pesa Posted August 19, 2010 Posted August 19, 2010 Part 1: - Part name: arch, ogive 1 x 2 x 2 1/3 - Part description: half arch, small - similar to 2339, but with shorter span so a pair would combine into a gothic style arch, see picture - Part usage: gothic style (aka lancet, ogive) window frame for buildings, castles, churches, townhouses etc. Used as a pair or ending a series of double arches (see Part 2) Part 2: - Part name: arch, double ogive 1 x 3 x 2 1/3 - Part description: double arch, small - similar to 2339, but with shorter span that would combine continuosly into gothic style archway - Part usage: gothic style (aka lancet, ogive) window frame for buildings, castles, churches, townhouses etc. Used as a series, making into an archway/framework Part 3: - Part name: arch, ogive 1 x 3 x 3 1/3 - Part description: half arch, medium - similar to 2339, but with shorter span so a pair would combine into a gothic style arch, see picture - Part usage: gothic style (aka lancet, ogive) window frame for buildings, castles, churches, townhouses etc. Used as a pair or ending a series of double arches (see Part 4) Part 4: - Part name: arch, double ogive 1 x 5 x 3 1/3 - Part description: double arch, medium - similar to 2339, but with shorter span that would combine continuosly into gothic style archway - Part usage: gothic style (aka lancet, ogive) window frame for buildings, castles, churches, townhouses etc. Used as a series, making into an archway/framework Quote
Mingu Posted August 19, 2010 Posted August 19, 2010 (edited) All colors in dark bley, light bley, black to start. - Part name: Double-sided 1x1 plate - Part description: a 1x1 plate, with studs on both sides! - Part usage: ability for SNOT techniques to reuse top-slopes, detailing etc. on the bottom of creations, or to do double-sided wings, etc. - Part name: Double-sided 1x2 plate - Part description: a 1x2 plate, with studs on both sides! - Part usage: same as above - Part name: Double-sided 2x2 plate - Part description: a 2x2 plate, with studs on both sides! - Part usage: same as above Having these basic parts with studs on top and bottom will allow for SNOT techniques many of us have been dreaming of. I have seen many suggestions similar to this, but these three basic parts would cover all the bases. Many "upside-down" parts can be replaced by using these elements to switch under-side building to use normal "top-side" parts. I have seen double-sided parts that would not require a plate, but many of these would be difficult if not impossible to get out from under some pieces. Something that might work, and would be harder to get stuck would be: - Part name: Double-height stud bracket 2x2 with holes in each stud - Part description: a 2x2 bracket of double-height studs, with thin connecting beams like this: O-O | | O-O - Part usage: built to be able to sandwitch two plates together without any added height. - Part name: Double-height stud bracket 1x2 with holes in each stud - Part description: a 1x2 bracket of double-height studs, with thin connecting beams like this: O-O - Part usage: built to be able to sandwitch two plates together without any added height. With the holes in the studs, you could use a light-saber pole or similar part to fish these guys out if they are improperly used or otherwise get stuck. As far as new colors go, I would rather just see alot more purple pieces... some great purple peices became available with Emperor Zurg Construct-a-Figure and some of the other Toy-Story sets. More Dark Turqiouse peices would also be great. Adding more colors in my opinion would just make things too fragmented. If anything, I would suggest resurrecting a select few of the retired colors. Edited August 19, 2010 by Mingu Quote
GuiliuG Posted August 20, 2010 Posted August 20, 2010 (edited) Part 1: - Part name : studless plate 5*3*0.5 - Part description: a thin plate studless with cruciform holes at the extremities : http://www.brickshelf.com/gallery/cbt/TechnicWorkshop/Wanted-items/Wanted-Technic-parts/liftarm_3x5_thin.jpg -Part usage : can be usefull to rigidify some construction or to make compact assemblies ( can be practictal to build the autovalve) Part 2 : -Part name : Technic Pin short with Stop Bush -Part description : exactly the same piece than the technic pin long with stop bush but this time just with two studs and not three : http://www.brickshelf.com/gallery/cbt/TechnicWorkshop/Wanted-items/Wanted-Technic-parts/pin_with_stop_bush_2l.jpg - Part usage : to make compact assemblies and to use when a technic pin long with stop bush is too long ^^ Part 3 : - Part name : technic_axle_joiner_double -Part description : this piece : http://media.peeron.com/ldraw/images/71/32184.png but with holes reversed: http://www.brickshelf.com/gallery/cbt/TechnicWorkshop/Wanted-items/Wanted-Technic-parts/technic_axle_joiner_double.jpg - Part usage : usefull to connect solidly to gear. Actually there is just this piece wich permits that : http://media.peeron.com/pics/inv/custpics/48989.1200267988.jpg and it limits to much the construction ( you're almost obliged to put a beam directly on the piece ) I haven't invented this parts, but i think they can be very usefull. Now my parts : Part 4 : -Part name : technic axle 11 -Part description : an axle of 11 studs to complet the serie of odd (impair?) axles. -Part usage : used in studless construction. Part 5 : -Part name : Technic Gear Rack 1 x 9 with Holes and Axleholes -Part description : the new rack with a different lenght : http://media.peeron.com/pics/inv/custpics/87761.1279091664.jpg ( 9 studs instead of 7 ) -Part usage : usable for constructions of (axles?) because of its biggest lenght Part 6 : -Part name: Technic Beam 3 x 0.5 Liftarm with reversed holes -Part description : this piece http://media.peeron.com/ldraw/images/71/6632.png with reversed holes -Part usage : usefull to make variable lenght axles and usefull to connect solidly two gears ( can be usefull for a lot of others constructions too, i often needed this piece when i built. Part 7 : -Part name : 20T (idle?) gear -Part description : a 20T gear wich doens't grip on its axis, able to receive a driving ring -Parte usage : pratictal to create compact gearbox. Part 8 : -Part name : small turn table -Part description : a small turn table where you can just put one axle into. With this small turn table you can directly connect beam ( because it has pins out like this piece : http://media.peeron.com/pics/inv/custpics/48989.1200267988.jpg.It has a diameter of 3 studs. -Part usage : usefull to create compact and solid axles Part 9 : -Part name :Technic Beam 5 x 0.5 with cruciform holes -Part description : a thin liftarm like this :http://peeron.com/inv/parts/32017?img=21038 with cruciform holes at the extremities -Part usage : pratictal to create solid build Sorry but i don't speak really good english, thanks you to forgive my mistakes. Edited August 25, 2010 by GuiliuG Quote
Superkalle Posted August 20, 2010 Posted August 20, 2010 When it comes to wanted colors, I took a somewhat analytical approach. I parsed/downloaded all colors for some 2000 of the most common bricks from BrickLink. Then I threw them in a database and ran some queries. Basically, I've checked "For the basic LEGO colors, which parts have been produced (in a set) in all EXCEPT one color". Basically I wanted to see if there were any basic color gaps that needed filling The basic colors I defined as: - White - Red - Blue - Yellow - Black - Green - Light Bluish Gray - Dark Bluish Gray And the result was (these parts have been produced in all colors except the one listed): Black 6232 Brick, Modified 2 x 2 with Pin and Axle Hole Blue 2339 Brick, Arch 1 x 5 x 4 Blue 30044 Window 1 x 2 x 2 2/3 with Rounded Top Dark Bluish Gray 2436 Bracket 1 x 2 - 1 x 4 Dark Bluish Gray 3938 Hinge Brick 1 x 2 Top Plate Thin Dark Bluish Gray 4150 Tile, Round 2 x 2 Dark Bluish Gray 48336 Plate, Modified 1 x 2 with Handle on Side - Type 2 (closed ends) Dark Bluish Gray 6215 Brick, Modified 2 x 3 with Curved Top Dark Bluish Gray 973 Torso Plain Green 2449 Slope, Inverted 75 2 x 1 x 3 Green 2453 Brick 1 x 1 x 5 Green 2476 Plate, Modified 2 x 2 with Pin Bottom Green 30237 Brick, Modified 1 x 2 with Vertical Clip Green 3033 Plate 6 x 10 Green 32523 Technic, Liftarm 1 x 3 Thick Green 3455 Brick, Arch 1 x 6 Green 3659 Brick, Arch 1 x 4 Green 3830 Hinge Brick 1 x 4 Swivel Top Green 3831 Hinge Brick 1 x 4 Swivel Base Green 42023 Slope, Curved 6 x 1 Inverted Green 44301 Hinge Plate 1 x 2 Locking with 1 Finger On End Green 44570 Hinge Plate 3 x 4 Locking Dual 2 Finger Green 4460 Slope 75 2 x 1 x 3 Green 4623 Plate, Modified 1 x 2 with Arm Up Green 4855 Wedge 4 x 4 Triple Inverted Green 6178 Tile, Modified 6 x 12 with Studs on Edges Green 6180 Tile, Modified 4 x 6 with Studs on Edges Light Bluish Gray 41767 Wedge 