TheLegoDr Posted February 13, 2013 Posted February 13, 2013 I was just thinking about this earlier. I'd like to see the 1x1 modified brick with 4 studs remolded to with only 2 studs next to each other. So it'd be a mix between the two current molds, one with 2 on opposite sides and the 4 studded one all the way around, only convert it to 2 studs on the two touching sides. It'd work great for corners of buildings or mini builds. Quote
jonwil Posted February 17, 2013 Posted February 17, 2013 I was just thinking about this earlier. I'd like to see the 1x1 modified brick with 4 studs remolded to with only 2 studs next to each other. So it'd be a mix between the two current molds, one with 2 on opposite sides and the 4 studded one all the way around, only convert it to 2 studs on the two touching sides. It'd work great for corners of buildings or mini builds. I concur with this being useful. I would also like to propose the creation of an inverse version of part http://www.bricklink.com/catalogItem.asp?P=3044 Basically you take this part http://www.bricklink.com/catalogItem.asp?P=3665 then remove the 1 x 1 brick worth of material then combine 2 of them together back to back with 2 studs on top. I have a use for a bunch of em in basic colors like red and yellow. Quote
Jargo Posted February 22, 2013 Posted February 22, 2013 Looking at the City square set bus made me think of this: Folding door. Same principle as the garage roller door section but upended. The piece would be roughly six bricks high by two studs wide so that two sections would be enough to make a folding bus door. Or indeed an interior folding door where a building has little space. Two pieces would be required, one with a handle and one without. And to go with those: Six high by four wide door frame with rail. A mix of a normal door frame with the rail from the modified plate with rail. Holes in the inside corners for the folding door pegs of the door section with no handle to attach. Rail at top and bottom to facilitate the sliding open and closed of the folding door sections. One possibe problem with using such a door in a structure rather than on the outside edge of a vehicle is the rail meaning the door has to be raised by a plate height. A solution to this would be designing the extra clearance into the door frame. which would mean the doors being that 1/3 of a brick's height shorter. This would still give regular minifigs enough clearance. Quote
LEGO Historian Posted February 25, 2013 Posted February 25, 2013 (edited) Now that Lego have finally (30 years late!) produced a slope 33 double concave I would like to see it in black, dark grey and red. Duq.... you took the words right out of my mouth.... AMEN to that!!! Also... they can add blue to the color palette. From the grapevine.... I understand that this part will be coming out in sand green pretty soon... but it's not one of the colors that a lot of people have a large quantity of other 33 degree parts in..... Edited February 25, 2013 by LEGO Historian Quote
LEGO Historian Posted February 25, 2013 Posted February 25, 2013 I have a bazillion 2x2 45 degree slopes in trans clear.... and have been adding to this assortment of this size since the 1980s.... it would be sooooooooooo nice if TLG made this part in 2x2 double convex (outside corner)... so that I could actually make a glass pyramid similar to the one at the Louvre... (used as a skylight).... http://upload.wikime...dia_Commons.jpg I don't necessarily need the 1/2 pyramid peaks in trans-clear... a single 2x2 tile in that color would be OK.... but geeze... they've been making those 2x2 regular 45 degree slopes since time immemorial.... it would be so nice to have a nice trans clear pyramid!!!!! Quote
RoxYourBlox Posted March 19, 2013 Posted March 19, 2013 (edited) #60479, Plate 1x12, Dark Stone Gray, Reddish Brown, Brick Yellow - The 1x12 plate is excellent for adding strength to any large structure. It would make sense for it to be available all concrete and wood colors. Edited March 19, 2013 by RoxYourBlox Quote
jonwil Posted April 25, 2013 Posted April 25, 2013 I would like to suggest a window 1 x 4 x 2 size. So basically it would be like the current 1 x 2 x 2 flat front window but twice as wide. It would come in black and white as colors (at the very least) and have glass in trans-clear and trans-smoke and trans-light-blue Quote
CM4Sci Posted April 27, 2013 Posted April 27, 2013 The two pieces needed to fill in these blanks: -Sci Quote
Mr_Malfoy Posted April 27, 2013 Posted April 27, 2013 The new Gothic arches in drk. tan, tan, light grey, drk. grey, and bley would all be very nice to have. Quote
Electricsteam Posted May 10, 2013 Posted May 10, 2013 A new Pneumatic Piston With a Valve Gear for Locomotives. Just a smaller Pneumatic Piston that reaches 3 studs of length of the piston rod when it is extended and it would need the ability to be attached to studs but strong enough not to bend! Quote
