  • Replies 427
I haven't seen it mentioned but I wish they would produce the 1 x 1 round brick in Bright Orange. I could have sworn they did (I swear I have seen one somewhere) but Bricklink and Brickset dont show it as existing.
Earth Green would also be nice to see.
It would also be great to see the regular minifig legs in more colors from the "purple" color family (as defined by Brickset at https://brickset.com/colours/family-Purple/status-Current).
The legs come in Medium Lilac which is great but more of the colors from that family would be great to see.
On 06/08/2017 at 5:43 AM, Space Police XVIII said:
I've got four of these, in red, from an Enlighten set.
Lego's ripping off the Chinese makers!   A STUNNING REVERSAL
Actually I think that the Chinese maker copied it from Hasbro/Kre-o ;)
But that may indeed by seen as a "problem" for Lego : many parts left for them to "invent" were actually already "invented" by others, as these are logical derivatives from existing parts.
Edited by antp
On 7/21/2017 at 9:46 PM, Digger of Bricks said:
I would like to see Lego reintroduce part no. 30161 (pictured below), but with 318 bar clips instead for hinges. It was a most ideal windshield part for six wide cars that could be angled at an pitch desired, unlike many current fixed windshield pieces.
th?id=OIP.cP-vQxQoI2dD04hOWyiBSwD6D6&pid=15.1
It'd be a little bit wider and would have a bar at the bottom rather than clips, but what about just using 2x 24093? It even already comes in Tr. Brown, albeit with printing.
19 hours ago, whitswj said:
Which 2 by 5 slopes do you mean? I have a couple funky 2 x 4 in trans neon green. I would love to see and get a 2x5 slope.
OK, I just looked at those slopes again of yours, and yeah, I mistakenly thought they were the ones @1974 had I'd pictured in my initial post. :facepalm:
That's actually a great idea, if you put two together, the seem between them creates a split windshield look! :thumbup:
13 minutes ago, Legohead458 said:
Duel moulded bricks, sounds silly but you'd be able to have two colours in the space of one brick = more detail
Now something like this could be utilized for a 1 by 1 tile. I remember I while back ago on this topic, @MatthewRC had proposed an idea for a triangular 1 by 1 tile, to which some had said this would have absolutely no clutch power. So a dual molded one could create the same desired cosmetic effect without introducing a new piece. :shrug_oh_well:
With parts that have dimensions as small as that, dual molding could be applied to them if ever needed.
It could be used for a 1 x 2 brick or plate to make what amounts to 2 different 1 x 1 elements fused together.  This would be great for use in places where you are creating a tight build, but don't want to have a seam between the bricks for the sake of stability.
Or you could do it lengthwise on other 1 x whatever bricks, for building sturdy walls with stone or brick on the outside and wood or painted sheet-rock on the inside, without the wall being 2 bricks thick.
Edited by x105Black
I think one issue with dual-molded parts like the ones being described is that you'd need a completely distinct part each time you wanted a new color combination. So say if the part were introduced in Dark Stone Grey/Medium Stone Grey and White/Black—who knows how long you'd have to wait for Medium Stone Grey/Black, let alone color combinations involving a specific set of more vibrant colors? People who have been waiting on a particular color of dual molded arms or legs will know what I'm talking about—and at least then many combinations involving common skin tones like Yellow or Light Nougat are more likely, a sort of predictability you couldn't as easily count on with basic building elements.
Another issue is that I'm pretty sure dual molded parts only have clean, regular seams like they do on dual molded legs or arms when they're overmolded (that is to say, the first color is injected into a smaller mold and then the mold changes and the second color is injected to fill the rest of the space). Overmolding is a more complex process, and might not even be feasible at all for tiny parts like the 1x1 or 1x2 plates and tiles being described, and without using that process, the colors would more likely "fade" into one another at the seam in an irregular fashion.
I would like to see a one brick high version of cone part 3942 (pictured below) done, something similar to an old part MegaBloks had done a long time ago, but that part had molded texturing into its sides. I tried looking for a picture of that piece, but with no success, since no one cares to catalog MegaBloks parts. But who would care anyway. :tongue:
On 16-8-2017 at 9:11 PM, Takanuinuva said:
I don't think this new part has been discussed yet. It's found in the Ninjago City set
http://www.newelementary.com/2017/08/a-stud-walks-into-bar.html
Not sure what I'll use it for. But I want a bunch of them.
https://www.bricklink.com/v2/catalog/catalogitem.page?P=32828&idColor=11#T=C&C=11
Wow, yeah I'm gonna pick me up a lot of those as well. So many great ideas for usage! :laugh:
I might have mentioned this before. But I really want a one axle version of this.
There have been so many times where that kind of part would have been perfect.
We have a pin hole to axle version found in sets like Ikir. So why not an axle hole to axle version
I know everyone would love to have any canopy and/or windshield part recolored in Trans-yellow, but for me, there are a few in particular I would be thrilled to see.
Here is list of the top ten canopy/windshield parts I would like to see in Trans-yellow:
  1. Part no. 45705 (SHELL 6X10X2 W/BOW/ANGLE, PC etc.)
  2. Part no. 41751 (SHELL 6X8X2 W/BOW/ANGLE etc.)
  3. Part no. 27165 (COCKPIT 4X10X2 1/3, W/ 3.2 SHAFT, NO. 1)
  4. Part no. 22483 (WINDSCREEN 4X5 1/2X1 1/3)
  5. Part no. 30372 (COCKPIT 4X7X2 FRIC/FORK etc.)
  6. Part no. 11289 (COCKPIT 4X4X4 2/3 W. Ø3.2 SHAFT etc.)
  7. Part no. 18973 (WINDSCREEN 4X6X1 1/3 W/STUDS)
  8. Part no. 87606 (COCKPIT 6X6X2 etc.)
  9. Part no. 27262 (COCKPIT 4X5X1, W/ 3.2 SHAFT, NO. 1)
  10. Part no. 62576 (WINDSCREEN 8x5x2 PC)