4 x 2 Right Light Bluish Gray 41768 Wedge 4 x 2 Left Light Bluish Gray 42022 Slope, Curved 6 x 1 Light Bluish Gray 45677 Wedge 4 x 4 x 2/3 Triple Curved Red 30136 Brick, Modified 1 x 2 Log White 87580 Plate, Modified 2 x 2 with Groove and 1 Stud in Center Personally, I think the parts in Dark and Light Bluish Gray are highly intresting. Besides those, I generally like to see more parts in the "AFOL" colors such as dark tan and dark green. For example 1x2, 1x3, 2x4 plates etc. I'm not that interested in new parts. I think the pleasure and challenge with Lego is to use the parts that exist in new a creative ways. There is supposed to be some limitations in the LEGO system, otherwise it's no fun Quote
Mark Kelso Posted August 20, 2010 Posted August 20, 2010 Part 1: - Part name: Wedge Tile - Part description: --> A tile verion of wedge plates in 2 x 3, and 2 x 4 sizes - Part usage: --> A tremendous number of builders are now building with a no-studs approach. We currently have no good solution to angles with tiled surfaces, and this part would be an outstanding addition to a very strong trend within the community. Thanks! Quote
legojojo Posted August 20, 2010 Posted August 20, 2010 (edited) Part 1: Part name : 1 1/2 connecting bush with friction Part description : same as 1 1/2 connecting bush, but with friction. It could be black (or other) to distinguish it from the dark grey one. Part usage : It would (finally) make all the connector pegs available with and without friction. It could be used to create smaller and lighter sturdy "studless" technic structures by attaching half beams (using connecting bush without friction makes the whole thing wobbly) Edited August 20, 2010 by legojojo Quote
earthnite Posted August 20, 2010 Posted August 20, 2010 Part 6 Part name: 2x2 Left Part description: this piece but 2 studs long Part usage:for cars, other vehicles, buildings, planes, and everything else ------------------------------------------------------------------------------------------------------------------------------------------- Part 7 Part name: 2x2 Right Part description: this piece but 2 studs long Part usage:for cars, other vehicles, buildings, planes, and everything else Quote
Captain M Posted August 20, 2010 Posted August 20, 2010 Part 1: - Part name: Atmospheric Diving Suit Helmet - Part description: Link. I'd like to see the helmet like this, but without the grill and replaced by a transparent/clear piece in the middle. The rim around the clear section would have points coming up(bad word choice here ) that look like bolts. There's more to the design, though. Link. Think of that piece being attached to the top, like the wookie head piece on the star wars sets. Cut it in half, and add more bolts going down a rim. - Part usage: This part would be extremely helpful to underwater themes. Because of the design, this part can be used over and over again. Think about the new Atlantis sets; seeing a skeleton in this helmet would be awesome. I'm thinking about modeling this part, because it's hard to describe what it would look like. I'll update this post if I decide to preview it. Quote
Scorpion Posted August 20, 2010 Posted August 20, 2010 A most essential point: EVERY SLOPE AND WEDGE MUST HAVE A NORMAL AND AN INVERTED VERSION. My apologies, Bonaparte, if that isn't framed adequately, but I just wanted to get this point across. Quote
JnQ Posted August 21, 2010 Posted August 21, 2010 (edited) i found this pool on flickr. there are a lot of good ideas and pictures for inspiration.... example http://www.flickr.com/groups/708111@N24/pool/ Edited August 21, 2010 by JnQ Quote
JaseTJ Posted August 23, 2010 Posted August 23, 2010 Part 1: - Part name: Centaur Body - Part description: Exactly like a normal Lego horse, but instead of a head, put the two leg things.. similar to 'Brickforge' 's new piece. - Part usage: For Centaurs.. would be great for part of a Narnia or Percy Jackson Lego set. either would be cool with all the myhological creatures. Part 2: - Part name: Fawn/Satyr Legs - Part description: Two legs similar to peg legs, but detailed to look like the back legs of a goat, attached to a normal Lego waist - Part usage: In dark brown, with a male torso (no shirt, scarf), a dark brown bearded 'Rasco' face, and 'Mutt Williams' 's hair for a sweet Mr. Tumnus from Narnia Part 3: - Part name: Dagger - Part description: A Lego blade somewhere in dimension between a sword and a knife - Part usage: great for medieval era creations.. to give a bit of diversity between characters. Part 4: - Part name: Shield(s) - Part description: Some different shaped Lego Shields would be nice, again for diversity.. (different shapes and sizes) - Part usage: same as #3 Part 5: - Part name: 48x48 'Mountain Pass' baseplate - Part description: a 48x48 baseplate with raised mountain sections (raised sections on either side with a winding pass in the middle) - Part usage: an AWESOME battleground Quote
Sekiyama Posted August 24, 2010 Posted August 24, 2010 (edited) Part 1: - Part name: Road plate with Tramtrack Curve 32 x 32 - Part description: Road 1 block thick plate. 32 x 32. Angle is 90 degrees. The tram track has been dug in the middle of the road curved. Tram track with each other tram load plate can be connected with RC(9v)train track. - Part usage: "City" "Module House" further expand the system! Part 2: - Part name: Road plate with Tramtrack Straight 32 x 16 - Part description: Road 1 block thick plate. 32 x 16. The tram track has been dug in the middle of the road. Part 3: - Part name: Power unit for trams - Part description: One-piece power unit for use trams AAA batteries. It is also good if you can not remote control from the ground up "stop" and "turnaround" should be able ("4.5V systems like".) Of course, "RC Train" rail can also run. - Part usage: "City" "Module House" further expand the system! If this system appears to have vibrant city. In addition, the system can also provide low-cost train. Part 4: - Part name: Long hair with a ribbon for minifigs - Part description: Ribbon(Of course, the plastic parts) can be removed and replaced. - Part usage: Girls user can play with minifigs will be a stylish. Part 5: - Part name: Skirt for minifigs(1 2/3 blocks height) - Part description: Skirt part of the current is too high, there is also 2 blocks back. Also, after all, is only a substitute. - Part usage:Girls user can play with minifigs will be a stylish. In addition, you can solve problems better than men tall woman wearing a skirt. Edited August 24, 2010 by Sekiyama Quote
legogirl19 Posted August 26, 2010 Posted August 26, 2010 I'd love to see this mountain bike released as an alternative kind of cycle Mountain Bike I second this idea of a mountain bike, it too, could come in several colors as do the current line of bicycles! Quote
Mr McGow Posted August 27, 2010 Posted August 27, 2010 (edited) Part 1 Part Name: Dog/Wolf 'the Grim' Part Description: Allocated 48812 on Bricklink. I would like to see differant breeds or at least differant colours other than dark bluish gray or reddish brown. Part Usage: Could be used in petshop MOCS, various city MOCS, historic MOCS. Along with cats, dogs are the most commonly kept pets in western countries. Would like to see this reflected in Lego sets. Part 2 Part Name: Tile 2x3 Part Description: standard tile style (e.g Tile 1 x 6), but in 2x3 size. My preferred colours would be white and light blue gray - but obviously this would be extendable. Part Usage: Wide variety of SNOT applications. Eliminates necessity of multiple tiles to accomplish same effect. In my humble opinion would give a much sleeker visual appearance to MOCS. Thankyou for reading and considering Edited August 27, 2010 by Mr McGow Quote
bdw Posted August 29, 2010 Posted August 29, 2010 (edited) Part name: Bicycle forks. Part description: The front forks of a bicycle with a stud on top or a clip so we can make 3 or 4 wheeled bikes that actually have spinning wheels. Beats using a 1 x 1 tap. Usage: We'll be able to make carts or bikes with 3 wheels, etc. Part name: Oriental straw hat. Part description: Those hats that Asians wear in the fields etc. Tan or Dark tan would be great. Oxfords bricks made one but im sure Lego can do better. Usage: An authentic looking hat for our asian scenes. Better than using a radar dish. Part name: Round-about. Part description: 32 x 32 baseplate, similar to cross-roads, with studs in the middle. Usage: teaches kids road rules. Like Lego use to do. Part name: Panel 3 x 3 x 6 trans blue or trans black. Part description: as above. Usage: Gives us angled windows. Part name: Language specific street signs. Part description: A pack of Lego signs in different languages. One language per pack of course. Usage: Kids in Japan can buy a pack of Lego street signs with Japanese writing on them. Adult fans of Lego can buy them from Lego.com or Bricklink to create different country scenes. Part name: Pack of animals. Part description: A box of animals. One pack has Penguins, seals, walrusses (however its spelt). Another pack can have Kangaroos, koalas, platypus. Another pack can have ducks, roosters, swans, peacocks. Another pack can have prehistoric animals: saber tooth tiger, wooly mamoth etc. Another pack can have kamodo dragon, tiger, panda. Usage: endless amounts of usage. Teaches kids about animals. Part name: Umbrella Part description: A closed umbrella for minifigs to carry incase the weather turns (even though it never rains in Lego worlds) Usage: just adds realism which we all want. Part name: Slope corners with pointed eave. Part description: Oriental styled slopes that come to a raised point. see pic from oxford bricks. Usage: so we can make temples or even have an asian restaurant in a downtown lego city. Thanks. We all seem to just want more bits and pieces and more colours to make our lego scenes more realistic. The people have spoken. Up to you now Lego. Stop us from even thinking about deflecting over to lesser brands. Edited August 29, 2010 by bdw Quote
BrickWild Posted August 29, 2010 Posted August 29, 2010 Part Name: Sidecar Part Description: A sleek sidecar that attaches to either side of a motorcycle with a short cross axle Usage: It could double the fun of your police bike for example! Quote
Zerobricks Posted August 31, 2010 Posted August 31, 2010 (edited) Part name: Universal joint with a 2 L axle Part description: One side contains normal universal joint connector, while the other one has no axlehole, but instead has a 2L axle. Usage: Used for shorter LA fixing, in combination with new 7x5 frames for suspension and for smaller mechanisms. Ignore the transparent bit, this part requires only one new mold. The 2L axle is modifyed, so it can couple with the cross. It also should allow for the whole 2L axle length to be usable (nothing should be sticking out). Edited August 31, 2010 by Zblj Quote
Anio Posted September 7, 2010 Posted September 7, 2010 Till today, TLG has been producing many sorts of slopes. But many of them do not exist as inverted slopes. For example, a slope 4x2 inverted and cheesy slope inverted were damn useful ! And that's very basic elements, so, it is totally in "Lego spirit". Quote
Erik Leppen Posted September 11, 2010 Posted September 11, 2010 (edited) I'm not sure this is still open, but I have thought of a few more interesting parts :) Part 8 Part name: Slope Brick 1 x 2 x 1 1/3 Inverted with Curved Bottom Part description: the inverted version of the existing curved slope brick. http://www.brickshelf.com/gallery/ErikLeppen/WishParts/slope_brick_inverted_round_1x2x1_1over3.png Part usage: for the creation of rounded undersides. Part 9 Part name: Technic Beam 31 Part description: straight thick liftarm with 31 holes http://www.brickshelf.com/gallery/ErikLeppen/WishParts/technic_beam_31_and_brick_32.png Part usage: easifies building long structures in sets like 8258, 8285; less room needed for structural part which leaves more room for functional part. Part 10 Part name: Technic Box Beam 5 x 5 with Open Center 3 x 3 Part description the top one in this image: http://www.brickshelf.com/gallery/ErikLeppen/WishParts/technic_box_beam_5x5_and_variations.png Part usage: strong frame for bevel gear transmissions and for structural construction in general. The direction of holes makes it easy to connect to the existing 5 x 7 box beams. Part 11 Part name: Technic Beam 3 x 5 U-shaped Part description the center one in this image: http://www.brickshelf.com/gallery/ErikLeppen/WishParts/technic_box_beam_5x5_and_variations.png Part usage: strong frame for bevel gear transmissions and for structural construction in general. Notice how the direction of holes is the same as the end of the existing 5 x 11 box beams. Part 12 Part name: Technic Pin Joiner 3 x 3 Bent with 5 holes Part description the bottom one in this image: http://www.brickshelf.com/gallery/ErikLeppen/WishParts/technic_box_beam_5x5_and_variations.png Part usage: strong frame for bevel gear transmissions and for structural construction in general. Notice how the direction of holes is the same as in the current pin joiner 2 x 2 bent (with 3 holes) Part 13 Part name: Technic Beam 5 x 7 L-shape Part description http://www.brickshelf.com/gallery/ErikLeppen/WishParts/technic_liftarm_5x7_l.png