave them this time. On all future sets, I'll try to decide which is best. On 5/6/2011 at 7:38 PM, Aanchir said: You have two of brick 48729 in 199Dark Stone Grey and 3 in 194 Medium Stone Grey. Bricklink says all of them should be 194 Medium Stone Grey. Yes, I made them Dark Stone Grey originally, because I hadn't seen them in Medium Stone Grey before and thought I'd just looked at the instructions wrong. When I realised, I guess I didn't correct all five parts. On 5/6/2011 at 7:38 PM, Aanchir said: Great job on all these sets! Thank you, and thank you very much for checking them all to find what I missed.
May 7, 201113 yr On 4/26/2011 at 11:11 PM, Aanchir said: I also see some decorations that you can't normally get with the decorations tool. Are you using my decorations file from the LDD Reference topic, or generating the parts with LDD Manager? Either way, nice to see people using either tool to access those otherwise-hidden decorations! Also, I'm so glad you went to the trouble of thoroughly listing every change you made from the official set. I always generate the parts with LDD Manager based on Bricklink's listing first, then use your decorations and colour files whenever needed. Many thanks to Superkalle and you for those tools! And I really need a thorough list, if I'm ever going to be able to correct the errors when more bricks/colours/decorations become available in LDD
May 7, 201113 yr 1924 - Viking Line Ferry Year - 1992 Theme - Ferries LXF File Issues: - No stickers - Replaced part 2625 with 50303 - Following pieces were left white, ferry square pieces aren't available: 3009px48, 3009px21, 3008px33, 3660pb02 - Piece 3068bp67 was left white, the red quarter rings pattern isn't available.
May 8, 201113 yr On 5/7/2011 at 11:10 PM, moop2000 said: 1924 - Viking Line Ferry Year - 1992 Theme - Ferries LXF File Issues: - No stickers - Replaced part 2625 with 50303 - Following pieces were left white, ferry square pieces aren't available: 3009px48, 3009px21, 3008px33, 3660pb02 - Piece 3068bp67 was left white, the red quarter rings pattern isn't available. Lovely model! But there are a few errors. It was hard to check for them since the Bricklink inventory seems woefully inaccurate; in the end I had to go through every piece in the order they were added in the instructions in order to be sure of what was in fact an error. Bricklink says there should be only two 2x2 45 degree inverse slopes (piece 3660); your model has four. According to Bricklink and the instructions, two of these are supposed to instead be 2x2 bricks (piece 3003). You have two 4x10 black plates (piece 3030) where Bricklink and the instructions say you should have one 4x10 black plate and one 4x8 black plate. The 1x6 arch piece should be part 3455 rather than 92950. Great work on this beautiful set!
May 8, 201113 yr On 5/8/2011 at 4:39 PM, Aanchir said: Bricklink says there should be only two 2x2 45 degree inverse slopes (piece 3660); your model has four. According to Bricklink and the instructions, two of these are supposed to instead be 2x2 bricks (piece 3003). You have two 4x10 black plates (piece 3030) where Bricklink and the instructions say you should have one 4x10 black plate and one 4x8 black plate. The 1x6 arch piece should be part 3455 rather than 92950. I had caught that last one, but uploaded the wrong file :) I have fixed the other issues, and have updated the files. As always, thanks for your help and corrections!
May 9, 201113 yr 1054 - Stena Line Ferry Year - 1999 Theme - Ferries LXF File Issues - Missing stickers and string. - Following pieces were left white, ferry window decorations aren't available for them: 3009p26, 3660px2 - Replaced part 2625 with 50303. - Replaced part 3040b with 3040 - Replaced part 73037 with 4209 and 4210. This last change was made to keep the set usable, and in the spirit of the design. Edited May 9, 201113 yr by moop2000
May 9, 201113 yr Just used LDD 4.1.7 to make 6890 Cosmic Cruiser from the Space theme: LXF File Errors: The correct decorations are unavailable for pieces 3004, 3010, 3839, and 76382. These pieces have been left blank. Parts 3943, 4081, and 4085 are all newer versions of those molds than those which appeared in the original set. Since they do have the correct part numbers, however, they are as correct as they can ever be unless LDD's data structure is changed to allow multiple part designs to share the same design ID. Other than that, no errors! It was fun building this, although it was far more boring a design than any of the Space sets from today or from my own childhood.
