obsidianheart Posted February 11, 2012 Posted February 11, 2012 (edited) Aside: Superkalle, that link doesn't seem to work for me, what's behind it? This is the updated file with substitutions by Calabar! 8637 - Agents: Mission 8: Volcano Base LDD File - Direct Link Errors: - Missing Prints and Stickers, substitutions made on minifigures, - Parts 78c07 Metallic Silver Hose, Ribbed 7mm D. 7L / 5.6cm (x2) unavailable, unable to find suitable replacement or a way to fake it, these parts were omitted. Calabar found a workaround for the substitutions. - Part 78c11 Metallic Silver Hose, Ribbed 7mm D. 11L does not flex. Longer flex tube actually flexes, original part set aside behind model. - Parts 75c25 Dark Blue Hose, Rigid 3mm D. 25L / 20.0cm (x2) do not flex. Calabar also found a neat workaround for this! - Marbled pattern for Parts 47847pb02U Trans-Neon Orange Rock Panel 2 x 4 x 6 with Marbled Dark Bluish Gray (x2) unavailable, so I left them trans-neon orange. Edited February 14, 2012 by obsidianheart Added Direct Link for the lxf file. Quote
Calabar Posted February 11, 2012 Author Posted February 11, 2012 Aside: Superkalle, that link doesn't seem to work for me, what's behind it? The site where the image is taken don't allow hotlinks. To see the image, copi the url directly in the address bar of your browser and press enter. Quote
zinfinion Posted February 11, 2012 Posted February 11, 2012 (edited) I received confirmation from @Kadabra, who reviewed Cole's Tread Assault, that the wings are indeed all in click at 90 and 67.5 degrees when folded tight to the vehicle. I also took a look at and they do appear to all go in click. There is quite a lot of play in all the Technic beams and pins, which LDD obviously can't replicate, so that clears up the mystery.Next time I'll look before I leap and save everyone some confusion. Edited February 11, 2012 by zinfinion Quote
Sjuip Posted February 12, 2012 Posted February 12, 2012 (edited) 4552 - Cargo Crane - Theme: Trains [bricklink] [brickset] [Peeron] 4552 LXF Notes: - Different decorations for minifig torsos - Different decoration for White Tile 1x2 (telemetry) - No string for welding set Nozzle (194cx1) nor for Crane - Technic Plates with Toothed Ends 1x4 and 1x6 (4263 & 4262) not in LDD. Replacements: (1) on Crane Wagon by construction from Crane Wagon from Set 7898 (LXF) using Technic Rotor 32124; (2) on Crane by Plate 1x6 (3666) and by Technic Half Beam 6M (32063). - Brick 2x6x2 with Weight (73090) not in LDD. Replaced by two Bricks 2x6. - Winch 2x3x2 (73037) not in LDD. Replaced with custom Winch (credits to Calabar ) - Hinge Vehicle Roof Holder 1x4x2 (4214) not in LDD, replaced with custom build construction. - Hinge Vehicle Sunroof 4x4 (2349) and Sunroof Glass (2348) not in LDD. Replaced with Hinge Roof 4x4 (4213). - Plate 1x2 with Hook (3127) not in LDD. Replaced by Hook with Ball (30395). EDIT: Winch 73037 corrected with LDD 4.3.6. EDIT2: Sunroof 2349 and Glass 2348 corrected with LDD 4.3.6 Brickversion 1128. EDIT3: Counterweight 73090/73843 corrected with LDD 4.3.8/1264. EDIT4: Roof Holder 4214 corrected with LDD 4.3.8/1564. Edited October 16, 2014 by Sjuip Quote
Sjuip Posted February 12, 2012 Posted February 12, 2012 (edited) 4541 - Rail and Road Service Truck - Theme: Trains [bricklink] [brickset] [Peeron] 4541 LXF Notes: - Different decorations for minifig torsos and faces. - Different decoration for White Tiles 1x2 (telemetry, controls). - Bracket 2x2-1x4 (2422) not in LDD. Replaced by Plate 2x2 Angle (3956). - Hinge Vehicle Roof Holder 1x4x2 (4214) not in LDD, replaced with custom build construction. - Hinge Vehicle Sunroof 4x4 (2349) and Sunroof Glass (2348) not in LDD. Replaced with Hinge Roof 4x4 (4213). - Tyre 4084 not in LDD. Wheels replaced by Rims 6014 with Tyres 6015. EDIT: Sunroof 2349 and Glass 2348 corrected with LDD 4.3.6 Brickversion 1128. EDIT2: Bracket 2422 corrected with LDD 4.3.8/1264 EDIT3: Roof Holder 4214 and Tyres 4084 corrected with LDD 4.3.8/1564 Edited October 16, 2014 by Sjuip Quote
