Took me long enough... but I've got instructions! Well, build photos at least! So if you'd like to recreate my Tumbler, check out the flickr set:
I also took the opportunity to give the driver a roomier cockpit, by replacing the 6x8 plate on the bottom with a recessed vehicle base. Batman approves!
If you do build a copy, or a Tumbler based on mine, please do share photos! :sweet:
  • 6 months later...
I didnt want to start a new thread. But I finally ordered the bricks and built my own version of Pellaeon's Tumbler. The tumbler parts was my first batch BL order so I was missing a few pieces. I scrounged some tiefighters and batches of loose pieces I have in a bin to add a little detail and try to finish the Tumbler. I also got too many of the black axle wheels, not realizing I needed a pin hole type black wheel so I used a gray set for the front as a temporary fix until I get the black wheels.
I added two batarang holders inside the cockpit.
Here is another shot of the Tumbler.
* snip *
Excellent work! I'm glad you're enjoying it, and that taking all those "instruction" photos wasn't a waste of my time. :tongue:
BTW, I've made one change since then, which is to add one of these to the rear engine: [ Black Technic Hub / Handle 1 x 1 ]. It looks a bit better, I think. I'll try to snap a pic when I get home.
interesting, mind taking build steps of tour animated series batmobile?
Sorry, that one is a lot of work to disassemble. It's a much easier build though, and I took a few pictures of the more complex assemblies, which you can see in my photostream starting with this one.
Edited by Pellaeon
  • 10 months later...
amazing creation! kudos to you Pellaeon!
now, what basic set should i buy to make your creation given i have no resources to get stuff from brick link?
only have access from our local toy shops, will getting the latest batman super heroes bat mobile vs two face kit get me started with this?
