As stated, I need to find the swiveling door frame on the tower that has the bandit skeleton on one side and the crystal/goblets on the other. I got this set on bay, was told it was 100% complete. But, instead of the correct door frame, it was the fatter jail door frame. I've perused Lego pick-a-brick and brick link, but for one reason or another, I couldn't locate it. Help,
The only suggestion i have is that you keep on lucking or you go into a lego show and get some help from them!
Thanks,
Jammit
Have you tried bricklink? www.bricklink.com
Oops, my bad. I see that you already stated you tried bricklink.
Good luck!!
This is the inventory on Peeron:
http://www.peeron.com/inv/sets/6093-1
just copy the piece nummer in bricklink and you should be good to go. (I can find both frames on bricklink)
Edited by OneSnowTrooper
Have you tried following the set inventory on bricklink? If it isn't listed, it might be hard to buy.
This Link is for the set inventory on bricklink. The part should be on the list and then you can follow the part through to a seller who has it in stock.
Here you go
http://www.bricklink.com/search.asp?itemID=1040&colorID=1
Plenty on there in white. Suprising considering this set was the only one with a white one in it.
The jail door frame in black is used in the set as well. Is that the one you got or did you get 2 jail door frames from the seller?
I got the jail door frame that's 2x4. I've never bought from brick link before, and I don't buy other than full sets...so I'm not sure how to go about obtaining this piece. I noticed some stores on there have a minimum purchase price, but even with the ones that don't..getting just the door would be crazy
So grab a few extra things from a shop that has it at a reasonable price. Take a look and get a selection of interesting parts or figures to hit the price they require and check if the store is located in the same hemisphere as you so postage costs less :thumbup:
You could always do what I do.
Keep a list of parts you need (in a text file, or on your wanted list on bricklink) and wait until you have enough pieces to make an order.
I buy random lots on a regular basis and use this method to finish sets.
Also - Don't feel overwhelmed, bricklink is as easy as buying something on ebay. You buy your item/items, pay, receive, verify, leave feedback. I was a bit confused the first time I ordered, but the anxiety wore off quickly :)
