  • Replies 2.2k
Posted Images
it s a problems of rendering. More you zoom out, more you lost rendering quality. The model is too higher, so it need a large zoom out.
Edited by recifaliste
If you are using LDView or LDCad to export the OpenGL rendering a common trick is to export in high resolution (e.g. UHD) and then use a quality image resize tool (e.g. irfanview) to scale it to something smaller. This usually results better edge lines. Doing this with or without AA might influence things too.
3300006: The Routemaster Bus (Bricklink) or London Bus (Brickset) - Promotional; LEGO Brand Store Opening Set
LDR File
No Errors!
Note:
The render isn't from the LDraw file, it's from Mecabricks. I render with Mecabricks because i don't know how to create a great render from LDraw.
Hope this isn't a problem.
Edited by KamalMYafi
Add an error Report (Though None)
4 hours ago, KamalMYafi said:
Note:
No, that isn't. I mean, if you render with Pov-Ray, you also don't render the LDraw file, you render the POV file :wink:
As long as everything the image shows is included the file, it's fine.
On a different note: something that is a problem: I can't update the index because of the forum upgrade. So, you all have to be little more patient. :sweet:
Thanks, that's great! :sweet:
BTW, this is an other set:
WHITEHOUSE: Micro White House - Promotional; Miscellaneous
LDR File
No Errors!
Can’t see his feet nor his shadow. I can see a little better on flickr. Maybe it’s the white background here (vs flickr’s dark background) that blinds me.
Changed, hope it's OK now.
7730 : electric goods train set
LDR file
first time i upload a lego set to this forum., never used pov-ray too.
this model is complete with the exception of some missing stickers. this was my first real train set too at witch i need some new parts to make it complete again.
motor still works though after 35 years being in a bag.
model created with LDcad version 1.5
Edited by nnndoh
Hi nnndoh,
Nice model, but the front section of the track (3x2340bc01) is not properly aligned with the rest of track: if you look at the engine, its wheels are not lying on the rails...
thanks. will look into it tomorrow. have an early shift
edit: done, added 2 minifigures and a forklift
Edited by nnndoh
75827 - HQ GHOSTBUSTERS - Ghostbuster theme - 2015
KNOW ERRORS:
WITHOUT MINIFIGS AND THEIR ACCESSORIES
WITHOUT STICKERS replace by similar if possible
WITHOUT PATTERN replace by similar if possible
PARTS MISSING:
11437 Shaft Crown For Helmet x1
25202 Ghettoblaster x1
23421 Pole 32M W/3.2 Shaft x1
23422 Handle For Pole W/3.2 Shaft x1
Download LDR file here => https://www.dropbox.com/s/kau43lr98pud6eh/75827 - HQ GHOSTBUSTERS.ldr?dl=0
10247 - FERRIS WHEEL - CREATOR EXPERT - 2015
KNOW ERRORS:
PARTS MISSING:
18587 Six Shooter Trigger X2
18588 Six Shooter Housing X2
85543 RUBBER BELT X2
LINK TO DOWNLOAD LDR FILE =>  https://www.dropbox.com/s/5qs47xx72bzd8hh/10247 - FERRIS WHEEL.ldr?dl=0
18 hours ago, legolijntje said:
You're working on some big models lately, recifaliste. Nice work! :classic: :thumbup:
thanks, more big sets coming soon ;)
you should use quantity of bricks shared to give the first builder rank of the release :P LOL ;)
