Very, very cute. I wish TLC would actually make some of these. :-)
There aren't any illegal connections, so it's theoretically possible. I'll try to get an .LXF file up.
Nice little well! However, the two headlight bricks supporting the beams look ungainly. I don't think it would be possible to lower them a brick, but would a 1 x 1 Technic brick fit between the two Travis bricks? Turned on its side, it could be used as the beam's support without sticking up above the rest of the well.
I've edited the frontpage post for you.
Thanks, and it would, but it would get in the way of the 1x1 round brick/bucket that goes down the center.
Instructions please, because this is just brilliant.
I forgot that studs can't go into Technic brick holes in LDD, but here's the cutaway shot:
Enjoy!
Note: The 6-wide base was meant to be sunk into an old Belville plate, it's not required. The 1x1 with studs on two sides below the normal structure is not required either, it's there because the friend I was building this for didn't have another backpack with stud piece like used on the front of the well.
Edited by Brickdoctor
I like it. Though to be critical, it looks strange to me without a roof area. I have the image of a well with a roof over it to keep out leaves, sun, etc. Don't most wells of this sort have these?
Medieval structures were kind of short on innovation, but I'm working on it.
