Kumbbl Posted November 19, 2013 Posted November 19, 2013 just build the 8043 as described here http://www.eurobrick...topic=88601&hl= - and it will work like a charm... if you build it in a perfect manner! (and you description sounds as if you haven't ;-) Quote
yepyep14u2know Posted November 29, 2013 Posted November 29, 2013 (edited) What gearing would I need to change if I don't have an XL motor? I have an extra M and L motor. Thanks! Edited December 24, 2013 by yepyep14u2know Quote
Tech-nick Posted December 12, 2013 Posted December 12, 2013 (edited) I built Ultimate 8043, and its way better than original. Great job Jurgen! But I made my own modification out of modification I used the standard battery box, and did not use lights or extension cable, (Because I don't own ones, or small battery box) To use the standard battery box, I made few changes in the inner structure and panels on the right side. It's possible, if somebody wondered. The structure is solid. If somebody wants more details, just ask :) Edited December 12, 2013 by Tech-nick Quote
afol1969 Posted December 12, 2013 Posted December 12, 2013 Hi Tech-Nick, Great work, your modification! A good solution for using a standard BB box, so it's not necessary to buy the expensive charging BB. Greetings Alex Quote
Tech-nick Posted December 12, 2013 Posted December 12, 2013 Thanks afol1969 I used your MLCAD instructions, they were geat, thanks! I found some errors/problems with it, I will report them in your Instruction topic. Quote
afol1969 Posted December 13, 2013 Posted December 13, 2013 Hi Tech-Nick, Can you give me more details about your BB modifications (photos etc.)? So I can add these modification steps to the instructions. It may be a great alternative for them who have only the standard BB. Greetings Alex Quote
Tech-nick Posted December 13, 2013 Posted December 13, 2013 (edited) Sure! Do you take LDD file? I could draw what is different in it. Edited December 13, 2013 by Tech-nick Quote
wimpie3 Posted December 21, 2013 Posted December 21, 2013 Just finished Jurgen's Ultimate 8043, with big bucket modif and a flashing light. Wow, that was hard... making a model based on pictures is difficult, but fun! Watch a video I have made here: Quote
yepyep14u2know Posted December 25, 2013 Posted December 25, 2013 I finished the Ultimate 8043 also, except I didn't have an XL motor so I just used an M motor in it's place and it still works great. Thanks Jurgen for the excellent MOC and instructions! Quote
Pyropetepete Posted December 26, 2013 Posted December 26, 2013 Just been playing with my stock version with my son. It's slow, unhappy and clunky. I didn't build it. I bought it second hand, boxed and all. It defo needs the upgrades. So how do I do this as this is my first moc, mod non offical build. The instructions I'm going to get printed off into a booklet. Do it proper. Parts.... Is there a list or website to get them all. Thanks Quote
yepyep14u2know Posted December 27, 2013 Posted December 27, 2013 Just follow this link http://rebrickable.com/compare?s1=8043-1&s2=MOC-0080 and it will compare the 8043 to the ultimate 8043 and give you the parts needed Quote
Pyropetepete Posted December 27, 2013 Posted December 27, 2013 Just follow this link http://rebrickable.c...3-1&s2=MOC-0080 and it will compare the 8043 to the ultimate 8043 and give you the parts needed Thanks, see I need 279 parts to do the mod from stock kit. So where is the best place to buy it all in one lump? Also is there going to be reworked updated manual for the moc build? Quote
zux Posted December 27, 2013 Posted December 27, 2013 Thanks, see I need 279 parts to do the mod from stock kit. So where is the best place to buy it all in one lump? Bricklink or Brickowl is your friend here. Quote
yepyep14u2know Posted January 18, 2014 Posted January 18, 2014 I built the Ultimate 8043 a few months ago and recently ordered up 3 XL motors from Lego. The XL for the boom is quite loud, so I tried the other ones and same thing. Is this normal? Also, what would I have to modify if I wanted to use the other 2 XL's for both tracks? Could anyone whip up an LDD for me? Thanks Quote
