  • Replies 5k
Posted Images
One more, and I'm out of stuff I've already built.
6941 Battrax Theme: Blacktron
LDD File
Errors:
- Prints missing (except classic face!), substitutions made on figure and controls, all others left blank.
- 4730 Modified Brick 2x2 with Pin and No Axle Hole unavailable, substituted 6232 Modified Brick 2x2 with Pin and Axle Hole.
- 4864a Panel 1x2x2 with Solid Studs unavailable, substituted with 4864b Panel 1x2x2 with Hollow Studs.
- I'm sure the hose is wrong, but Peeron and Bricklink's numbers aren't matching up with what's listed on LDD's info bar, so I don't know for sure.
- The biggest error is that part 2337 Windscreen 4x4x2 Canopy Extender is unavailable, it is replaced here with an inelegant brick-built mock-up that doesn't connect to the front windscreen.
- I'm sure the hose is wrong...
- ...2337 Windscreen 4x4x2 Canopy Extender is unavailable...
The Classic Space hoses are correct. And nice work on the canopy extender, I came up with something a bit different: LXF File. I've already included it in the wanted parts post.
Edited by zinfinion
8971 Aerial Defense Unit - Theme: Agents 2.0
Errors:
-Pair of 1x4 plates with 2 1x2 grills wouldn't fit on the sides because of a boundary error with the 4x6 plate above it. These are hovering near where they are supposed to be placed.Fixed by zinfinion!
-Rear upper x224 Dark Blue Windscreen 8x6x2 Curved can't be placed correctly due to a boundary error with the pair of 61678 Curved Slopes 4x1 underneath it. The part is placed 1 stud behind where it is supposed to sit.
- Strings and rubber band can't be connected, so they are laying near where they go, and place the backpacks on Charge and Chase.
-Possibly the most frustrating error, the doors won't close. There appears to be a boundary error with the 3749 Technic Axle Pins beneath them. After the headache of getting the rotor assembly to line up, I opted to just leave the doors open.
In addition to previous discussions:
1) Pair of plates on sides
This is an error due to the holes of technic bricks not being placed in system. A classic issue (read more here). It's not because of an error in LDD - it's an illegal build technique. But can be worked around in LDD liked discussed by zinfinion.
2) Dark blue windscree - Collision error bug in LDD.
3) Doors won't close.
This seems to be a problem with the way the model was built in conjunction with how LDD handles rotation axis.
If you put an extra plate (pink in the attached file) to add multiple stud connections on each side, it will allow you to rotate the around the first axis.
To rotate around the other axis, you need to click on the pin itself (marked green in the file) in order to select the correct rotation axis.
There is still a collision error with the green pin though, which won't allow you to close the doors fully. This is because the technic hole positioning (same as error 1 above).
Heli.lxf
Plenty of errors in this one...
The issue isn't the inability to rotate the parts (easily solved through your method or pulling the bottom pin out and rotating the bottom beam in first), but the 3M Pin with Cross colliding at the top. At least as I understand it.
Edit: Haha, what is going on here? Superkalle, did you delete your post? If so, please delete this one as well. :laugh:
Edited by zinfinion
Oh, I was just temporarily hiding my post while editing/completing. And in between you got a sneak peek. :laugh:
7291 Street Rebel [Version III] - Theme: Creator -
Errors:
- Replaced 32316 Technic 5M Beam with 2x 32017 Technic 5M Half Beam due to 32316 Technic 5M Beam not snapping to the middle of 32054 2M Friction Snap w/ Cross Hole.
This is because of illegal build from TLG. The 32054 will be "pushed half way through" the 32316, and hence will put it in constant compression. If you examine a physical 32054 closely you will see it has ridges that are supposed to snap fully in, and they don't in this case.
Conclusion: LDD is correct. Bad build by TLG.
... The 32054 will be "pushed half way through" the 32316, and hence will put it in constant compression. If you examine a physical 32054 closely you will see it has ridges that are supposed to snap fully in, and they don't in this case.
