I own next to none of the sets I built here, although I certainly wish that I did. :laugh:
The render that I always remembered since I first saw it is this one. It's just awesome :classic:
That is ridiculously awesome. *oh3*
  • Replies 2.2k
Posted Images
Yeah, the advancement in compute generated graphics is just awesome these day. But I'm think about photographs and if a rendered image can be made so it is ABSOLUTELY impossible to distinguish from a photo. I mean, if you zoom in on a photo you can always spot small blemishes (color deviations in bricks, dust speckles, finger prints etc). So, I'm basically asking for cases where someone would enter a render in a MOC contest, and it would be completely and utterly impossible to spot that it's a render. Has such renders ever been made?
http://www.indigorenderer.com/content/great-lego-render-schosch
Would you be able to tell, if you didn't know it was fake?
9748 - Droid Development Kit - Model B - R2-D2 (Mindstorms/Star Wars)
R2-D2 DDK.mpd
Errors: Other than the hoses and flexible axles being a bit wonky, no errors.
9748 - Droid Development Kit - Model C - Jedi Knight Droid (Mindstorms/Star Wars)
Jedi Knight Droid DDK.mpd
Errors: The homemade links that open and close the jaws aren't quite in the right position, but other than that, it's golden.
http://www.indigoren...-render-schosch
Great googily-moogily! :wub: We need to get that guy in here to teach us how to do that. It looks fantastic.
8089 - Hoth Wampa Cave (Star Wars)
Hoth Wampa Cave.mpd
Errors:
Wampa uses unofficial parts
No Stickered Parts
Incorrect Helmet and goggles on Luke Skywalker
Incorrect Head Print on the Rebel Pilot
Many thanks to C3POwen, who provided the unofficial parts for the Wampa. The links to these .DAT files can be found in this quote
87562p01.dat - Wampa Body
87564p01.dat - Wampa Arm Right
87565p01.dat - Wampa Arm Left
These parts can be placed into the following folder to avoid mixing them up with the official library: C:\Program Files\LDraw\Unofficial\Parts (assuming that LDraw is installed at "C:\Program Files\LDraw" - for 64-bit Windows it's "C:\Program Files (x86)\LDraw").
8652 Enzo Ferrari 1:17
Ferrari
Download 8652.Dat
Errors:
Missing 30363px11 Used 30363 instead
Missing 30363px12 Used 30363 instead
Missing 4150px21 Used 4150 instead
Missing Stickers sheet
another render
Edit:
a 3rd revision rendered picture.
I think I am finally happy with it
Edited by TotalyWicked
The big error is obviously the lack of an actual Wampa. Poor Chewbacca is standing in for it. :hmpf_bad:
You could try a brick build solution.
For example here there are custom solution for Jabba and a tauntaun.
10197 Fire Engine Brigade ( Modulars )
missing proper length of yellow flexible bar. Had to improvise
missing proper female hair (using the one that is not as detailed, but similar styles.
I tried a few different building techniques with this one.
10197 mpd
6940 Alien Moon Stalker ( Space - Classic )
No errors. This was the first Lego set I ever received. I was 8 at the time and loved putting it together, destroying it, then rebuilding. I still have most of the pieces.
6940 mpd
This will probably be my last post in this topic (and EB) for the next days, because I'm away from my pc. I'll see you all on Friday again! :wink:
Statistics for last release
Records added between: April 21, 2013 and May 12, 2013
Number of sets: 66
...whereof duplicates: 2
...whereof alternatives: 8
...whereof incomplete: 1
...whereof irregular: 3
New Themes added: 4
New contributors
jester - 1 sets
Top contributors
C3POwen - 28 sets
Walter Kovacs - 9 sets
SpaceMan Nathan - 9 sets
legolijntje - 9 sets
juraj3579 - 6 sets
TotalyWicked - 4 sets
Clyde Bum - 3 sets
lego2lego - 1 sets
jester - 1 sets
Making technic models in bricksmith is challenging to say the least, however..
8045 Mini Telehandler - Technic
Download: https://www.dropbox....k8y12r/8045.ldr
Errors: The wheels are not yet officially available as a complete part, so some tinkering was necessary (and that shows)
Edit: Corrected render and .ldr file
Edited by lego2lego
7967 Fast [Power Racers, 2010]
LDR file
Errors:
- Missing Air Blast Launcher
- Missing stickers
7968 Strong [Power Racers, 2010]
LDR file
Errors:
- Missing stickers
7970 Hero [Power Racers, 2010]
LDR file
Errors:
- Missing stickers
7971 Bad [Power Racers, 2010]
LDR file
Errors:
- Missing stickers
5541 Blue Fury (Model B) [Model Team, 1995]
MPD file
Errors:
- Missing stickers
- One of the hinges that attaches the steering rack doesn't quite join, due to the lack of give that real parts normally have.
This render takes advantage of HDRI lighting (which also creates the reflections on the floor and chrome parts), radiosity and slight focal blur.
Edited by C3POwen
I've made a (giant) brick-built Wampa for the Hoth Wampa Cave above. Let me know if you like it. I'm not certain I do.
Brick-built solutions can go two ways, and I personally feel that the wampa is not as strong as the Jabba you used in "4480 Jabba's Palace".
However, about a year ago I exported the body parts for the wampa from LDD (as a lot of LDraw parts are created like this) but didn't do anything with them. I thought I'd tidy them up a bit (fix their position and add a little colour) in case you wanted to use them in your render. Of course, they're not official parts, and I don't plan on submitting them to the LDraw Parts Tracker as they need a lot of work done to them, but for rendering purposes, you're more than welcome to use them.
I also put all of the parts together in an LDR file, along with the Technic pins to attach the arms and croissants for horns (as the tauntaun horns don't yet exist in either LDraw or LDD):
LDR file
Edited by C3POwen
Added 64 bit info
Errors:
I just opened your file and could not find the error you are referring too.
The steering works in the animation console of SR3D,which requires all the relevant parts to be connected probably.
I just opened your file and could not find the error you are referring to.
The actual parts used for steering are joined up, but there are two hinges that are used to attach the steering rack to the chassis, and the one further back won't clip in like it should:
