AndyC Posted February 3, 2012 Posted February 3, 2012 (edited) 10020 Santa Fe Super Chief - Theme: Trains (Duplicate) LXF File Spanner wouldn't go into clip inside train, so I put it in minifig's hand 10022 Santa Fe Cars Set 2 - Theme: Trains[Vers I] (Duplicate) LXF File 10022 Santa Fe Cars Set 2 - Theme: Trains[Vers II] (Duplicate) LXF File 10022 Santa Fe Cars Set 2 - Theme: Trains[Vers III] (Duplicate) LXF File 10025 Santa Fe Cars Set 1 - Theme: Trains[Vers I] (Duplicate) LXF File 10025 Santa Fe Cars Set 1 - Theme: Trains[Vers II] (Duplicate) LXF File 10170 TTX Intermodal Double-Stack Car - Theme: Trains (Duplicate) LXF File 9324 Micro Building - Theme: Dacta LXF File Small chain used in place of short string with studs 8077 Atlantis Exploration HQ - Theme: Atlantis (Duplicate) LXF File Edited February 3, 2012 by AndyC Quote
ADHO15 Posted February 3, 2012 Posted February 3, 2012 (edited) Updated 4488 MINI Millennium Falcon and 7778 Midi-Scale Millennium Falcon here. Edited February 3, 2012 by ADHO15 Quote
Calabar Posted February 3, 2012 Author Posted February 3, 2012 UPDATE I updated ALL my sets to LDD 4.2.5. Here is the list of the set updated from LDD 4 to LDD 4.2.5 - 6061 - Siege Tower - 6040 - Blacksmith Shop [Vers I] and [Vers II] - 6085 - Black Monarch's Castle - 6360 - Weekend Cottage Here you can find the list of sets updated from LDD 3 to LDD 4.2.5 You can download Here the complete ZipPack. Quote
Stephan Posted February 3, 2012 Posted February 3, 2012 Good afternoon, Why can't I use the "Insert image" thingie when I want to reply? It says: "You are not allowed to use that image extension on this board." I've got a few nice models which I want to share. Quote
Stephan Posted February 3, 2012 Posted February 3, 2012 (edited) Good afternoon, 396 Thatcher Perkins Locomotive - Theme: Hobby Set - LXF file Black & Transparent 7049b replaced with 4x Black 32064. Black 263 replaced with custom solution. Black 36 not in LDD. Black 132-old not in LDD. Black wheel2a replaced with Black 30155 and Copper 3749. Red x564 not in LDD. Red bb19 replaced with Red 30155 and Copper 3749. Red 35 replaced with Red 33211 and Copper 3749. Yellow x515 not in LDD. Custom pieces left to the side of the model. Two 2x2 Plates scaffolded in place (at the back) due illegal connection. 393 Norton Motorcycle - Theme: Hobby Set - LXF file Black 3700b replaced with Black 3700. Black 3634b replaced with Black 3634. Grey 3709a replaced with 4x Grey 3700. Grey 3475a replaced with Grey 3475. Red x148 replaced with Red 3713. Red g9 replaced with Red 30155. Custom pieces left to the side of the model and with the engine block, the 4x Grey Plate 2x2 couldn't be 'half-pressed' together. 394 Harley-Davidson 1000cc - Theme: Hobby Set - LXF file Black 3700b replaced with Black 3700. Black 3634b replaced with Black 3634. Grey 3709a replaced with 4x Grey 3700. Grey 3475a replaced with Grey 3475. Red x148 replaced with Red 3713. Red g9 replaced with Red 30155. Custom pieces left to the side of the model and with the engine block, the 4x Grey Plate 2x3 couldn't be 'half-pressed' together. The color for the axles is Nature White, but it shows as Transparent, so a 1x1 plate with the correct color left next to the model, axles colored White. 392 Formula 1 - Theme: Hobby Set - LXF file Black 3634b replaced with Black 3634. Grey 3709a replaced with 4x Grey 3700. Red x148 replaced with Red 3713. Red g9 replaced with Red 30155. Yellow 3475a replaced with Yellow 3475. The color for the axles is Nature White, but it shows as Transparent, so a 1x1 plate with the correct color left next to the model, axles colored White. 391 1926 Renault - Theme: Hobby Set - LXF file Black & Transparent 7049b replaced with 4x Black 32064. Black 36 not in LDD. White 35 replaced with White 33211 and Copper 3749. Custom pieces left to the side of the model. 