  • Replies 5k
Posted Images
6057 - Sea Serpent - Theme: Castle
- LDD doesn't allow the dragon wings and body (on figurehead) to attach to the central brick, I've put them right next to where they should be.
Please note you've used the wrong brick. It should be 4733
A good idea is to use the BrickLink or Peeron inventory catalogs to make sure you used the right bricks. In this case it doesn't matter however, because the dragon pieces won't fit in 4733 either (which is a good brick bug find).
EDIT: I suspect it should be 4733 in the mast too.
@bbqqq
I noticed you used an Anaglyph 3D image as a preview for your last sets.
As the great part of users has not the chance to see the image in 3D, I'd like you replace these images with standard screenshot.
You can insert the 3d images as extra, but only as text link.
Besides, for set 10143 (Death Star II), you should use a screenshot where the build is not "cut", but showed entirely.
Thanks ;)
Themes Star Wars (Ultimate Collector Series)
10143-1: Death Star II
(Duplicate, based on Yellost's model)
Thanks to Yellost, some part use his model.
lxf
Wow, great job on that one :thumbup:
I never thought anyone vould be crazy enough to tackle on that one. considering the pain I had when I made mine...
Edited by yellost
Thanks, you did many great job, too :thumbup: . Maybe next one is 10179 UCS Millennium Falcon :classic: .
7784 The Batmobile UCS - Theme: Batman
duplicate, base on AndyC :thumbup: 's model. My link add link
error: mod a bit to attach wings
AndyC wrote: "x1192 Technic, Axle Connector 2 x 3 with Ball Socket and Axle Socket missing from LDD"
LXF
LDDScreenShot99 by Nachapon S., on Flickr
Edited by bbqqq
7181-1: TIE Interceptor
There's not need to post an animated gif for this - please use a still shot. The animation you posted was rather annoying. I've removed the image tags; if you make a still shot, feel free to embed the image.
9488 Elite Clone Trooper And Commando Droid Battle Pack
ERRORS:
Missing ARC trooper kama and pauldron
Replaced part x281 with 30376, ARC trooper helmet with 61189, ARF Trooper helmet with 30369 and Commando Droid head with 30378
Incorrect/missing prints
elite clone trooper and commando droid battle pack.lxf
Edited by Calabar
Oversized image converted in text link.
Hi stark mark 5.
Thanks for your contribution. :classic:
But your post is irregular, you should read the rules of the topic in the first post and edit it!
More seasonal sets:
10079 Snowman - Theme: Seasonal Christmas
This is a re-issue of set 1979
10079 lxf
10080 Angel - Theme: Seasonal Christmas
This is a re-issue of set 1626
10080 lxf
10165 Elf Boy - Theme: Seasonal Christmas
10165 lxf
10166 Elf Girl - Theme: Seasonal Christmas
10166 lxf
Note: used custom bricks for faces in 10080, 10165 and 10166 (proper decorations are not in LDD)
EDIT: Amended for LDD 4.2.5/4.3.5: 10080, 10165 and 10166 now have correct bricks for faces, still not with correct decorations but best fitting ones.
Edited by Sjuip
Good work Sjuip and welcome!
Do you think to transfer your first models in your brickshelf account too?
Done. Had to get the knack of putting links in..
7903 - Rescue Helicopter - Theme: City
7903 lxf
Notes:
- No string, so Hook with Ball is added separately.
- Correct decorations on minifig faces. No decorations on minifig bodies (proper ones not available in LDD).
- LDD has a problem with attaching the rotorblades correctly (reported here: http://www.eurobricks.com/forum/index.php?showtopic=47953&view=findpost&p=1128266 ). In real life, just remove the purple bricks that are inserted in the blades.
EDIT: Amended for LDD 4.2.5/4.3.5. Rotorblade bug is now fixed - blades are correctly fitted.
Edited by Sjuip
5886 T-Rex Hunter
Theme - DINO
LXF here
Missing decals.
Missing prints for figs.
Guns have been improvised.
Not sure the correct name, but angled 4x2 plate not present in LDD and substituted.
Colors may or may not be right. Let me know please as I'm not sure which colors to use sometimes.
T-Rex not yet present in LDD and not substituted. :angry:
4431 Ambulance
Theme - CITY
LXF here
Missing decals.
Missing prints on figs.
Why not? ;)
You can add a custom version of the T-Rex, then report it here. If not, I have to index the entry as incomplete.
Your first contribution to this topic?
Good work, thanks! :classic:
Minor thing mods, shouldn't it be [KEY TOPIC] instead of [KET TOPIC] :grin:
Oops... Fixed!
Thanks
Shouldn't it be [KEY TOPIC] instead of [KEI TOPIC]? :wink::grin:
I have lots of sets updated and new ones built, but I never got round to uploading them. I should really post them sometime!
@ok13
I merged your topic with the right one: now your post is in the correct place.
Thanks. Hopefully I'll get it correct next time. :blush:
