  • Replies 2.2k
Posted Images
Space / Unitron / 1787 Crater Cruiser
1787
Errors: missing 3626bpx157, used 3262bp69 instead
Errors: missing 2446px4, used 2446 instead
Space / Unitron / 1789 Star Hawk II
1789
Space / Unitron / 1793 Space Station Zenon
1793
Space / Unitron / 6991 Monorail Transport Base
6991
Errors: missing 2890
Errors: missing 2889
Errors: missing 2677 (used 2678 upside down instead (updated file on Brickshelf, didn't change picture)
Errors: missing sticker sheet 168285
Edited by SpaceMan Nathan
If you could render it at 1920x1080, it would make a really nice wallpaper :classic:
I've added 1920x1080 render to flickr for the same picture. :wink:
6887-1: Allied Avenger [space/Blacktron 2 - 1991]
6887.l3b
Errors: None - just some render problem with the sticker (in l3b file ok)
Why does the cockpit color look like normal trans-green, instead of trans-neon-green?
It came from the material library in Blender. As you can see on the other models, the normal trans-green is way too dark. Overall, the materials, especially the transparent ones aren't that good and need some work, but now, I'm more into building models as fixing blender problems.
21021 Marina Bay Sands - Architecture
Download: link
Errors: Tile 1x8 with text "Marina Bay Sands" not yet available. And there is some collision between the dark bluish gray 1x1 plates on the base and the structure. It is meant to keep the building in place, but it must be a very tight fit in the real set.
Better render is forthcoming, transparent plates take some time.....
Edit: Replaced render. Also the two tiles 2x2 round on top of the building should be rotated 45 degrees. Current part does not allow this. This should be a new part which is not yet authorised on the unofficial parts tracker. I will update the .ldr file as it becomes available along with the name tile.
Edited by lego2lego
Another index update! A lot of classic space this time.
Thanks for all your submissions, support and interest everyone! :classic:
Statistics for last release
Records added between: October 29, 2013 and December 3, 2013
Number of sets: 37
...whereof duplicates: 2
...whereof alternatives: 4
...whereof incomplete: 0
...whereof irregular: 1
New Themes added: 5
New contributors
papacharly - 1 sets
Top contributors
juraj3579 - 13 sets
GandalfofHoth - 9 sets
C3POwen - 5 sets
SpaceMan Nathan - 4 sets
marco9999 - 3 sets
lego2lego - 3 sets
papacharly - 1 sets
Here are some small Designer Set sets (an older version of Creator). I have a few more small ones on my PC, ready to be posted. I hope I can make some of the bigger sets somewhere in the next weeks. I quite like them :classic:
4903 - Lion - Designer Set/Creator
4903.png?dl=1&token_hash=AAFt_7Sg1KjJKg0dQ0lYYCX__lriaLurwqFp5UDTqBnwxQ
No errors.
Download here
4904 - Elephant - Designer Set/Creator
4904.png?dl=1&token_hash=AAE1OzYlfSB7pkVtJdiKrZJ_lWZC5IlvPiAW52n6pfe2tQ
No errors.
Download here
4905 - Giraffe - Designer Set/Creator
4905.png?dl=1&token_hash=AAGNayTx0-NRkiA-NddO0yN9p-9aKAd1CIFK5F87M1v9Cg
No errors.
Download here
7910 - Robot - Designer Set/Creator
7910.png?dl=1&token_hash=AAFACbjuGlvGisYX2mdUNDxmnh05Rx4cThhWnDpHr4wOaA
No errors.
Download here
7911 - Tugboat - Designer Set/Creator
7911.png?dl=1&token_hash=AAFw4Z8vgkIsqcSWNG7c7GV-Q2Rm7BCichNV0O362abIhQ
No errors.
Download here
31019 Cheeky Animals (Model A) [Creator, 2014]
MPD file
31019 Cheeky Animals (Model B) [Creator, 2014]
MPD file
31019 Cheeky Animals (Model C) [Creator, 2014]
MPD file
Errors:
- Missing printing
I've cheated a little on the first image and manually created printed eyes on the monkey, but have not included this in the MPD file. The sets will be updated once the relevant part is created in LDraw.
Edit: Updated set names to match that of LEGO.com: http://www.lego.com/en-gb/creator/products/all-models
Edited by C3POwen
10197 Fire Engine Brigade ( Modulars )
missing proper length of yellow flexible bar. Had to improvise
missing proper female hair (using the one that is not as detailed, but similar styles.
I tried a few different building techniques with this one.
10197 mpd
I'm also building this model, but I can't seem to find the right torso's for the firefighters. I believe they are your own creation, or am I missing something? Can't open the actual file because bricksmith can't cope with some unavailable parts (the torso's included, I guess)
They load normally on my pc (LDview and SR3D Builder) so the parts should be somewhere on here. That means they should also be somewhere in the official parts or in the unofficial parts collection. They have LDraw number 973P7V.dat.
If you can't find them anywhere, I can send the .dat file to you :classic:
Thank you for the LDraw number . I have gone through all the torso's multiple times, but it must have been hiding for me :blush: . The model will probably load but the string in the bell tower created an error list longer than my screen, so I couldn't get rid of it....