390 1913 Cadillac - Theme: Hobby Set - LXF file Black & Transparent 7049b replaced with 4x Black 32064. Black 36 not in LDD. Red 35 replaced with Red 33211 and Copper 3749. Yellow 39 replaced with Yellow 4070. Custom pieces left to the side of the model. 395 1909 Rolls-Roys - Theme: Hobby Set - LXF file Black & Transparent 7049b replaced with 4x Black 32064. Black 36 not in LDD. Red x148 replaced with Red 3713. White 35 replaced with White 33211 and Copper 3749. Yellow 39 replaced with Yellow 4070. Custom pieces left to the side of the model. The color for the axle is Nature White, but it shows as Transparent, so a 1x1 plate with the correct color left next to the model, axle colored White. 8649 Nitro Menace - Theme: Racers; Power Racers - LXF file Black 44771 not in LDD. Dark Stone Grey 32195b replaced with custom solution. Silver Flip/Flop 78c05 not in LDD, replaced with custom solution, not bendable so left next to the model. Silver Flip/Flop 78c09 not in LDD, replaced with custom solution, not bendable so left next to the model. Silver Flip/Flop 32200 not bendable, left next to the model. Silver Flip/Flop 32235 not in LDD, replaced with Silver Flip/Flop 57539. Bright Yellowish Green 32199 difficult to place because the Bright Yellowish Green Flex Axle 14L is not bendable. Bright Yellowish Green 32201 not bendable, left next to the model. Bright Yellowish Green 44350 not in LDD. Bright Yellowish Green 44351 not in LDD. Metallic Dark Grey 44350 not in LDD, replaced with smaller panel. Metallic Dark Grey 44351 not in LDD, replaced with smaller panel. Silver 46452 not in LDD, replaced with a custom solution. This set uses also some illegal building technique: Dark Stone Grey 32002 replaced with Dark Stone Grey 4274. The issue with Black 32138 replaced with custom solution. Custom pieces and replacements left to the side of the model. 8146 Nitro Muscle - Theme: Racers; Power Racers - LXF file Black 32195b replaced with custom solution. Black x1825 not in LDD. Silver Metallic 78c11 not bendable, left next to the model. Silver 46453 not in LDD, replaced with custom solution. Red 32235 not in LDD, replaced with Red 57539. Red 44350 not in LDD. Red 44351 not in LDD. Medium Stone Grey 32013 and Blue 43093 could not be placed due some kind of collision. And for all models: no stickers Greetings :) Edited May 5, 2014 by Stephan Quote
Calabar Posted February 3, 2012 Author Posted February 3, 2012 Good afternoon, [...] Did you read my private messages? Quote
Stephan Posted February 3, 2012 Posted February 3, 2012 (edited) Did you read my private messages? Yes, I did. I'm about to upload the new, good pictures now. If any other things I'm doing wrong please tell me :) Btw how can I do those white backgrounds instead of the grey ones? Edited February 3, 2012 by Stephan Quote
zinfinion Posted February 3, 2012 Posted February 3, 2012 (edited) 6898 Ice-Sat V - Theme: Space - Ice Planet 2002 - LXF File Errors: - 4504 Hinge Plate 1x6 with 2 and 3 Fingers On Ends replaced with 4275 / 4276 / 3023. - 3149c01 Hinge Plate 2x5 replaced with 98285 / 98286 / 2780 / 2x 63864 Hinge Plate 2x4 Bottom w. Pin Hole / Hinge Plate 2x4 Top w. Pin Hole / Connector Peg w. Friction / 2x Flat Tile 1x3. - The design of the new bottom hinge plate causes a color mismatch at the hinge joint. _________________________________________________________________________ 6973 Deep Freeze Defender - Theme: Space - Ice Planet 2002 - LXF File Errors: - 2731 Technic Figure Accessory Ski replaced with 2x 2431 / 3070 / 50746 / 3023. _________________________________________________________________________ Errors affecting multiple sets: - Missing all prints. - 2607 Magnet Holder 2x3 replaced with 6541 Technic Brick 1x1 / 2x 50746 Roof Tile 1x1x2/3 / 2x 3070 Flat Tile 1x1. - 2609 Magnet Holder Tile 2x2 replaced with 3068 Flat Tile 2x2. Edited February 4, 2012 by zinfinion Quote
