Calabar Posted April 20, 2012 Author Posted April 20, 2012 379(-2) Car and Caravan - Theme: LEGO Model - LXF file Stephan, the image of this set is oversized. Perhaps you absentmindedly used the large image instead than a thumbnail? Quote
marco9999 Posted April 22, 2012 Posted April 22, 2012 4882 - Speed Wings - Creator Version I LXF Version II LXF Version III LXF Version IV LXF Version V LXF Version VI LXF Version VII LXF Version VIII LXF Version IX LXF Version X LXF Version XI LXF Quote
Stephan Posted April 24, 2012 Posted April 24, 2012 Stephan, the image of this set is oversized. Perhaps you absentmindedly used the large image instead than a thumbnail? Solved Quote
marco9999 Posted April 25, 2012 Posted April 25, 2012 8153 - Ferrari F1 Truck 1:55 - Racers LXF Stickers are missing. Quote
ADHO15 Posted May 2, 2012 Posted May 2, 2012 (edited) 9492 TIE Fighter (LDD 4.3.5 - Star Wars: Episodes 4/5/6 - Duplicate) LXF File ERRORS: Incorrect/missing prints 9676 TIE Interceptor And Death Star (LDD 4.3.5 - Star Wars: Planet Series 1) LXF File ERRORS: Replaced part 98107 with brick-built solution Incorrect/missing prints 30056 Star Destroyer (LDD 4.3.5 - Star Wars: Episodes 4/5/6 - Duplicate) LXF File 30057 Anakin's Pod Racer (LDD 4.3.5 - Star Wars: Episode 1 - Duplicate) LXF File 30058 STAP (LDD 4.3.5 - Star Wars) LXF File 30059 MTT (LDD 4.3.5 - Star Wars) LXF File EDIT: Just found and made these new Marvel Superhero promos: 30162 Quinjet (LDD 4.3.6 - Super Heroes: Marvel Heroes) LXF File 30163 Thor And The Cosmic Cube (LDD 4.3.6 - Super Heroes: Marvel Heroes) LXF File ERRORS: Incorrect/missing prints 30165 Hawkeye With Equipment (LDD 4.3.6 - Super Heroes: Marvel Heroes) LXF File ERRORS: Incorrect/missing prints Edited March 9, 2013 by ADHO15 Quote
ok13 Posted May 4, 2012 Posted May 4, 2012 (edited) 6264 Forbidden Cove - Pirates LXF NOTE: - Incorrect or missing decorations - Missing stickers - A couple of connections were not possible with LDD UPDATE: - Fixed brown color as per Aanchir's comment Edited May 5, 2012 by ok13 Quote
Aanchir Posted May 5, 2012 Posted May 5, 2012 6264 Forbidden Cove - Pirates LXF NOTE: - Incorrect or missing decorations - Missing stickers That brown color is wrong. Those brown parts should be 25 Earth Orange (classic brown). Quote
Calabar Posted May 6, 2012 Author Posted May 6, 2012 UPDATE 4996 - Beach house [Version I] Theme: Creator Link to the original post. NOTE: the screenshot has not been updated (fixes are not so visible). Thanks to ok13 for the error checking. Quote
ADHO15 Posted May 8, 2012 Posted May 8, 2012 (edited) Here's 10225 R2-D2 (LDD 4.3.5 - Star Wars: Ultimate Collector Series) LXF File ERRORS: Incorrect/missing prints and sticker Collision error between parts 2921 and 32523 (Book 2 p30,p45) Parts 30527 cannot be flexed (Book 2 p78) Part 32187 cannot connect to 2780 (Book 3 p10) Part 32187 cannot connect to 61184 (Book 3 p12) Part 32187 cannot connect to 87580 (Book 3 p30) Perhaps a more skilled builder than I could put the third leg in place. Edited October 27, 2012 by ADHO15 Quote
Superkalle Posted May 8, 2012 Posted May 8, 2012 Here's 10225 R2-D2 (LDD 4.2 - Star Wars) ERRORS: Incorrect/missing prints and sticker Collision error between parts 2921 and 32523 (Book 2 p30,p45) Parts 30527 cannot be flexed (Book 2 p78) Part 32187 cannot connect to 2780 (Book 3 p10) Part 32187 cannot connect to 61184 (Book 3 p12) Part 32187 cannot connect to 87580 (Book 3 p30) Great work ADHO15 And good find about the 32187 not connecting. Clearly an error. About the collision though, I found by doing some quick tests that if you tilt the entire body by 1 degree "backwards", 2921 and 32523 will not collide. It's a bit tricky though since there are parts both in the feet and the body that are not connected (lose connection). I wasn't able to fix it, but maybe someone else can. Quote
ADHO15 Posted May 9, 2012 Posted May 9, 2012 Great work ADHO15 And good find about the 32187 not connecting. Clearly an error. About the collision though, I found by doing some quick tests that if you tilt the entire body by 1 degree "backwards", 2921 and 32523 will not collide. It's a bit tricky though since there are parts both in the feet and the body that are not connected (lose connection). I wasn't able to fix it, but maybe someone else can. Thanks, Superkalle. That 32187 has been an error I've noticed in numerous sets, so I hope they'll make it attachable to studs and pins in a future version of LDD. Only axles seem to work at the moment. Yes, I noticed that, but unfortunately tilting the body back is nowhere near as easy to do on LDD as in real life! I tried to do that as I was joining the legs to the body, but thought that having one or the other on an angle might cause problems when bulding the head and feet, so decided to just remove the bricks with handles and report it as an error in my model. Quote
Superkalle Posted May 9, 2012 Posted May 9, 2012 Thanks, Superkalle. That 32187 has been an error I've noticed in numerous sets, so I hope they'll make it attachable to studs and pins in a future version of LDD. Only axles seem to work at the moment. Yes, I noticed that, but unfortunately tilting the body back is nowhere near as easy to do on LDD as in real life! I tried to do that as I was joining the legs to the body, but thought that having one or the other on an angle might cause problems when bulding the head and feet, so decided to just remove the bricks with handles and report it as an error in my model. Stud support for 32187 should not be a problem to fix (I assume). Pin support I don't know since LDD doesn't support "loose" connections - with a physical element the pint won't fully lock the 32187 in place (as I remember at least). Yeah, I tried too to tilt the body backwards, but could only do it after I removed a lot of other parts. And then I gave up and though...maybe someone else want's to have a go Quote
ok13 Posted May 9, 2012 Posted May 9, 2012 (edited) 6292 - Enchanted Island - Pirates LXF NOTES: - incorrect or missing prints - missing stickers - incorrect baseplates - missing sails - missing mast 4318 - missing hinge bar 4319 - missing hinge bar 2375 Edited May 9, 2012 by ok13 Quote
Nachapon Lego Posted May 9, 2012 Posted May 9, 2012 (edited) Here's [b1]10225 R2-D2[/b] (LDD 4.2 - Star Wars) Good work! I tried to re-pose it, but rotate the leg not enough so all legs become a bit too long. LXF pic Edited May 9, 2012 by bbqqq Quote
Calabar Posted May 9, 2012 Author Posted May 9, 2012 @bbqqq As you did the work yet, why don't insert your entry as a duplicate? Quote
Stephan Posted May 9, 2012 Posted May 9, 2012 (edited) I have also finished R2. With the legs in proper position and no other big errors. Although THE hoses aren't flexible. I will upload it as soon as possible (as a duplicate)! Greetings EDIT: I didn't see that bbqqq posed R2 with his third leg... I have posed him in his two-legged position. Edited May 9, 2012 by Stephan Quote
Stephan Posted May 9, 2012 Posted May 9, 2012 I have also finished R2. With the legs in proper position and no other big errors. Although THE hoses aren't flexible. I will upload it as soon as possible (as a duplicate)! Greetings EDIT: I didn't see that bbqqq posed R2 with his third leg... I have posed him in his two-legged position. EDIT2: Here's the LXF file: LXF file I will update this post in the next couple of days (when I got the time). Quote
Nachapon Lego Posted May 10, 2012 Posted May 10, 2012 (edited) @bbqqq As you did the work yet, why don't insert your entry as a duplicate? OK, I will do it as soon as I fix the lags angle, extend length and piece removed. Edited May 10, 2012 by bbqqq Quote
Nachapon Lego Posted May 10, 2012 Posted May 10, 2012 10225 R2-D2 (LDD 4.2 - Star Wars) [duplicate] Base on ADHO15's work. LXF foot fix pic LDDScreenShot549 by Nachapon S., on Flickr Quote
marco9999 Posted May 10, 2012 Posted May 10, 2012 10174 - Imperial AT-ST - Star Wars LXF Rubber belt, decorations and stickers missing. I could not manage to close the cockpit's rear door completely. The side doors' connection is not ideal too. Some improvement could be obtained by combining rotations in a different way; I made several attempts and this was my best. Quote
Nachapon Lego Posted May 11, 2012 Posted May 11, 2012 10174 - Imperial AT-ST - Star Wars Good work! Didn't notice that no one make this set. I closed the cockpit. pic LXF Quote
marco9999 Posted May 11, 2012 Posted May 11, 2012 I closed the cockpit. pic LXF That's teamwork! Quote
ADHO15 Posted May 11, 2012 Posted May 11, 2012 (edited) I'm right in thinking updated sets that were originally made in LDD4 are posted here, correct? If so, from the Batman theme... Updated 7885 Robin's Scuba Jet: Attack of The Penguin here; 7884 Batman's Buggy: The Escape of Mr. Freeze here; 7786 The Batcopter: The Chase for the Scarecrow, 7787 The Bat-Tank: The Riddler and Bane's Hideout, 7886 The Batcycle: Harley Quinn's Hammer Truck and 7888 The Tumbler: Joker's Ice Cream Surprise here; and 7779 The Batman Dragster: Catwoman Pursuit and 7780 The Batboat: Hunt for Killer Croc here. Edited May 11, 2012 by ADHO15 Quote
ADHO15 Posted May 13, 2012 Posted May 13, 2012 (edited) Another new Marvel Superheroes set: 6868 Hulk's Helicarrier Breakout (LDD 4.3.6 - Super Heroes: Marvel Heroes) LXF File ERRORS: Missing part x37 Replaced parts 75c06 with brick-built solution, 10121pb01 with 60671, 10124 with 60672, 10126 with 60640, 10127 with 60641, and 10154 with 60673 Incorrect/missing prints and stickers Part 32187 cannot connect to 2780 (Book 1 p21) Edited March 28, 2013 by ADHO15 Quote
ADHO15 Posted May 18, 2012 Posted May 18, 2012 (edited) Seems I'm the only one here at the moment. Another Marvel Superheroes set: 6869 Quinjet Aerial Battle (LDD 4.3.6 - Super Heroes: Marvel Heroes) LXF File ERRORS: Incorrect/missing prints and stickers Part 61483 cannot connect to part (Book 3 p27) Edited March 28, 2013 by ADHO15 Quote