Luckily I just got the 9391 Mini Crane yesterday and it has a couple of the 32054 pins. I definitely can see the ridge in the middle of the long side, as well as feel it click back out to being uncompressed when a full width beam is fully positioned to either side. I tried it as well with 4 half width beams and that prevents the compression. So I guess my fix of 2 half beams in the fork was the right thing to do. :laugh:
Messing around with your file, Superkalle, I can almost get the door closed, and then copy/paste it that way to other appropriate spots. I think I'll leave it alone, though. Think of it as, uh, showing off the interior? Even though you can't actually see most of it in the picture. Yeah.
6781 SP-Striker - Theme: Space - Space Police I - LXF File
Errors:
- Replaced 4873 Bar 1x6 with Studs Open with 6140 Hanger 1x6.
- Replaced 4760c01 Small Electric 9V Battery Box with 4x 3007 Brick 2x8 / 3023 Plate 1x2 / 2x 2420 Corner Plate 1x2x2 / 3020 Plate 2x4 / 3031 Plate 4x4.
- Replaced 4x 4755 Electric Plate 1x2 with Contacts with 4x 3023 Plate 1x2.
- Replaced 2x 4757 Electric Plate 2x4 with Contacts with 2x 3020 Plate 2x4.
- Replaced 4315 Hinge Plate 1x4 with 3710 Plate 1x4.
- Replaced 2x 3067 Brick 1x6 without Pins with 2x 3009 Brick 1x6.
- Replaced 2337 Windscreen 4x4x2 Canopy Extender with 6x 2431 Flat Tile 1x4 / 2x 3710 Plate 1x4.
- Replaced 4767 Electric Light Brick 1x2 with Single Top Light with 2x 3023 Plate 1x2.
- Replaced 4771 Electric Light Brick 1x4 with Twin Top Lights with 2x 3710 Plate 1x4.
- Replaced 2500c01 Electric Light Brick 1x8 with 3 Front Light Prisms with 2x 3005 Brick 1x1 / 3x 3700 Technic Brick 1x2 / 3x 4274 Connector Peg w. Knob.
- Replaced 905c01 Electric Light Slope 45 2x2 with Computer Console Pattern with 3039 Roof Tile 2x2/45° / 3023 Plate 1x2.
_________________________________________________________________________
6895 Spy Trak I - Theme: Space - Space Police I - LXF File
Errors:
- Replaced 3034 Plate 2x8 with 2x 3022 Plate 2x2 and shifted 2x 3660 Roof Tile 2x2/45 Inverted upwards 8 LDU to avoid collision with 3707 Cross Axle 8M.
6986 Mission Commander - Theme: Space - Space Police I - LXF File
Errors:
- Replaced 2426 Technic Rack Winder with 4x 3023 / 2x 3700 / 3710 / 2x 3024 / 32073 / 2x 32123.
- Replaced 2428 Technic Rack 1 x 20 x 2/3 with 5x 3743 Toothed Bar.
- Replaced 4504 Hinge Plate 1x6 with 2 and 3 Fingers On Ends with 4275 / 4276 / 3023.
Errors affecting multiple sets:
- Missing prints.
- Replaced 4033 Window 1 x 4 x 3 Train with All Studs Hollow with 6556 Container Frame 1x4x3.
- Replaced 4x 3957 Antenna 1x4 with 4x 30374 Light Sword - Blade / 4x 85861 Plate Round 1x1 w. Through Hole to avoid collision.
- Replaced 3855 Glass for Window 1x4x3 with 4034 Train Window Glass 4x3.
6770 Lunar Transporter Patroller - Theme: Space - Futuron - LXF File
Errors:
- Replaced 4755 Electric Plate 1x2 with Contacts with 3023 Plate 1x2.
6780 XT Starship - Theme: Space - Classic - LXF File
Errors:
- Shifted 2x 64230 20 LDU rearwards due to being not flexible enough.
6783 Sonar Transmitting Cruiser - Theme: Space - Classic - LXF File
Errors:
- Replaced 2x 122c01 Plate, Modified 2x2 with Wheels with 4600 Bearing Element 2x2 / 4624 Rim Narrow w. Hole Ø8.
- Replaced 2x 4868a Engine, Smooth Large, 1x2 Thin Top Plate with 4868b Engine, Smooth Large, 2x2 Thin Top Plate / 2x 3794 Plate 1x2 w. 1 Knob.
- Replaced 3149 Hinge Plate 2x5 with 98285 / 98286 / 2780 / 2x 63864.