zinfinion Posted February 3, 2012 Posted February 3, 2012 (edited) 4206 Recycling Truck - Theme: City - LXF File Errors: - Missing some prints. Missing all decals. Edited February 4, 2012 by zinfinion Quote
mred Posted February 4, 2012 Posted February 4, 2012 (edited) 4514 - Cargo Crane - Theme: World City As far as I could tell, my only problems are some of the colours have been replaced, and the decals/minifigure faces are not available. Here is the lxf file: 4514.lxf Edit: Have fixed the colours, and refreshed the thumbnail and the lxf file Thanks Calabar for your help Edited February 4, 2012 by mred Quote
Calabar Posted February 4, 2012 Author Posted February 4, 2012 4514 - Cargo Crane - Theme: World City As far as I could tell, my only problems are some of the colours have been replaced, and the decals/minifigure faces are not available. Hi! I'm wondering about the colours you told has been replaced. Extended Mode allows to apply almost all colours to all available bricks (even in never combinations never realized in real bricks), so this problem should not happen. Could you explain with more detail? Quote
mred Posted February 4, 2012 Posted February 4, 2012 Hi! I'm wondering about the colours you told has been replaced. Extended Mode allows to apply almost all colours to all available bricks (even in never combinations never realized in real bricks), so this problem should not happen. Could you explain with more detail? I think I probably got some of the colours a little mixed, as I was building from instructions that were far from clear. Therefore some of the colours may be wrong. It should be close though. I've probably modernized the colours a bit, using medium stone grey instead of old grey, etc. I'm not completely sure what the right colours are:wacko:, so if someone sets me straight I can fix it Quote
Calabar Posted February 4, 2012 Author Posted February 4, 2012 I think I probably got some of the colours a little mixed, as I was building from instructions that were far from clear. Therefore some of the colours may be wrong. Ok, I understand the problem! The solution in simple: you have to refer to an inventory such as those that provided from bricklink or peeron. As bricklink, peeron and lego uses different names for the colours, you should look at a conversion table, such as peeron color list. More informations in the "LDD reference" Topic. Replace the colours is simple too: the Color Selection Tool allow you to select all the bricks of the same colour and then recolour that using the bucket. Quote
mred Posted February 4, 2012 Posted February 4, 2012 Ok, I understand the problem! The solution in simple: you have to refer to an inventory such as those that provided from bricklink or peeron. As bricklink, peeron and lego uses different names for the colours, you should look at a conversion table, such as peeron color list. More informations in the "LDD reference" Topic. Replace the colours is simple too: the Color Selection Tool allow you to select all the bricks of the same colour and then recolour that using the bucket. Ahh, of course, a simple solution! Thanks for your help, it's all fixed Quote
Sjuip Posted February 4, 2012 Posted February 4, 2012 (edited) 4549 - Container Double Stack - Theme: Trains [bricklink] [brickset] [Peeron] 4549 LXF Notes: - Missing decoration (red&white chevrons) on Blue minifig bodies and on White Tiles 1x2 - Red Wedge Plate 3x4 (4859) on truck replaced with similar Wedge (48183) with stud notches - Addition of a black Plate Round 2x2 (4032) to the back of the truck and modifications to the front of the trailer to enable replacement of Plate 2x5 with Towball Socket (3491, missing in LDD) by Plate 1x4 with Reversed Hook (30043). - Winch 2x3x2 (73037) not in LDD. Replaced with custom Winch (credits to Calabar) - Technic Plate 1x6 (4262) not in LDD. Replaced with Technic 6M Half Beam (32063) - Telescope Lever (2351) placed next to crane, as it will not fit inside Telescope Bottom (2350). This problem is reported here. - Container Grab (2348) and Container Grab Grip (2649) missing from LDD. No replacement. - No stickers, no string. - All objects (cars, containers) grouped sparately in the LXF. EDIT: Telecope Lever 2351 and Winch 73037 corrected with LDD 4.3.6 4549 - Container Double Stack - Theme: Trains [MODIFIED] Image 4549 Mod LXF Note: - Modified version of the 4549 Set above: Crane Truck modified with modern Telescope Arm copied from Set 7992 Edited March 9, 2013 by Sjuip Image of the modified model converted in text link Quote
Sjuip Posted February 4, 2012 Posted February 4, 2012 7992 - Container Stacker - Theme: City [bricklink] [brickset] [Peeron] 7992 LXF Built from instructions with bricks and colours checked against TLG site - no issues. Quote
Sjuip Posted February 4, 2012 Posted February 4, 2012 7820 - Mail Van - Theme: Trains [bricklink] [brickset] [Peeron] Version 1 7820 Version 1 Version 2 7820 Version 2 Notes: - Different decoration on Blue minifig - Wheels substituted (credits AndyC) Quote
Sjuip Posted February 4, 2012 Posted February 4, 2012 (edited) 2126 - Train Cars - Theme: Trains [bricklink] [brickset] [Peeron] 2126 LXF Notes: Built from instructions. Objects grouped in the LXF. Minifigs - different decoration on minifig faces. - different or missing decorations (best fitting replacements) on minifig bodies. Barrel Car - different decorations on Slope Bricks Black 2x2 (3039) and Grey 1x2 (3040). - Black Round Dishes (3960) do not fit on Brown Barrels (30139) (scaffolded). Dump Truck - Black Hinge Plate 2x9 (3324) not in LDD, replaced with custom build construction with Hinge 3937/3938. - Grey Hinge Vehicle Roof Holder 1x4x2 (4214) not in LDD, replaced with custom build construction. - Tyre 4084 not in LDD, replaced with smaller tyre 3641. Hopper Car - Missing Decorations on Black Tiles 1x2. Rail Car - Different decoration (control panel) on White Tile 1x2. Auto Wagon - Red/White Vehicle Mudguard 3 x 4 Slope (2513) not in LDD, replaced with custom build car hoods. - Different decoration (danger stripes) on White Tiles 1x4. EDIT: Dishes 3960 corrected with LDD 4.3.6 EDIT: Roof Holder 4214 and Tyres 4084 corrected with LDD 4.3.8 BV 1564 Edited October 16, 2014 by Sjuip Quote
zinfinion Posted February 5, 2012 Posted February 5, 2012 6983 Ice Station Odyssey - Theme: Space - Ice Planet 2002 - LXF File Errors: Base: - 2552 Ice Pattern Raised Baseplate 32x32 with Ramp and Pit replaced with a new brickbuilt version. Details and template. - 2748 Baseplate 16x32 replaced by 2x 91405 Plate 16x16 to keep the same thickness as the other baseplate. - Antenna hinge assembly shifted 2 LDU away from the ramp wall to prevent collision of the Plate 1x1 Round. - 2426 Technic Rack Winder replaced with 4x 3023 / 2x 3700 / 3710 / 2x 3024 / 32073 / 2x 32123. - 2428 Technic Rack 1 x 20 x 2/3 replaced with 5x 3743 Toothed Bar. - 2x 3597 / 3315 Hinge Plate 2x4 - Female / Hinge Plate 2x4 - Male (Digger Bucket Holder) replaced with 3022 / 3069 / 2x 2555 / 48336 / 3021 / Plate 2x2 / Flat Tile 1x2 / Plate 1x1 w. Upright Holder / Plate 1x2 w. Shaft ⌀3.2 / Plate 2x3. - 2x 3149c01 Hinge Plate 2x5 replaced with 98285 / 98286 / 2780 / Hinge Plate 2x4 Bottom w. Pin Hole / Hinge Plate 2x4 Top w. Pin Hole / Connector Peg w. Friction. - 2607 Magnet Holder 2x3 replaced with 6541 / 2x 50746 / 2x 3070 / Technic Brick 1x1 / Roof Tile 1x1x2/3 / Flat Tile 1x1. - 2609 Magnet Holder Tile 2x2 replaced with 3068 Flat Tile 2x2. Rocket Carrier: - 3149c01 Hinge Plate 2x5 replaced with 98285 / 98286 / 2780 / 2x 63864 / Hinge Plate 2x4 Bottom w. Pin Hole / Hinge Plate 2x4 Top w. Pin Hole / Connector Peg w. Friction / Flat Tile 1x3. Sled: - 2731 Technic Figure Accessory Ski replaced with 2x 2431 / 3070 / 50746 / 3023. - 2880 Hinge Bar 2.5L with 2 and 3 Fingers on Ends replaced with 87994 Shaft 3M ⌀3.2. Notes: This completes Ice Planet 2002! Quote
