6769 Fort LEGOredo - Theme: Western
That should be listed as 'duplicate'.
Thanks for the notice.
I saw there are two possible set's numbers for Fort LEGOredo: 6762 (your) and 6769 (AndyC's).
If the two version are substantially identical, I could correct the index adding both numbers.
  • Replies 5k
Posted Images
Well spotted chaps. Brickset suggests 6762 is just 6769 re-released and the Bricklink inventories don't have any blindingly obvious differences. I changed my post to number it 6762/6769 and marked it as a duplicate. I'd suggest we do that in the inventory too.
6928 Uranium Search Vehicle - Theme: Space - Classic - LXF File
Errors:
- Missing all prints.
Updated 2012/01/24:
- 4x 3004 Brick 1x2 replaced with correct 3065 Brick 1x2 without Pin.
- 2x 3010 Brick 1x4 replaced with correct 3066 Brick 1x4 without Pin.
- Set posed.
Edited by zinfinion
6925 Interplanetary Rover - Theme: Space - Futuron - LXF File
Errors:
- 4474 Cockpit cannot close when attached to 4625 Plate 1x4 Vertical Hinge since 4474 it is out of spec with respect to the physical part as reported here.
Updated 2012/01/24:
- 4474 Cockpit placed manually so that it now rests flush against cockpit wall. Does not attach to 4625 and does not hinge as a result. Original LXF file to compare the difference.
- Mini figure torsos corrected to white.
- Set posed.
Edited by zinfinion
7642 Garage - Theme: City
LXF File
Errors
Stickers/Prints
Part 4006 cannot be placed due to a collision error.
The chain cannot be attached.
The hook cannot be attached to the chain straight.
There is no rope.
The piston can't be attached to the arm of the Truck.
Edited by Costy
For all: I have checked my LXF contributions to this topic in the new LDD 4.2.5
Where needed, posts have been edited to indicate changes and bug fixes.
No new bugs encountered - all my LXFs should be 4.2.5-proof. :tongue:
Errors
Stickers/Prints
Costy,
Couldn't help noticing that your Garage employees are parolees: they have the body decoration that is normally used for prisoners (on white bodies). I would not buy a second hand car there :laugh: .
With the new version 4.2.5 of LDD, the correct minifig body for the blue bodied minifigs is there, though it is not visible in the Extended Mode Decoration Tool.
Switch to the regular LDD mode and search for "mini upper part". Check the blue coloured bodies: the required decoration with the orange stripes, breast pockets and white sweater is there! Simply pick it and switch back to Extended.
Edited by Sjuip
6879 Blizzard Baron - Theme: Space - Ice Planet 2002 - LXF File
Errors:
- 6120 Undercarriage 1x4 (Ski) fails to connect to 4275 Hinge Plate 1x2 1/2 as reported here. The hinges manage to get incredibly close, so for the most part, the model looks fine.
Updated 2012/01/24:
- 43989 Parabolic Reflector ⌀24x6.4 replaced with correct 3960 Round Plate ⌀32x6.4 as noted by Toa Of Justice.
- Mini figure legs corrected to black as noted by Toa Of Justice.
- Set posed.
Edited by zinfinion
5979 Max Security Transport - Theme: Space - Space Police III - LXF File
Errors:
- Missing all minifigure torso and leg prints. Missing all decals.
- 6141 Plate 1x1 Round will not attach to 61069 Design Shell w. Ribs. It can be manually placed in the proper position, but does not attach.
- 57028 Arrow 8M w/Soft Upper P. collides with 3069 Flat Tile 1x2 at the rear of 57796 Release Housing.
Edited by zinfinion
6881 Lunar Rocket Launcher - Theme: Space - Classic - LXF File
Errors:
- Missing x467c12/5102c12 Hose, Classic/Pneumatic 4mm⌀, 12L.
- 3324c01 Hinge Plate 2x9 replaced with 98285 / 98286 / 2780 / 87079 Hinge Plate 2x4 Bottom w. Pin Hole / Hinge Plate 2x4 Top w. Pin Hole / Connector Peg w. Friction / Flat Tile 2x4. Due to the set design, no offset was caused by this substitution.
- 122c01 Modified 2x2 Plate with Wheels replaced with 4600 / 4624 Bearing Element 2x2, Double / Rim Narrow w. Hole.
- 4288 Balloon Tires fail to attach to 4624 Rim Narrow w. Hole, but are in the correct position.
Notes:
- I actually prefer the new hinge assembly to the old, at least on this set, as it will not stick when fully lowered due to the flat tile, yet maintains the original set geometry.
Edited by zinfinion
2233 Fangz - Theme: Hero Factory
LXF File
The only error seems to be that Fangz's front toes can't be colored Silver Metallic. Also, for some reason the head won't rotate, but it is mounted correctly otherwise.
