___ Posted May 9, 2014 Posted May 9, 2014 (edited) Well, thanks ! I'm beveling every corner of the parts, so you can see this kind of "separation" in between them. I'm using the LGEO library which can give you the possibility to replace standard ldraw stud by marked ones. I'm creating a LGEO parts to replace the ldraw part for rendering, I can then, choose to modify every surface of a part to a grainy one if I want. You're right, I will correct that asap. Thanks for your answers, Darats...now - as of yesterday evening as I finally achieved all I wanted using my LDD/Blender rendering tandem - I see we doing basically the same (although in another SW's) without knowing about each others way of work, nice :) I don't know what software you are using LDD or a LDraw application, but there are some pretty good guides in these forums. I wish to answer your questions but I don't want to "pollute" this thread. Maybe your question can be moved (by an admin) to the relevant forum (rendering LDraw with Povray) and I will be glad to offer you some advice, Thanks, we stay in contact about this stuff as I wrote you...appreciated your suggestions you gave me, they help big time! ;) Edited May 9, 2014 by bublible Quote
Darats Posted May 10, 2014 Posted May 10, 2014 sorry to tell you but NOT TRUE: as I own this set personaly I have to tell youmthat those rear gray tails are BLACK ;) Corrected! Quote
Darats Posted May 11, 2014 Posted May 11, 2014 (edited) Space / Classic Space / 6952 - Solar Power Transporter 6952 Errors : None Edited May 14, 2014 by Darats Quote
lego2lego Posted May 14, 2014 Posted May 14, 2014 (edited) 8860 Car Chassis (1980) - Technic Download Errors: Rubber bands on both chairs are missing as Lsynth doesn't allow for twisting it, and I had to resort to some tricks to get some things right. The rear suspension has to be compressed in order to have all wheels aligned, so the spring is a bit more higher up into the cylinder than physically possible. And due to the "challenging" way bricksmith let's you angle parts, I had to shorten the diagonal part of the steering axle to make it fit. Edited May 15, 2014 by lego2lego Quote
Darats Posted May 14, 2014 Posted May 14, 2014 Space / Blacktron I / 6954 - Renegade 6954 Errors : None Quote
___ Posted May 14, 2014 Posted May 14, 2014 (edited) Space / Classic Space / 6952 - Solar Power Transporter https://farm8.staticflickr.com/7307/14160329821_dd4753ea0b_b.jpg 6952 Errors : None I know I am becoming like the "all.the.time.disagreeing.guy', but... :D ...I have to disagree again: I own this set also beside quantum of other space sets and need to tell you that the yellow hands on the black astronaut needs to be BLACK, not YELLOW ;) Also you need to add more anisotropicity to the gold color...in real LEGO it has metallic shine to it... + tires should have more blackness to them, they are too greyish compared to real thing Space / Blacktron I / 6954 - Renegade https://farm3.staticflickr.com/2897/13996139989_e14f804768_b.jpg 6954 Errors : None Nice, compared to the real thing I have here it looks quite accurate...good work ;) Mainly all those trans parts look amazing, their shine is exact, very good indeed! I'm creating a LGEO parts to replace the ldraw part for rendering, I can then, choose to modify every surface of a part to a grainy one if I want. If I may ask: in what SW are you making your LGEO parts? I could look to it myself too then and decide which way suits my need better ;) Edited May 19, 2014 by legolijntje Removed images to keep page clean Quote
Darats Posted May 14, 2014 Posted May 14, 2014 I know I am becoming like the "all.the.time.disagreeing.guy', but... :D ...I have to disagree again: I own this set also beside quantum of other space sets and need to tell you that the yellow hands on the black astronaut needs to be BLACK, not YELLOW ;) Also you need to add more anisotropicity to the gold color...in real LEGO it has metallic shine to it... + tires should have more blackness to them, they are too grayish compared to real thing This was a mistake, didn't pay attention to it. It will be corrected soon. Thanks for notifying me. I will add more blackness to the tyres, will see how it renders. About the gold color. I will try to improve it later. If I may ask: in what SW are you making your LGEO parts? I could look to it myself too then and decide which way suits my need better ;) I'm re-creating the part from scratch in a CAD software (I'm using CATIA V5), then export to STL, then use STL2POV to make it readable by POV. From that I get a file xxxx.inc with the mesh in it. Then I'm making a lg_xxxx.inc (compatible with the LGEO format) file which will use xxxx.inc and add studs, colors if needed, slope surfaces if needed, etc... To sum up, I have for each custom LGEO part : a xxx.inc file with the geometry inside and a lg_xxxx.inc with the LGEO specification inside. If you want further detail, PM me, or create another topic, not to pollute too much this one. I have around 200 parts like that I've recreated. (quite difficult to share as some with very detailed geometry are weighting more than 50 Mb) This is what I've recreated : here Quote