gerger Posted January 20, 2014 Posted January 20, 2014 (edited) Sorry for my poor english as I am non-english speaker. I built my 8043 set in early 2011 and had been putting it onto shelf, until I found recently that the two actuators supporting the boom were getting very weak even with new batteries installed. Inspired by the MOC from this post but without too many extra parts from my own, eg, the expensive 8878 rechargeable battery, I tried to pack the default AA batteries box with 6 motors plus some extra work around for more space to align the IR receivers, etc.. it's a great set to play with and her are some overview. *images links are fixed. I created a LDD file to document my earlier MOCs (post #165) when i was disassembling my own version of 8043 with some minor changes, see if that's helpful. https://dl.dropbox.com/s/bozgxon1g7d508z/8043-rt.lxf Edited January 20, 2014 by gerger Quote
akuaslisolo Posted January 20, 2014 Posted January 20, 2014 INSPIRING! Let me download the instructions Mate. Next time I'd like to make one of that too, and let's see if I can come out with a little bit more modifications. I'll share later. Thanks Mate! Quote
Simwong Posted February 11, 2014 Posted February 11, 2014 (edited) Hey guys, i just built my Ultimate 8043, it is really cool. but there is a small problem that the left and right side drives in different speed so it cannot just go straight .( i noticed that some guys also complain about this issue) i think it is because of the gearing design is different between 2 side, the right side gears are way complex than the left side, so my solution is replace the right side motor from M motor to L motor . after i made this change, it works perfectly fine, hope this small tips can solve your problem. Also i have extend the length of the boom so it can help to go through some blocks. Edited February 17, 2014 by Simwong Quote
TinkerBrick Posted February 11, 2014 Posted February 11, 2014 Sounds like promising solution. Could you do a short video the improved performance and share it? Quote
yepyep14u2know Posted March 2, 2014 Posted March 2, 2014 Hey guys, i just built my Ultimate 8043, it is really cool. but there is a small problem that the left and right side drives in different speed so it cannot just go straight .( i noticed that some guys also complain about this issue) i think it is because of the gearing design is different between 2 side, the right side gears are way complex than the left side, so my solution is replace the right side motor from M motor to L motor . after i made this change, it works perfectly fine, hope this small tips can solve your problem. Also i have extend the length of the boom so it can help to go through some blocks. Do you have instructions for the extended boom? Quote
ritztoys Posted March 3, 2014 Posted March 3, 2014 Do you have instructions for the extended boom? Check out the forum "42009 Extended Boom", go to post #45, there is a link for BI and additional parts required. Quote
Blakbird Posted March 3, 2014 Posted March 3, 2014 Check out the forum "42009 Extended Boom", go to post #45, there is a link for BI and additional parts required. Here is a direct link to that post. Quote
Eigenbroetler Posted March 3, 2014 Posted March 3, 2014 Check out the forum "42009 Extended Boom", go to post #45, there is a link for BI and additional parts required. Here is a direct link to that post. i think he meant the extended 8043 boom? Quote
yepyep14u2know Posted March 3, 2014 Posted March 3, 2014 Check out the forum "42009 Extended Boom", go to post #45, there is a link for BI and additional parts required. Don't need the 42009 extended boom, was wondering if there was instructions for the 8043 extended boom in the video Quote
ritztoys Posted March 4, 2014 Posted March 4, 2014 i think he meant the extended 8043 boom? Opps, wasn't paying attention I see request for 'extended boom' and jump right in trying to help a fellow builder................ Quote
Seeks Posted March 10, 2014 Posted March 10, 2014 Just (almost) finished Jurgens version of the 8043. As one of the receivers had an error, I had to disassemble the side with the cables again. Now I have the problem again how to "store" them (cables) in a good way in the chasis. Can please anybody give me a good hint or so how to manage this properly? Thx Quote