2232 Raw-Jaw - Theme: Hero Factory
LXF File
For some reason, I couldn't find Raw-Jaw's printed shell piece. I thought it was available in a previous version of LDD, but I might be wrong about that.
-Toa Of Justice
Edited by Toa_Of_Justice
6523 Red Cross - Theme: Town
LXF File
Car roof substituted for car roof with sunroof
6680 Ambulance - Theme: Town
LXF File
Vehicle hinge roof holder missing
Wheels substituted
6688 Ambulance - Theme: Town (Duplicate)
LXF File
Wheels substituted
6382 Fire Station - Theme: Town (Duplicate)
LXF File
Baseplate substituted
Wheels substituted
6643 Fire Chiefs Truck - Theme: Town
LXF File
#4084 Medium Tires missing (can't find a good substitute)
car roof substituted for car roof with sunroof
6650 Fire and Rescue Van - Theme: Town
LXF File
Wheels holder substituted
6384 Police Station - Theme: Town
LXF File
Wheels substituted
Rotor holders substituted
TV Aerial missing
Motorbike substituted
6681 Police Van - Theme: Town
LXF File
Edited by AndyC
3022 Plane of Hurrykain - Theme: Adventurers
LXF File
6062 Battering Ram - Theme: Castle
LXF File
6078 Royal Drawbridge - Theme: Castle
LXF File
Attenas don't fit under the arch pieces, left to the side
7188 King's Carriage Ambush - Theme: Castle (Duplicate)
LXF File
Horse headgear substituted
Unicorn horns left off
Spiders web missing
7946 King's Castle - Theme: Castle (Duplicate)
LXF File
Portcullis piece missing
7947 Prison Tower Rescue - Theme: Castle (Duplicate)
LXF File
10223 Kingdoms Joust - Theme: Castle (Duplicate)
LXF File
30161 The Batmobile - Theme: Licensed (DC Heroes) (Duplicate)
LXF File
21006 The White House - Theme: Architecture (Duplicate)
LXF File
Edited by AndyC
This is the kind of sets I love because date back to the period of my infantry!
But... do you want to leave some of that so incomplete? I even see missing tires that has not been replaced.
PS: have you got a list of inaccuracies? It could be useful to share it!
It's the 4084 tires that are missing from LDD that are missing from those vehicles. It's about 3 studs in diameter, as opposed to the 3641 tire that is in LDD that is about 2 studs in diameter. Both use the same size hub, and the equivalent 3 stud diameter 42611 tire in LDD uses a larger hub and looks rather odd when used on the old models.
I was confused as well, and did some serious sleuthing in LDD, which is how I know all of this now. :P
It's the 4084 tires that are missing from LDD that are missing from those vehicles. [...]
Oh I know! The first 6382 (Fire Station) was made by me. As the right tyres was missing, I replaced the whole system system (122c01+4084) with other quite similar elements (4600+50944+42611). :classic:
Hehe, you caught me mid sneaky editing. Descriptions of the errors are now inserted. I was planning to see if I could find a good replacement for the tires, the pieces you used in yours are ok so I may go with those unless I can scaffold something more accurate looking. In any case I figured I'd put these up now while I have a play around.
Edited by AndyC
6844 Seismologic Vehicle - Theme: Space - Classic - LXF File
_________________________________________________________________________
6871 Star Patrol Launcher - Theme: Space - Classic - LXF File
6826 Crater Crawler - Theme: Space - Classic - LXF File
1558 Mobile Command Trailer - Theme: Space - Classic - LXF File
Errors:
- 3838 Mini Oxygen Bottles wont snap onto stud, they collide with 2342 Console 1x2. Likely an illegal build, relying on the flexibility of the neck strap of the oxygen bottle.
6831 Message Decoder - Theme: Space - Space Police I - LXF File
Errors:
- 3957 Stick/Aerial is not attached to 4740 Satellite Dish. Used a temporary 85861 Round Plate 1x1 w. Hole to position.
1478 Mobile Satellite Up-Link - Theme: Space - M-Tron - LXF File
Errors affecting multiple sets:
Notes:
- I accidentally managed to get the 4288 Balloon Tires to slip over the 4624 Rim the other day and delighted with this discovery proceeded to build all remaining sets that feature this assembly. The trick is to raise the rim to the height of the tire, and then slip the tire over it. They don't attach, but they look correct, which is what counts most.
- 4288 / 4600 / 4624 Balloon Tire Template LXF File
Edited by zinfinion
2507 Fire Temple
Theme - Ninjago
download
Missing prints
Posible collision error, I couldn't get the 3 swords to go between the curved brick thingies
Dragon's legs won't rotate while attached to the body
