Which LEGO set should I buy? => Object: LEGO set; that's why "which" must be used.
What "no object" should I buy? => No object; that's why "what" must be used.
Tell me whether I've understood. I think I have.
I usually do it the correct way anyway. However, recently I've seen sentences with "what" plus object so often that I felt the need to ask.
I actually signed up at an English forum for such questions, but I'm sometimes quite sceptical in regard to the replies I get there. Sometimes non-native speakers reply and I highly doubt I get an answer I can rely on. And even if a native speaker responds, the answer is often quite perfunctory and not really explained well. But it's different here. You guys know how to help. Thanks a bunch!
  • Replies 131
You've got it :wink:
As I said, the incorrect form is often used colloquially; in time it'll probably be acceptable, unfortunately.
You can trust us pedants :laugh:
In a circus you travel a lot.
=> Here the writer wants to say that as a circus artiste you move from one location to the next all the time, but is the preposition "in" correct or not? What about saying:
With a circus you move a lot.
Again, technically both are correct.
In a circus, you travel a lot. or: You travel a lot, in a circus. (I pretty sure there should be commas.)
Equally the same with the second phrase.
Being "in" or "with" a circus is the same as being "in" or "with" any group. Overall, I'd personally choose the first phrase ("in") as a more natural way of saying it. :sweet:
The second one is more correct, however in a normal conversation the first one is still correct.
She said that trapeze artist was an exciting job.
=> OK this way without an article before "trapeze artist"? I think it is.
She got the job by the circus.
=> I'd say: ...AT the circus.
Somehow this sentence sounds strange:
In the show she has the part which is the most exciting.
=> Correct or not? I'd either say "which is the most exciting one" or "which is most exciting".
PS: Mr Man and Pandora, thanks for your previous replies!
I would say:
Original: She said that trapeze artist was an exciting job.
My take: She said that being a trapeze artist was an exciting job.
The original does make sense, but doesn't sound quite right.
Original: She got the job by the circus.
My take: She got the job at the circus.
The original is confusing, and suggests that she got the job at a venue next to the circus.
Original: In the show she has the part which is the most exciting.
My take: She has the most exciting part in the show...or...In the show, she has the most exciting part.
The original definitely sounds as if it's from a non-native speaker.
Hope that helps. :classic:
=> OK this way without an article before 'trapeze artist'? I think it is.
If you replace 'trapeze artist' with something more down-to-earth (no pun intended) like 'teacher', it sounds odd:
She said that teacher was an exciting job.
Depending on the context, you could say:
Agreed. Unless she got a job next to the circus!
It's technically correct, but I don't think anyone would say that, unless for emphasis:
In the show, she has the part which is the most exciting of all.
A more natural way to say it would be:
Agreed! This way it is pretty obvious that "being" is needed!
Again, you've helped a lot, guys. Thanks!
More questions might follow!
Edited by legotrainfan
What do you say to these sentences:
Here the prison warden is law and order.
=> I'd say: ..is THE law and order. (Meaning: The prison warden sets up his own rules in his prison.)
We will see us on Monday again.
=> I'd say: We will see EACH OTHER...
I'm not entirely sure if I'm understanding you, but if I am then we would say:
"Here the prison warden is the law." and probably leave off "and order"
or you could say:
"The prison warden's word is the law"
but I agree that "the" is required.
Similarly despots have been known to exclaim: "I am the law!"
I agree with you, it is "We will see each other on Monday" and if you want to add in the "again" then it would be:
"We will see each other again on Monday"
"Seeing us" implies both seeing both at the same time (e.g. in a mirror.)
Thanks!
Aren't there two possibilities of where you put "again", either where I placed it or where you placed it? Can another native speaker add their opinion on this matter? It'd be interesting.
That is actually a very fair point, "We will see each other on Monday again" is completely valid, but to me implies that the two involved meet every Monday, rather than have met and will meet again on a day which happens to be Monday.
I'll leave it there as I don't wish to be accused of philosophy again! :wink::tongue:
Both are correct but option B is used more often in casual conversation. Option A tends to be used when emphasis on "one day" is important.
Wife: You need to clean up your LEGO room. It's a mess.
Husband: It's not a mess! I remember where everything is.
Wife: Let's test your memory. When did you find your shiny gold minifigure crown in the couch cushions?
Husband: I found it three days ago.
Wife: You found it one day ago. Where is it now?
Husband: ...
Edited by Arigomi
Version a) is correct. Can you also say b)?
a) I found it one day ago.
b) I found it a day ago.
Both of these are correct, but most people would say, 'I found it yesterday.' The exception would be for emphasis, usually with another word: 'I found it a whole day ago.'
If there's more than one day, then it's obvious: 'I found it two days ago,' but you could also say, 'I found it a couple of days ago.'
All of these are perfectly acceptable.
  • 4 months later...
Native speakers of English, I need your help again! What do you say to the following sentences?
In the next days we drove to Geneva.
=> My suggestion: Within the next few days we drove to Geneva.
=> I don't like the preposition "in" in connection with the past tense. I'd use it for the future: In the next few days we will go there. Or (past tense): On the next few days we decided to...
It is a big city with a chemical industry.
=> Is it OK to say "A chemical industry." If no, what would be the correct version?
We drove to Cologne, where a big cathedral stands.
=> I don't like "stands." I'd say "...where there is a big cathedral."
I agree with your opinion on the use of "in" and "within". If you wished, you could replace "within" with "during" or indeed "over".
If the driving to Geneva took part over the course of a couple of days (as "within" implies it might) then "over" would be the most natural sounding choice.
Chemical industry is correct.
Again, I agree with your opinion that in this form "...where there is a big cathedral" is more natural, however if you wish to expand the sentence, you could say "We drove to Cologne, where a big cathedral stands surrounded by trees/ in a grand square etc." If the intent is merely to state that Cologne has a big cathedral, then the former is more appropriate.
Thanks for confirming my opinions, Pandora!
What about this one:
"We rode with the bikes to the next city."
I'd say: We rode our bikes to the next city.
Again I would agree with you. Saying "with the bikes" implies you rode something else and took the bikes with you.
Just to be annoying legotrainfan, but you can't confirm opinions. As opinions are purely your view, they can't be confirmed as a fact. They can be agreed with, but not confirmed. I know you didn't ask for help but I felt I might as well add my point.
Edit-Actually, ignore that comment. I don't want to open a massive debate on this slightly shady subject. Go on saying what you were saying.
Edited by The Crazy One
Hi guys! Some more questions for you:
Is this sentence correct?
=> I am going to sleep by mum and dad tonight.
I suppose that the student who wrote that sentence wants to say that the kid is going to sleep in their parents' marital bed, as children sometimes love doing.
If the writer wanted to say spending the night in the house of the parents, I'd say: I am going to sleep at my mum and dad's tonight.
Is the tense correct?
=> Every day we were swimming in the lake.
I'd say: "Every day we SWAM in the lake." I don't know if it is OK to use the past progressive for repeated actions in the past.
=> We were in England with the car.
Or should it be: We were in England by car.
Are both of the following versions correct? I think they are.
=> We were by the river.
=> We were at the river.
Thanks in advance for your comments!