Darats Posted May 14, 2014 Posted May 14, 2014 (edited) Space / Classic Space / 6952 - Solar Power Transporter https://farm8.staticflickr.com/7307/14160329821_1877df3686_b.jpg 6952 Errors : None Corrected Edited May 19, 2014 by legolijntje Removed image to keep page clean Quote
___ Posted May 15, 2014 Posted May 15, 2014 (edited) Space / Classic Space / 6952 - Solar Power Transporter 6952 Errors : None Yea, now it looks quite exact...but maybe really just add more black to tyres, please, I do not know where you all got it from but THEY SHOULD BE REALY BLACK ;) Edited May 15, 2014 by bublible Quote
Darats Posted May 16, 2014 Posted May 16, 2014 Space / Classic Space / 6970 - Beta-1 Command Base 6970 Errors : None Quote
___ Posted May 17, 2014 Posted May 17, 2014 (edited) Space / Classic Space / 6970 - Beta-1 Command Base 6970 Errors : None Gee OMG...very very nice, Darats, this was actually my very first LEGO set I have got from my parents as a gift at the end of the school in second class...of course having it also today being a part of my Space complex Edited May 17, 2014 by bublible Quote
Darats Posted May 17, 2014 Posted May 17, 2014 (edited) Space / Classic Space / 6971 - Intergalactic Command Base 6971 Errors : None Edited May 18, 2014 by Darats Quote
___ Posted May 17, 2014 Posted May 17, 2014 (edited) Space / Classic Space / 6971 - Intergalactic Command Base 6971 Errors : None Ah, great old memories..this was my second set And again, Darats: very good work, both #6970 and #6971 BUT you made mistake again, my friend: hands on black minifig needs to be black, not yellow Edited May 17, 2014 by bublible Quote
Darats Posted May 18, 2014 Posted May 18, 2014 Space / Classic Space / 6971 - Intergalactic Command Base https://farm6.staticflickr.com/5507/14018662999_d531d7cea9_b.jpg 6971 Errors : None Corrected Quote
___ Posted May 18, 2014 Posted May 18, 2014 Corrected OK, and one more thing: from the picture it is not clear but are you aware of the fact that all slopes there should have the grain on their slew parts INCLUDING PC SLOPE BRICKS? Quote
Darats Posted May 18, 2014 Posted May 18, 2014 All my slopes have the grainy surface. Check my Flickr account for higher res pics. In that case you can barely see it, as the camera is a bit too far away. But believe me, the grain is there. Quote
___ Posted May 18, 2014 Posted May 18, 2014 All my slopes have the grainy surface. Check my Flickr account for higher res pics. In that case you can barely see it, as the camera is a bit too far away. But believe me, the grain is there. Quote
Darats Posted May 18, 2014 Posted May 18, 2014 Space / Classic Space / 6972 - Polaris-I Space Lab 6972 Errors : None Quote
___ Posted May 18, 2014 Posted May 18, 2014 Space / Classic Space / 6972 - Polaris-I Space Lab 6972 Errors : None I see no error this time BUT the blue trans color of the window panes are somewhat too clear or better said "light', when I look at the real stuff here in my collection the color is more darker...except that it looks super as always Quote
Darats Posted May 18, 2014 Posted May 18, 2014 Thanks for you comments. About the colors, I've already spent a lot of time tweaking them. I came to a result satisfying enough for me and I don't really want to change them much. Exept the black rubber one that I have darkened a bit following your advices. :) Quote
___ Posted May 18, 2014 Posted May 18, 2014 Thanks for you comments. About the colors, I've already spent a lot of time tweaking them. I came to a result satisfying enough for me and I don't really want to change them much. Exept the black rubber one that I have darkened a bit following your advices. :) Hahaha, OK and understood...no problem my friend Quote
legolijntje Posted May 19, 2014 Author Posted May 19, 2014 So, here is the next index update. Not a big one (and I wanted to build some model too, but I'm busy working on instructions), but nonetheless a very good update. A lot of space sets this time Thanks everyone for building Statistics for last release Records added between: March 31, 2014 and May 19, 2014 Number of sets: 48 ...whereof duplicates: 17 ...whereof alternatives: 0 ...whereof incomplete: 0 ...whereof irregular: 0 New Themes added: 0 New contributors Darats - 19 sets Top contributors Darats - 19 sets SpaceMan Nathan - 17 sets lego2lego - 11 sets papacharly - 1 sets I was in a helpful mood, so I thought because of the recent space madness here, I'll add this. I can easily see the missing sets, so these are the missing space sets: 1580 1593 6806 6807 6808 6825 6926 6931 6985 897 920 A bunch of UFO and Space Police 3 sets And, (almost) all Insectoids, Life on mars, Alien Conquest, Mars Mission, Exploriens and Roboforce sets The above list of numbers may include sets that are already in the database, but ar US/EU variants. If you spot one, please let me know Quote
Darats Posted May 20, 2014 Posted May 20, 2014 (edited) Space / Cassic Space / 6806 - Surface Hopper 6806 Errors : None Space / Classic Space / 6807 - Unknown 6807 Errors : None Space / Classic Space / 6808 - Galaxy Trekkor 6808 Errors : None Space / Classic Space / 6825 - Cosmic Comet 6825 Errors : None Space / Classic Space / 6826 - Crater Crawler 6826 Errors : None Edited May 20, 2014 by Darats Quote