May 10, 201113 yr I thought I'd plug the holes in the Indiana Jones theme. 7199 The Temple of Doom (LDD 4.3.6 - Indiana Jones And The Temple Of Doom) LXF File ERRORS: Incorrect/missing prints 7197 Venice Canal Chase (LDD 4.3.6 - Indiana Jones And The Last Crusade) LXF File ERRORS: Incorrect/missing prints Collision error between parts 6587 and 3660 (p33) 7624 Jungle Duel (LDD 4.3.6 - Indiana Jones And The Kingdom Of The Crystal Skull) LXF File ERRORS: Replaced part tentiaj with brick-built solution Incorrect/missing prints 7626 Jungle Cutter (LDD 4.3.6 - Indiana Jones And The Kingdom Of The Crystal Skull) LXF File ERRORS: Replaced part 50945 with 50951 Incorrect/missing prints and stickers Part 2440 cannot connect to 4623 (p54) 7627 Temple Of The Crystal Skull (LDD 4.3.6 - Indiana Jones And The Kingdom Of The Crystal Skull) LXF File ERRORS: Replaced parts 51011 with 92409 and 51542 with brick-built solution Incorrect/missing prints and stickers Collision error between parts 92409 and 30413 (Book 1, p57) Collision error between parts 6587 and 30413 (Book 1, p57) Collision error between parts 3040 and 32557 (Book 2, p23) Collision error between parts 30176 and 4460 (Book 2, p45) Collision errors between part 2449 and replacement for part 51542 Edited July 24, 201311 yr by ADHO15
May 10, 201113 yr On 5/10/2011 at 3:39 PM, ADHO15 said: I thought I'd plug the holes in the Indiana Jones theme. 7197 Venice Canal Chase LXF File ERRORS: Incorrect/missing prints On the boat with the Brick Yellow deck, you have used one 2x2 45 degree inverse slope (3660) where you should have used two 1x2 45 degree inverse slopes (3665). I won't make you change this because I'm not sure about it, but I have for a long time had a sneaking suspicion that flags in sets after 2008 should use part 60779 (which is the newer of the two part numbers) rather than 2335. However, I never remember to check my own collection to verify this. You can maybe compare pre- and post-2008 sets from your own collection if it's not too much trouble-- 60779 has a slightly different clip shape than 2335. But I'm mainly saying this not because you need to change this but to ingrain it in my memory that I need to stop putting this verification off. Your model only has three Medium Stone Grey 1x1 round plates (6141). Bricklink and the instructions say there should be five. The missing two belong on the jumper plates on the back of the boat. Your model only has nine Dark Stone Grey 1x1 round plates (6141). Bricklink and the instructions say there should be 13. The missing four belong on the jumper plates on the back of the boat. Your model has 11 Bright Blue 1x1 round bricks (3062). According to Bricklink four of these should be Earth Blue. Quote 7199 Temple Of DoomLXF File ERRORS: Incorrect/missing prints The giant sword (60752) should be 131 Silver rather than 315 Silver Metallic. Your model has two Medium Stone Grey 1x2 Technic bricks with pin holes (3700) where it should have 1x2 Technic bricks with axle holes (32064). The dinosaur tails (40379) should be 294 Phosphorescent Green rather than 50 Phosphorescent White. I have a number of these in this color and can certify that it doesn't match other Phosphorescent White parts. However, it's made with a plastic other than polycarbonate, hence why it's not transparent but more of a milky color like the transparent portions of many BIONICLE weapon pieces. The 4x4 hinge plates (44570) can only be hinged at angles that are multiples of 22.5 degrees. You have them hinged at 15 degrees. Quote 7624 Jungle DuelLXF File ERRORS: Missing part tentiaj Incorrect/missing prints The Transparent Yellow 1x1 cone should be part 6188 rather than part 4589. The sword (3847) and frying pan (4528) should both be 131 Silver rather than 315 Silver Metallic. The four Medium Stone Grey 1x2 plates with vertical bar should be part 4623 rather than part 88072. 88072 actually made its debut this year, and so shouldn't appear in any older sets. Quote 7626 Jungle CutterLXF File ERRORS: Replaced part 62885 with 92738 Incorrect/missing prints and stickers The piston housing (53586) and exhaust pipes (61072) should be 131 Silver rather than 315 Silver Metallic. The 1x2 plates with slide (32028) should all be 194 Medium Stone Grey rather than 315 Silver Metallic. The flick-fire missile (entire construction of parts 61184, 6269, and 59900 in Medium Stone Grey) should be duplicated. Although the instructions are needlessly vague on this, the set's inventory on both Bricklink and the instructions calls for two, and there are two pictured in many of the official pictures. Again, the four Medium Stone Grey 1x2 plates with vertical bar should all be part 4623 rather than 88072. You have two of the wrench piece 55300 when the set only has one (used as a launcher for the flick-fire missile). Quote 7627 Temple Of The Crystal SkullLXF File ERRORS: Missing parts 40243 and 51542 Replaced part 62709PB01 with 64808 Incorrect/missing prints and stickers There is a white skull (3626) missing from your model. It should be on a Warm Gold jumper plate in the back of the model (on top of the hinged wall). Your model has a 1x4 Brick Yellow palisade brick (30137) where it should have a 1x4 Brick Yellow Technic brick (3701). Part 2587 should be 131 Silver rather than 315 Silver Metallic. Your model has only four Dark Green leaves (2423) when it should have six. Both of the missing ones should be attached to the front-left module of the temple. The hands of the two Ugha Warrior minifigures should be 192 Reddish Brown rather than 38 Dark Orange. Again, the Dark Stone Grey 1x2 plates with vertical bar should be part 4623 rather than part 88072. Also, this isn't an error, but it'd be really cool if you could float the sections of the temple to the heights they'd be at if they were on the baseplate. But it's not the most common baseplate, and I wouldn't be able to tell you how high that would make everything have to be, so unless you know that for yourself that'll have to wait until the baseplate is actually available. Great work on all these sets! Indiana Jones was a great theme, and I've really enjoyed the few sets from the theme that I've acquired over the years!