Part usage: suggestion to "replace" the current 5 x 9 double-bent liftarm with diagonal section, because that diagonal section is always in the way and rarely useful. Also this part was wrongly spotted on the first images of 8052 which made some people enthousiastic, so I think this part is wanted. Part 14 Part name: Plate 2 x 2 T-shape Part description http://www.brickshelf.com/gallery/ErikLeppen/WishParts/plate_2_x_2_t_shape.png Part usage: another way to create half-stud offsets. When used in walls this can create a single 1 x 1 area sticking out for decoration or detail. When used in combination with 1 x 2 plates this can create interesting 1.5-stud intervals. When used in combination with tiself a very strong half-stud offset can be created. See http://www.brickshelf.com/gallery/ErikLeppen/WishParts/plate_2x2_tshape_usage.png Edit, 2010-09-14: a Brickshelf account on the name of Lyyar has pictures of nonexisting parts I think are quite useful too. http://www.brickshelf.com/cgi-bin/gallery.cgi?f=445051 Note: these are not my ideas. Someone else posted them on Brickshelf. Edited September 14, 2010 by Erik Leppen Quote
ghyde Posted September 19, 2010 Posted September 19, 2010 (edited) Survey: New parts and new colors The floor is now yours http://www.bricklink.com/catalogItem.asp?P=4488 Is there anyone else here who would like to see the 1x2 plate extension removed from this element? If they did this, it would come in most handy for making transformers out of cars and other vehicles! Just make it exactly as is in all other respects but without the plate extension! Also useful would be to see this cut into a 1x2 plate with single wheel holder: http://www.bricklink.com/catalogItem.asp?P=2926 Get a modeling program and chop it dead-center between the center two studs on the 4L axis! It would be very handy for wide low vehicles that don't normally run on roads! I do also have one color request, but I don't know if medium blue is in current production - if it is, I'd like to see it come back for this part, and preferably in amounts of more than 2x per set: http://www.bricklink.com/catalogItem.asp?P=6091 While I'm on the subject, I would also very much like to see inverted versions of all curved parts that are not currently made with an inverted counterpart to the curved part! Last, but not least, I have a really radical idea! Inverted tiles! Or flat-bottomed plates if you prefer! Like the "slide shoe" only totally flat on the bottom, and with studs on top! Cheers ... ghyde Edited September 19, 2010 by ghyde Quote
Erik Leppen Posted September 20, 2010 Posted September 20, 2010 Is there anyone else here who would like to see the 1x2 plate extension removed from this element? [snip] Just make it exactly as is in all other respects but without the plate extension! Actually when I read this, before clicking the link I thought you were referring to another part. As your part wasn't the one I expected, let me request one too. I'd like to see the 1 x 2 plate extension removed from this element: http://www.bricklink.com/catalogItem.asp?P=85970 Just make it exactly as is in all other respects but without the plate extension! Quote
The_Customizer Posted September 21, 2010 Posted September 21, 2010 Here is something I would LOVE to see. Part 1 Part Name: Leaf(ves) Part Description: Like the regular plant/vine pieces, but with actual LEAVES. Part Usage: Great for making trees, bushes, and other things Part 2 Part Name: Minifigure-Scale Bush. Part Description: Like the bushes TLC already has, but sized up to minifigures. Or, pretty much, just sized down a bit. Part Usage: Having this enables us to make MOCs that have bushes the real size compared to Minifigures, instead of head high bushes. Or bushes that are knee-high, but don't look like bushes. Quote
BrickWild Posted September 21, 2010 Posted September 21, 2010 Part Name: Plate 1x4 w/flattened towball socket Part Description: Similar to pic below, but 1x4 rather than 2x2. Quote
Emperor Posted October 1, 2010 Posted October 1, 2010 Some parts I could use very very often: Part 1 Part name: No idea... Part description: A plate with studs on both sides Part usage: For complex building Part 2 Part name: Round Brick Tile/ Round tile Part description: A round brick without studs on top/a round tile Part usage: Hiding/Removing the studs from round bricks (just like with normal bricks) Quote