peterski Posted February 5, 2012 Posted February 5, 2012 (edited) 9395 - Pick-up Tow Truck - Theme: Technic sorry I have only 100k upload quota and 4.21k remains. Could anyone who can help me expand more space? thanks LXF file: 9395.lxf The set is almost perfect except lacking a black string and a few parts can not be placed on its proper position. Edited February 5, 2012 by peterski Quote
Calabar Posted February 5, 2012 Author Posted February 5, 2012 sorry I have only 100k upload quota and 4.21k remains. Could anyone who can help me expand more space? thanks The best way to share your images and lxf file is to use an external file hosting that allows hotlinks. The most used here is brickshelf: you can make a free account and than hotlink both images and lxf file. Quote
peterski Posted February 5, 2012 Posted February 5, 2012 The best way to share your images and lxf file is to use an external file hosting that allows hotlinks. The most used here is brickshelf: you can make a free account and than hotlink both images and lxf file. Yes, Just have done. Thanks Quote
Calabar Posted February 5, 2012 Author Posted February 5, 2012 Yes, Just have done. Thanks You're welcome. I have to ask you another thing. The image you inserted is too big and need to be resized. The image have to stay inside a 512x512 pixel. Besides, the set's data have to be highlighted in bold. You can find all the rules of the topic in the first post. Quote
AndyC Posted February 5, 2012 Posted February 5, 2012 6403 Paradise Playground - Theme: Paradisa LXF File 6x6 Container substituted 6404 Carriage Ride - Theme: Paradisa LXF File Hinged version of the horse hitch substituted 6409 Island Arcade - Theme: Paradisa LXF File 6419 Rolling Acres Ranch - Theme: Paradisa LXF File Hinged bucket substituted Baseplate substituted Bracket pieces omitted, no good substitute 6356 Med-Star Rescue Plane - Theme: Town LXF File 6380 Emergency Treatment Centre - Theme: Town LXF File Baseplate substituted 1x4x5 windows substituted Car roof with sunroof substituted 6666 Ambulance - Theme: Town LXF File Car roof with sunroof substituted Window panels substituted Quote
Aanchir Posted February 6, 2012 Posted February 6, 2012 (edited) 6403 Paradise Playground - Theme: Paradisa LXF File 6x6 Container substituted 6404 Carriage Ride - Theme: Paradisa LXF File Hinged version of the horse hitch substituted 6409 Island Arcade - Theme: Paradisa LXF File 6419 Rolling Acres Ranch - Theme: Paradisa LXF File Hinged bucket substituted Baseplate substituted Bracket pieces omitted, no good substitute The pink parts in these Paradisa sets should be colored 9 Light Reddish Violet. 223 Light Pink is, as its number suggests, a far more recent color. To be perfectly honest I have never seen it in actual bricks and so don't know if it has a Bricklink counterpart, but I have seen it on LEGO licensed shoes and other products along with more familiar LEGO colors like Bright Reddish Violet (Bricklink's Magenta), Light Purple (Bricklink's Bright Pink), and Bright Purple (Bricklink's Dark Pink in post-2004 sets). The dark pink seats in "Carriage Ride" should also be colored 22 Medium Reddish Violet rather than 221 Bright Purple. In general the cutoff point between these two colors, like so many color changes that elicited greater controversy, was 2004. The ponytails in the first set are also incorrect, being the one from the Minifigures Series 1 nurse (87990) rather than the "classic" ponytail (6093). Edited February 6, 2012 by Aanchir Quote