- Replaced 2x 4085 Plate 1x1 w. Holder with 3024 Plate 1x1 to avoid collision.
- Missing prints.
- Replaced 4760 Small Electric 9V Battery Box with 4x 3007 Brick 2x8 / 2x 3023 Plate 1x2 / 2x 2420 Corner Plate 1x2x2 / 3020 Plate 2x4 / 3031 Plate 4x4.
- Replaced 4767 Electric Light Brick 1x2 with Single Top Light with 3023 Plate 1x2 / 3794 Plate 1x2 w. 1 Knob.
- Replaced 4757 Electric Plate 2x4 with Contacts with 3020 Plate 2x4.
- Replaced 4758 Electric Plate 2x8 with Contacts with 3034 Plate 2x8.
- Replaced 4774 Electric Sound Siren 9V 2 x 2 x 1 1/3 with 3022 Plate 2x2 / 92947 Profile Brick Ø15.83 w. Cross.
1916/3015 Starion Patrol - Theme: Space - Space Police II - LXF File
1969 Mini Robot - Theme: Space - Space Police II - LXF File
6813 Galactic Chief - Theme: Space - Space Police II - LXF File
6897 Rebel Hunter - Theme: Space - Space Police II - LXF File
6957 Solar Snooper - Theme: Space - Space Police II - LXF File
- Missing prints.
Notes:
- This completes Space Police II! -
325-3: Shell service station
Theme: LEGO / Classic / Cars / Year: 1966
Download-->
model without stickers and patterns, doors and windows replaced
fuel truck, sign and pump stand custom replaced
Hi zfinion!
Every time I look at your excellent LDD-works I ask myself: How did he do that?
Do you us e a special final rendering, or what? Is it included to LDD?
(Hopefully you haven't answered this question before).
My models look so different from yours - and yours so much better!
Don't let me die unknowing. :classic:
Good evening,
21012 Sydney Opera House - Theme: Architecture - LXF file
[Brickset][Bricklink]
Errors:
No building errors!
Missing prints:
Missing stickers:
No missing stickers!
21101 Hayabusa - Theme: Cuusoo - LXF file
Errors:
No building errors!
Missing prints:
Missing stickers:
Missing stickers!
4000002 LOM 2011 Moulding - Theme: Miscellaneous - LXF file
Errors:
No building errors!
Missing prints:
Missing stickers:
Edited by Stephan
I'll set my phaser to stun, instead. :tongue:
What I've done is set my video card to be able to display at 3040x1900, which is a bit complicated and fraught with peril. If you have an Nvidia card and wish to be brave, try these instructions. If you are not ready to turn your computer into a smoulder slag pile, or you are using AMD or Intel graphics, you can:
-Right click desktop
-Screen resolution
-Advanced settings
-List all modes
-Look for 2560 x 1600, True Color (32 Bit) or the largest listed that is True Color (32 Bit)
-Select it and click OK
-Click apply
-If your screen switches resolution, click Yes (If your screen goes blank or weird, don't panic, wait 15 seconds, and it should go back to the original resolution)
That's for Windows 7, but Vista or XP should be somewhat similar.
Once you have your maximum resolution set, go to view mode in LDD, hit 5 on the numpad, scroll wheel back one click, then take the screenshot from the menu. Open this in your photo editor of choice and resize to 512px or whatever you prefer. Make sure to use bicubic or bicubic smoother to get the smoothest results. I use Photoshop, but the GIMP or PixBuilder Studio work just as well.
Additionally, before I resize, I stack 4 copies of the screenshot on top of each other then merge the layers, this makes the transparent elements much more vivid.
That's pretty much it. Thanks for noticing the effort I put into my shots. :laugh:
Oh, and buyer beware, I can't be held liable for any damages mental or physical, etc ad infinitum and so forth...
I guess I don't have to post mine now! :tongue: Good work, and it's a really neat build. The angled sections were rather fun to get lined up. It's also surprisingly not as hideous looking as the official photos make it out to be.
10224 - Town Hall - Theme: Modular Buildings
[bricklink] [brickset]
10224 LXF
Notes:
- Built from instructions with bricks and colours checked against TLG Customer Service site - not checked with actual set.