Sjuip Posted February 12, 2012 Posted February 12, 2012 (edited) 4557 - Freight Loading Station - Theme: Trains [bricklink] [brickset] [Peeron] 4557 LXF Notes: - Different decorations for minifig torsos and faces. - Missing decorations for Triangular (892) and Octogonal (890) Roadsigns and on Container Box Door (4346). - No string for Crane. - Hinge Vehicle Roof Holder 1x4x2 (4214) not in LDD, replaced with custom build construction. - Hinge Vehicle Sunroof 4x4 (2349) and Sunroof Glass (2348) not in LDD. Replaced with Hinge Roof 4x4 (4213). - Plate 1x2 with Hook (3127) not in LDD. Replaced by Hook with Ball (30395). EDIT: Sunroof 2349 and Glass 2348 corrected with LDD 4.3.6 Brickversion 1128. EDIT2: Roof Holder 4214 corrected with LDD 4.3.8 Brickversion 1564. Edited October 16, 2014 by Sjuip Quote
Calabar Posted February 12, 2012 Author Posted February 12, 2012 8637 - Mission 8: Volcano Base1) Parts 78c07 Metallic Silver Hose, Ribbed 7mm D. 7L / 5.6cm (x2) unavailable, unable to find suitable replacement or a way to fake it, these parts were omitted. 2) Part 78c11 Metallic Silver Hose, Ribbed 7mm D. 11L does not flex. I'm, uh, not even sure I used the right one in the model. 3) Parts 75c25 Dark Blue Hose, Rigid 3mm D. 25L / 20.0cm (x2) do not flex. Again, I'm not sure I used the right ones, but none that flexed were long enough. 1) you can replace it with 4x 72504, connecting that with an axle and not with technic pins. Tested and working perfectly. 2) It seems the right piece, but... don't flex! Only the longer 72039 seems able to flex. 3) You could try with the only flexible hose, the 76270. If necessary, "sum" it to the shorter 55668 to reach the length. The one you choose should not be the right one, 184 mm vs 200 mm. There is a brick missing in the propeller system of the copter. Look here to the file with some improvements, including groups! Quote
zinfinion Posted February 12, 2012 Posted February 12, 2012 (edited) 4916 Mini Animals [Version I] - Theme: Creator - LXF File 4916 Mini Animals [Version II] - Theme: Creator - LXF File 4916 Mini Animals [Version III] - Theme: Creator - LXF File ______________________________________________________ 4917 Mini Robots [Version I] - Theme: Creator - LXF File 4917 Mini Robots [Version II] - Theme: Creator - LXF File 4917 Mini Robots [Version III] - Theme: Creator - LXF File ______________________________________________________ 5761 Mini Digger [Version I] - Theme: Creator - LXF File 5761 Mini Digger [Version II] - Theme: Creator - LXF File 5761 Mini Digger [Version III] - Theme: Creator - LXF File ______________________________________________________ 5762 Mini Plane [Version I] - Theme: Creator - LXF File 5762 Mini Plane [Version II] - Theme: Creator - LXF File 5762 Mini Plane [Version III] - Theme: Creator - LXF File ______________________________________________________ 5864 Mini Helicopter [Version I] - Theme: Creator - LXF File 5864 Mini Helicopter [Version II] - Theme: Creator - LXF File 5864 Mini Helicopter [Version III] - Theme: Creator - LXF File ______________________________________________________ 6910 Mini Sports Car [Version I] - Theme: Creator - LXF File 6910 Mini Sports Car [Version II] - Theme: Creator - LXF File 6910 Mini Sports Car [Version III] - Theme: Creator - LXF File ______________________________________________________ 6911 Mini Fire Truck [Version I] - Theme: Creator - LXF File 6911 Mini Fire Truck [Version II] - Theme: Creator - LXF File 6911 Mini Fire Truck [Version III] - Theme: Creator - LXF File Edited February 13, 2012 by zinfinion Quote