May 11, 201113 yr 1496 Rally Car Errors: Missing Decals Substituted parts: None, thanks to the older style hinged roof!
May 11, 201113 yr Damn! I really need to be more careful. On 5/10/2011 at 10:42 PM, Aanchir said: I won't make you change this because I'm not sure about it, but I have for a long time had a sneaking suspicion that flags in sets after 2008 should use part 60779 (which is the newer of the two part numbers) rather than 2335. However, I never remember to check my own collection to verify this. You can maybe compare pre- and post-2008 sets from your own collection if it's not too much trouble-- 60779 has a slightly different clip shape than 2335. But I'm mainly saying this not because you need to change this but to ingrain it in my memory that I need to stop putting this verification off. I changed it anyway since I was making other edits. I compared the parts from the Mos Espa Podrace, the Hoth Rebel Base and the Republic Dropship, but couldn't see any differences between the clips. The post-2008 dropship part clearly has a different texture and no circles or 'LEGO' markings on the clips, but I can't see any differences in shape or thickness. On 5/10/2011 at 10:42 PM, Aanchir said: [*]The dinosaur tails (40379) should be 294 Phosphorescent Green rather than 50 Phosphorescent White. I have a number of these in this color and can certify that it doesn't match other Phosphorescent White parts. However, it's made with a plastic other than polycarbonate, hence why it's not transparent but more of a milky color like the transparent portions of many BIONICLE weapon pieces. I saw that Bricklink calls the colour Glow in the Dark Opaque, which Peeron translates to Phosphorescent White. I've coloured them Phosphorescent Green per your request now. On 5/10/2011 at 10:42 PM, Aanchir said: Also, this isn't an error, but it'd be really cool if you could float the sections of the temple to the heights they'd be at if they were on the baseplate. But it's not the most common baseplate, and I wouldn't be able to tell you how high that would make everything have to be, so unless you know that for yourself that'll have to wait until the baseplate is actually available. I have now estimated their height based on the stairs at the back right of the temple and raised them to that height. On 5/10/2011 at 10:42 PM, Aanchir said: Great work on all these sets! Indiana Jones was a great theme, and I've really enjoyed the few sets from the theme that I've acquired over the years! Thank you very much, and again for checking them all. All corrections should now be made. Edited May 11, 201113 yr by ADHO15
May 14, 201113 yr 10040: Black Seas Barracuda - Theme: Pirates Bigger picture at http://www.imageupload.org/?d=21D292D51 Greetings from Australia I couldn't see it listed so I thought I'd give it a go, knowing that alot of pieces are missing from LDD. - Hull is using different pieces but managed to make it work, albiet with a bit of customisation. - Couldn't get strings to function like in real model, don't even know if this is possible. - Also Wing 4 x 4 Left and right are not in LDD so had to make a few changes there. - Several other missing parts that I can't remember - Not all minifigs included in final lxf file - Managed to get the chest suspended by the hook although the hook system is different as box parts aren't included in LDD - No sails - Probably a fair few tile colour inaccuracies - Decorations missing or incorrect on minfigs due to not being available in LDD - No decorations on flags 10040 Black Seas Barracuda.zipUnavailable Edited May 14, 201113 yr by Calabar
May 14, 201113 yr Author On 5/14/2011 at 5:42 AM, Myles said: ***Will not allow me to link to the jpg image file as it says I am not allowed to use that image extension. It's just a jpg.**** You have to find a file hosting service to host your image and your lxf files. Forum's attachment service is very limited and inadequate for this goal. Almost all here uses a brickshelf account, that allow to host both images and lxf files and use deeplink. Other alternatives are: a private web space, a generic file hosting (such as fileden, mediafire, adrive, ...), an image hosting for images (such as imageshack) and another solution for the lxf files, ... If you didn't that already, read the first page to see the topic's rules and look at other recent posts as reference. PS: if you don't include all minifigs, the set will be indexed as incomplete.
May 14, 201113 yr On 5/14/2011 at 7:51 AM, Calabar said: You have to find a file hosting service to host your image and your lxf files. Forum's attachment service is very limited and inadequate for this goal. Fixed, just used another image host site On 5/14/2011 at 7:51 AM, Calabar said: PS: if you don't include all minifigs, the set will be indexed as incomplete. That doesn't bother me at all, I just thought I'd share what I have done with everyone else, happy for someone to point out improvements etc, when I get around to it I may duplicate a few of the minifigs. The main reason I didn't is there is absolutely no pirate decorations what so ever and they would all look almost identical save a hat and clothing colour. Edited May 14, 201113 yr by Myles