- Missing decoration on some minifig torsos (orange, white, earth blue).
- Different decoration on red minifig torso.
- White Beard 93223 not in LDD, replaced with beard 6132
- Female Wig 93562 not in LDD, replaced with Wig 93217
- Medium Stone Grey Mini Shield 10182 (decorated) not in LDD, replaced with Mini Shield 3846.
- Technic 1x2 With 2 Holes (32000) does not (in LDD) 'lean on' Plate 1x2 with Stub (30383) (in support of sloped roof above main entrance).
- In sloped roofs above main entrance, White Plate 1x10 replaced by Plate 1x2 and Plate 1x6 to avoid collision.
- Missing decoration (picture/painting) for Sand Yellow Tile 2x2
- Two Decorated Half Domes (Cylinder Hemisphere) 97360/97362 (Bricklink 61287pb001 / pb002) not in LDD. No replacement :sad:
- White Tile 1x2 does not fit in 1891 logo. Placed seperately. ('Pet Shop problem')
- Missing decoration (clock) on Black Round Plate 3960.
- I was unable to fit the rooftop windows with the Lamellas 4218/4219. :wacko: They are now placed next to the building. Any help in getting this fixed is welcome.
EDIT 1: New version: Problems with 1891 Logo and Rooftop Window Lamellas solved through collaboration with EM4CZ, Calabar and Vean pirate_thumbup.gif . Thnx guys!
EDIT 2: Updated to LDD 4.3.5 - White Beard 93223 & Black Female Wig 93562 corrected as they are now in LDD.
EDIT 3: Updated to LDD 4.3.9/2075 - Half Domes 61287 added (Globe). Decorations on globe halves still missing, though.
Edited by Sjuip
Fixed lamella roof on 10224 - Town Hall
10224.lxf
- White Tile 1x2 does fit in 1891 logo. I shifted the number one.('No problem')
- Fit the rooftop windows with the Lamellas 4218/4219. :wink: I modified a little the angle of the Lamellas and put them over the roof.
Edited by EM4CZ
Changed from indexing style heading, Image removed.
Great! Thank you for this work.
I have achieve to finish the roof placing correctly all window parts. You can find the XLF for this roof here: My link
I've just put the roof cause you made 99,9999999% of the work. Thank you again for this! :thumbup:
Vincent
Edited by Calabar
Extra images converted in text links
10224 - Town Hall - Theme: Modular Buildings - version 2
10224.lxf
Good work EM4CZ. Do you think you could try to make the lamellas "symmetrical" on both sides. As it is now, there is a quite an angle on the black one, and on the other side it's vertical on the other side. The result is that the knobs on the lamellas touch into the 6183 Arch, and if TLG ever decides to upgrade the collission volumes on that brick, the lamellas will be removed when opening the file. I don't know if this is easy to do, but maybe you can give it a try.
Also, I edit your post to remove the indexing style heading and just make it an update to Sjuips post.
EDIT: Just saw that vean did something too. Checking that out now...
EDIT2: Vean, your folder is not public yet. Can you deeplink?
@Sjuip
I completely removed your duplicate post.
@EM4CZ
I can't find references for the "version 2" you posted. Could you provide one?
Another little thing: your image represents a detail of the building, could you replace it with an image showing the whole set? The image is for preview purpose. :classic:
EDIT: I see now the SuperKalle intervention. I misunderstood, your insertion was a fix of Sjuip work.
I've removed the image too, as the post is not a new entry to be indexed.
@vean
Which entry your post is referred to?
The link you provide points to your gallery, but as brickshelf is moderated, it could be unaccessible for days. If you want to share your fix you should deeplink the lxf file.
Excellent work on the Townhall Sjuip - some comments/questions below
That is a bit strange - does it mean that it leans "on-top" of the stub in the real model? I mean, otherwise LDD is normally quite accurate. It would be interesting to hear from anyone who has the set (or feel like replicating that section of the model). If it leans on the stub like it does in the LDD model, that is not very good design from TLG.
Also a bit strange. I guess it depends also on the angle of the roof, which in turn is dependent on the issue above. If the angle is correct, this seems like an illegal build from TLG.
Yeah, annoying LDD issue that you can't fine tune position better.