Sjuip Posted February 12, 2012 Posted February 12, 2012 (edited) 4556 - Train Station - Theme: Trains [bricklink] [brickset] [Peeron] 4556 LXF Notes: - Different decorations on minifig faces. - Different or missing decorations on minifig torsos. - Different decoration on Tile 2x2 (gauges). - Missing decoration on Container Box Door 4346 (mail) and on Tile 1x2 (arrow). - LDD does not allow Brick 1x1 with Four Studs (4733) to fit on Tile 2x2 with Pin (2460), probably due to illegal method. Problem has been reported here. Therefore Tile with Pin is replaced by Plate 2x2 with 1 Stud (87580). - Window 1x4x6 (6160) not in LDD. Replaced with Window 1x4x6 Frame with 3 Panes (57894) with Glass 57895. But maybe even more important: this thread now contains the LXFs of all TRAINS sets from 1998 to the present day (and all except one from 1993-2011 ...) Edit: problem with turnstile solved with help from Zinfinion and Superkalle. Edited February 12, 2012 by Sjuip Quote
obsidianheart Posted February 13, 2012 Posted February 13, 2012 (edited) 1) you can replace it with 4x 72504, connecting that with an axle and not with technic pins. Tested and working perfectly. 2) It seems the right piece, but... don't flex! Only the longer 72039 seems able to flex. 3) You could try with the only flexible hose, the 76270. If necessary, "sum" it to the shorter 55668 to reach the length. The one you choose should not be the right one, 184 mm vs 200 mm. There is a brick missing in the propeller system of the copter. Oops, I knew about the missing bricks and forgot to add them in the error list. Sorry about that. How did you get them to stay in there? I tried for a bit, but had no luck. Also, I tried 4 72504s, but I used pins, so it didn't work. Never thought to use an axle. Thank you for the updated version, now I can re-add the modifications I made to it and place it back into my diorama file. Edit: Whoa, I got a yellow brick there under my stats. Thanks! Edited February 13, 2012 by obsidianheart Quote
Calabar Posted February 13, 2012 Author Posted February 13, 2012 @obsidianheart Placing the brick in the copter system was easy using a simple scaffolding. Flex the Hoses around the copter propellers was another kettle of fish! Post a notice here when you'll update your post above. Quote
Venari Posted February 13, 2012 Posted February 13, 2012 (edited) First post, just for fun. 2509 - Earth Dragon Defense - Theme: Ninjago Shame that the sticker graphics and Ninjago dragonhead/minifig graphics are not available... but it's all correct without spares shown. Earth Dragon is a fun set too, with his sturdy whiplash tail. I'm afraid we had to collect all the dragons once we'd bought the Ice Dragon (already modelled.) While Fire and Lightning are fine specimens with big wings, Earth dragon has attitude! 2509-Dragon.lxf Enjoy! Ven. Edited February 16, 2012 by Venari Quote
obsidianheart Posted February 14, 2012 Posted February 14, 2012 I've updated the Agents set with Calabar's super additions. And I have another that I didn't see in the index. 8960 Power Miners: Thunder Driller LDD File Errors: -Missing prints and stickers, I didn't make substitutions this time. (I think that's it, actually, let me know if I missed something else.) Quote
Calabar Posted February 14, 2012 Author Posted February 14, 2012 (edited) 6889 - Recon Robot Theme: Space > Spyrius [Brickset] [Peeron] [BrickLink] Download (LDD 4.2.5): - Direct link HERE. - More on my BrickShelf Gallery HERE. - Visual Gallery HERE. - Get the ZipPacks from HERE. Known Inaccuracies: - Hinge Bar (2880) replaced with Steering Lever (2433) - Wall Element with solid studs (4864a) replaced with Wall element with hollow studs (4864b) - Wall Element with solid studs (2362a) replaced with Wall element with hollow studs (2362b) - I used minifig head with hollow stud (3626b) instead than old type (3626a) - Many decorations missing, replaced if possible. Comments: A little entry for the spyrius subtheme. A good set, I like it more than its bigger brother 6949. Edited January 22, 2016 by Calabar Quote
