chewie Posted May 7, 2006 Posted May 7, 2006 well, as a little intorductory into my model, I will give you a little information about this jet. This is my most recent MOC. Countries of Origin France Builder team : Dassault Aviation, SNECMA, Thomson-CSF Length: 50 ft, 3 in (14.36 m) Span: 29 ft, 5 in (9.13 m) Height: 5.30 meters Empty Weight: 7,600 kg Maximum Weight: 16,500 kg Maximal armament weight : 5,900 kg Power plant / Thrust : SNECMA M 53 P2 jet engine / 9.7 t with afterburner Maximum Speed Mach 1,2 [low altitude] Mach 2,2 [high altitude] Rate of Climb: 17,000 m/min Ceiling: Above 50,000 ft / 16,500 m Now, not too bore you guys, I've left out quite a bit of information about this plane. If you're intrested in more of the specs, check them all out here In the pictures of my model taken, I have the following weapons mounted: BLU-107 Durandal (The specs are as follows) Weight: 450 pounds Length: 8 ft 2 in Diameter: inches Guidance: None Control: None Autopilot: None Propulsion: rocket booster to penetrate runway surface Warhead: 330 lb high-explosive I've got two of them, you can read more about this weapon here and the AM39 Exocet (The specs are as follows) Diameter/Caliber: 350mm 13.78-in Length: 4.7 m 15-ft Max Range: 70 km 38 nm Max Speed: 1,112 kph Mach .93 Max Weight: 670 kg 1,477-lb Min Range: 50 km 27 nm Span: 1.1 m 4-ft Warhead Weight: 165 kg 364-lb You can read more about this weapon here I will post deeplinks to some pics as soon as I upload them to brickshelf This is a pic of the full plane, see it here This is a pic of the belly, with the weapons. The weapons from left to right: BLU-107 Durandal, An external fuel tank (not a weapon), an AM39 Exocet and another BLU-107 Durandal check out the pic here As well, here is a nose shot and, lastly, a picture of the tail bearing the French Flag. I did have the Italian flag in the tail, being as Italy does use the Dassault, I did however feel I should put the French flag in because after all, France is the country of origin. You can see it here Quote
xwingyoda Posted May 7, 2006 Posted May 7, 2006 My dear Chewie, Your model looks great !! The Mirage 2000c represents the French aeronautics/military pride *sweet* For those who do not know this slick fighter here are some shots: Chewie, your pics do not do your model justice, could you please take some sharper and clearer pics please !! Tks so much in advance ;-) Fly On !! *yoda* Quote
Jipay Posted May 7, 2006 Posted May 7, 2006 *french pride mod on* Excellent plane ! *french pride off* Your moc is great chewie ! I like the use of the snot technic for the wings. But I have to agree with yoda, the pictures don't seem to do justice to your model Quote
Deinonychus Posted May 7, 2006 Posted May 7, 2006 Niiiiice! Now don't take this as an insult, because it's a compliment coming from me, but it puts me in mind of some of the great Megabloks aircraft they've done in the past several years...I'd buy a set designed like that in a heartbeat! *wub* And it's packing Exocets...that's cool, it can take out some unsuspecting brick warship X-D Quote
chewie Posted May 8, 2006 Author Posted May 8, 2006 Chewie, your pics do not do your model justice, could you please take some sharper and clearer pics please !! Tks so much in advance ;-) Fly On !! *yoda* Ah yes, I would love to get some more clearer pictures, however, my sisters digital camer has no setting for close up shots. I was just at a hobby show today with some other lego guys from the Toronto Lego Group and one of them took some pictures with his digital SLR, so when I get the pics from him, I can post them so that my pictures do give my model justice. Quote
