Use the colour picker tool with the desired colour. Select a group of bricks you want to change then use paint tool on that group.
That doesn't work. Selecting multiple bricks and then painting them only works with colours already in the palette.
Your are correct my UserPalette works only in LDD (normal) mode. I flip back to LDD from Extended all the time mostly to get colors. Also I use text editing on the LXFML file to change large numbers of parts.
Thanks for the tip. Edited by liquidmetalrob
  • Replies 110
Posted Images
It's working. :wink:
This is the example how to colour the arctic truck's tracks with fancy ( :sick:) light green (#14) in 4 steps:
  • 1 year later...
On 7/11/2010 at 11:25 AM, Superkalle said:
Here is the LEGO LXFML reference information for your reading pleaseure. It's been poster earlier in the forum, but here it is in this topic
LXFML5.zip
guys this file is 0kb..........
why?
On 1/11/2017 at 1:25 AM, SubZer076 said:
why?
It seems that the new version of the forum blocks the old attachments if the file type is not among those supported at the present time.
Wait for Superkalle's answer, maybe he can provide you the file before this problem is fixed.
Edited by Calabar
A lot has already been said in this topic about creating reference files with all the decorations in LDD applied according to existing real-life bricks.
I have recently embarked again on this tedious project.
First spin-off is something that has rarely been mentioned: the existence of Minecraft decorations.
Here is a file with current (BV 2248.1) Minecraft decorations applied to the proper bricks.
The file contains the following bricks:
6065593, 6097003, 6097028, 6097029, 6097032, 6103044, 6103105, 6103108, 6103111, 6103114, 6103123, 6162384, 6162386, 6162390, 6162466, 6162469, 6162485, 6162507
  • 1 year later...
Just spotted an unusual trick that isn't documented in the official help files...
For a while now I've been making use of holding down the [Alt] key while dragging a selected part, to quickly make a copy of it (a bit like the clone tool). Seeing as I'd normally used this method to build walls quickly, I hadn't tried leaving the "cloned" part on the grid. Once I did, I noticed that the cloned part expected to "drop" at a half offset on the X and Y axes; in other words, a 1x1 brick cloned and dropped this way will expect to centre itself as if you dropped it onto an 87580. If you do the same thing with the recently cloned brick, it'll take another half X/Y offset and put the newest clone back "in system".
I haven't really found a reason for this particular quirk, and until I find if it's possible to make it add an offset on only one axis, it's probably not a solution for mirroring precisely aligned parts.
  • 7 months later...
LXFML5.zip
Is this file (LXFML5.zip) still available somewhere?
  • Calabar featured this topic
  • 10 months later...
If anyone has trouble downloading LDD files, I have a tip. Open a new tab in your browser, press the right mouse button on a download link, press '' Copy link address '' and in the new tab press Ctrl + V and search to download it will do it immediately.
I hope I've helped!
Edited by NextLevel5523
Hi @NextLevel5523, I guess you use auto translation, could you remember we aren't all polyglots (I mean, I speak Dutch and English, some German and understand some French, but apart from that...). So please translate what you wanted to say in English for all of us to be able to react on.
I think this is what @NextLevel5523 meant:
Quote
If anyone has trouble downloading LDD files, I have a tip. Open a new tab in your browser, press the right mouse button on a download link, press '' Copy link address '' and in the new tab press Ctrl + V and search to download it will do it immediately.  I hope I've helped!