Sjuip Posted February 14, 2012 Posted February 14, 2012 It took some creative LDD building, this monster , but finally here it is! 4957 - Ferris Wheel - Theme: Creator [bricklink] [brickset] [Peeron] 4957 Version 1 LXF Notes: - No issues with bricks, colours, decorations or adhesives!! Only the two White Rubber V-Belts (70902) are placed separately. - Major fault: I could not get the supporting frame to link up with the ground plate. The supposed angles of the beams are outside LDD tolerances . Therefore, the linking axles in the bottom ends are not connected (the frame and wheel 'float' above the ground plate). The model is built from instructions. I do not own the set, so I do not know how much strain the beams of the supporting frame are under in the actual model. - If anybody can get the frame to link up: let me know! Quote
zinfinion Posted February 15, 2012 Posted February 15, 2012 It took some creative LDD building, this monster , but finally here it is! Errors: Missing Moveable Drawbridge [Version II] and Building Crane [Version III] I'll stick to Creator Minis. Quote
Calabar Posted February 15, 2012 Author Posted February 15, 2012 @Venari Good entry for a first work with LDD! The post is good too, the only thing I could ask you to improve is to crop the blank horizontal stripes in the image. @obsidianheart About decorations, I ever prefer a replacement is found, if possible. Especially for minifigures' faces, that without decorations seems really incomplete. Quote
zinfinion Posted February 16, 2012 Posted February 16, 2012 (edited) 6912 Super Soarer [Version I] - Theme: Creator - LXF File 6912 Super Soarer [Version II] - Theme: Creator - LXF File 6912 Super Soarer [Version III] - Theme: Creator - LXF File _________________________________________________________________________ 7292 Propeller Adventures [Version I] - Theme: Creator - LXF File Errors: - Replaced 2x 3022 Plate 2x2 with 2x 3023 Plate 1x2 in the turbines due to collisions. 7292 Propeller Adventures [Version II] - Theme: Creator - LXF File 7292 Propeller Adventures [Version III] - Theme: Creator - LXF File Edited June 12, 2012 by Calabar Fixed 6912 set's number Quote
Venari Posted February 16, 2012 Posted February 16, 2012 @Venari Good entry for a first work with LDD! The post is good too, the only thing I could ask you to improve is to crop the blank horizontal stripes in the image. I think I understand - the whitespace at the top and bottom has now been removed. V. Quote
zinfinion Posted February 16, 2012 Posted February 16, 2012 (edited) 7291 Street Rebel [Version I] - Theme: Creator - LXF File Errors: - Omitted 2x 85543 V-Belt Ø15. 7291 Street Rebel [Version II] - Theme: Creator - LXF File Errors: - 62462 Tube w/Double Ø4.85 doesn't attach to 4081 Lamp Holder. Positioned manually. 7291 Street Rebel [Version III] - Theme: Creator - LXF File Errors: - Replaced 2x 87087 Brick 1x1 w. 1 Knob with 2x 3005 Brick 1x1. 62462 Tube w/Double Ø4.85 doesn't attach to 87087 Brick 1x1 w. 1 Knob. Positioned manually. - Replaced 32316 Technic 5M Beam with 2x 32017 Technic 5M Half Beam due to 32316 Technic 5M Beam not snapping to the middle of 32054 2M Friction Snap w/ Cross Hole. Edited February 17, 2012 by zinfinion Quote