Redhead1982 Posted June 14, 2013 Posted June 14, 2013 Although a nice idea, I'm not sure TLG would got make a brick like that, specially as one can use more of the 1x1 bricks with a stud. However, a brick like that would make it easier. I was just thinking about this earlier. I'd like to see the 1x1 modified brick with 4 studs remolded to with only 2 studs next to each other. So it'd be a mix between the two current molds, one with 2 on opposite sides and the 4 studded one all the way around, only convert it to 2 studs on the two touching sides. It'd work great for corners of buildings or mini builds. As the arch is a new piece, I'm hoping for extra colors, too. The new Gothic arches in drk. tan, tan, light grey, drk. grey, and bley would all be very nice to have. Quote
Legomaster34 Posted June 21, 2013 Posted June 21, 2013 (edited) Part Name: Inverted Cheese Slope Part Description: Instead of a hole to attach to studs, a stud to attach to the underside of plates and such. Part Usage: To smooth the bottom of builds, such as creatures, and possibly stylized vehicles, such as space ships. I'm sure it could be used in buildings and other builds as well, but those are the two I find this part would be the most useful for. Edited June 21, 2013 by Legomaster34 Quote
dcastdeclan Posted October 8, 2013 Posted October 8, 2013 They've got mini ball joints, so why not make a similar style like that for the larger ratchet joints. What I mean is that special style that moved in the same way as a ball joint, but smaller. I'm saying a mini version of the joints used for the ninjago samurai mech legs. Quote
Inzane Posted December 9, 2013 Posted December 9, 2013 Parts: Now that Lego have finally (30 years late!) produced a slope 33 double concave I would like to see it in black, dark grey and red. ^ I another vote for this! I was going to post this but scanned the thread first to see if someone had beat me to it. I particularly want this part in black, followed by red. And on the topic of slopes, more variety of parts in the "Slope 18" variety too please! Quote
Lego Otaku Posted December 10, 2013 Posted December 10, 2013 Nice!!! Now I need a 2x2 45° double inverted concave. A reverse of this: http://www.bricklink.com/catalogItem.asp?P=3046a. The closest I can get to it is a 2x2 corner brick and hacked pair of cheese slopes. Quote
Fives Posted December 12, 2013 Posted December 12, 2013 A rounded corner cheese slope. That'd be cool. Also, maybe a variation to the cheese slope so the slope is more rounded. Quote
CardinalBricks Posted December 19, 2013 Posted December 19, 2013 What are some new parts TLG needs to have? I was thinking a 1X1 piece, kind of like a cheese slope, but less angular and more curved. Kind of like the slope of bow slopes. Some of my other ideas are a 1X1 mason brick, a 2X2 round brick but with a Technic pin hole instead of an axle hole, and maybe a glass frame to fit the lattice window frame. Quote
Junpei Posted December 20, 2013 Posted December 20, 2013 I think there's a topic for this. I know it's not a new part per say, but I would love to see Lego bring back thin o-ring 1x1 plates. Those parts are very useful for unusual offsets. Quote
CardinalBricks Posted December 20, 2013 Posted December 20, 2013 I think there's a topic for this. I know it's not a new part per say, but I would love to see Lego bring back thin o-ring 1x1 plates. Those parts are very useful for unusual offsets. Indeed. Quote
emilstorm Posted December 28, 2013 Posted December 28, 2013 -part name: transclear tile 1x1 and 1x2 -part usage: head lights and light bars I found the 1x1 on BL some time ago at a ridiculous price and do not remember ever seeing it in a set. It has always been a mystery to me why this part is not in any set that has a vehicle in it. Quote
TheOrcKing Posted December 31, 2013 Posted December 31, 2013 Off the top of my head, this part in black. Maybe even different colors for this breastplate (like black ). Quote
LEGO Historian Posted January 5, 2014 Posted January 5, 2014 I just spent 15 minutes looking for the existing topic... no luck... ' So here's a new part... Quote
Cult_Of_Skaro Posted January 5, 2014 Posted January 5, 2014 I just spent 15 minutes looking for the existing topic... no luck... ' So here's a new part... Ooh, haven't seen that! It's beautiful! By the way, here's the old topic: http://www.eurobricks.com/forum/index.php?showtopic=45361 Quote
rriggs Posted January 5, 2014 Posted January 5, 2014 What are some new parts TLG needs to have? I was thinking a 1X1 piece, kind of like a cheese slope, but less angular and more curved. Kind of like the slope of bow slopes. LEGO have pretty much done this now with the 1x2 brick with bow that has appeared in many of the 2014 first wave city sets. Although it's 1x2 overall, the base is only 1x1. It's a nice little part. Cheers Rog Quote
SweetiePie88 Posted January 5, 2014 Posted January 5, 2014 I can see 1x1 masons plus mason corners as something desperately needed at times. 1x1 logs and log corners is something I found myself needing in a recent build. Quote