Stephan Posted February 17, 2012 Posted February 17, 2012 (edited) Good afternoon, 3826 Build-A-Bob - Theme: SpongeBob SquarePants - LXF file [Brickset][Bricklink][Peeron] Errors: Blue x89 Rubber Belt Large (Round Cross Section) - Approx. 4 x 4 not included because it's not bendable. Dark Bluish Gray 41753 Rubber Band / Belt Holder 2 x 6 x 2 1/3 not in LDD (and also not really necessary). Yellow 47431 Technic, Brick Modified 2 x 2 with Axle Hole, Rotation Joint Ball Half (Vertical Side), Vertical Axle Hole End (Fist) not in LDD, not replaced. There are two mouth expressions for this set (a scared one and a normal one) and both constructions are included. No stickers and the prints of the eyes are missing. 10018 Darth Maul - Theme: Star Wars; Ultimate Collector Series - LXF file [Brickset][Bricklink][Peeron] Errors: No building errors in this build. One printing is not in LDD: 3004px8, replaced with Dark Grey Brick 1 x 2. Greetings Edited February 17, 2012 by Stephan Quote
zinfinion Posted February 17, 2012 Posted February 17, 2012 4205 Off-Road Command Center - Theme: City - Police - LXF File Errors: - 62812 Rubber Boat 22x10x3 can not be placed on the trailer. The collision mesh does not properly model the hollows on the underside of the boat. _________________________________________________________________________ 4430 Fire Transporter - Theme: City - Fire - LXF File Errors: - Replaced 74610 String 30cm w. Jet Pipe with 4210 Nozzle. _________________________________________________________________________ 4643 Power Boat Transporter - Theme: City - Harbor - LXF File _________________________________________________________________________ Errors affecting multiple sets: - Missing prints. Missing decals. Quote
EM4CZ Posted February 18, 2012 Posted February 18, 2012 (edited) 4440 Forest Rangers Station Theme: City - Police LXF here Edited February 19, 2012 by EM4CZ Please edit the topic onli when the image will be regular. Quote
obsidianheart Posted February 18, 2012 Posted February 18, 2012 (edited) 8971 Aerial Defense Unit - Theme: Agents 2.0 LDD File Errors: -Missing a few prints and all decals, some substitutions made. -Pair of 1x4 plates with 2 1x2 grills wouldn't fit on the sides because of a boundary error with the 4x6 plate above it. These are hovering near where they are supposed to be placed.Fixed by zinfinion! -Rear upper x224 Dark Blue Windscreen 8x6x2 Curved can't be placed correctly due to a boundary error with the pair of 61678 Curved Slopes 4x1 underneath it. The part is placed 1 stud behind where it is supposed to sit. - Strings and rubber band can't be connected, so they are laying near where they go, and place the backpacks on Charge and Chase. -Possibly the most frustrating error, the doors won't close. There appears to be a boundary error with the 3749 Technic Axle Pins beneath them. After the headache of getting the rotor assembly to line up, I opted to just leave the doors open. Edited February 18, 2012 by obsidianheart Quote
zinfinion Posted February 18, 2012 Posted February 18, 2012 (edited) -Pair of 1x4 plates with 2 1x2 grills wouldn't fit on the sides because of a boundary error with the 4x6 plate above it. I've run into this before and there is a hilariously complicated workaround to get it to not collide. Unfortunately, I have no idea how I did it. Still no idea how I did it, but here is the fixed model. Definitely a bug. -Rear upper x224 Dark Blue Windscreen 8x6x2 Curved can't be placed correctly due to a boundary error with the pair of 61678 Curved Slopes 4x1 underneath it. This is also definitely a bug. If you use a jumper plate to offset the 61678, they won't collide. It is only when the sides are aligned that the collision occurs. -Possibly the most frustrating error, the doors won't close. There appears to be a boundary error with the 3749 Technic Axle Pins beneath them. I have no idea on this one. I'd be willing to bet it is an LDD issue though. Edited February 18, 2012 by zinfinion Quote
