TechnicFan68 Posted January 29, 2011 Posted January 29, 2011 I try to use LDD manager to upload a parts list to BrickLink, but all I get is a single XML tag <INVENTORY> and then nothing... Is there an error in my configuration/model, or am I using LDD Manager wrong? My procedure was as follows: - Start LDD manager. - Import my model - Start step 2 of Upload part list to BrickLink (I have several wanted lists already on BrickLink) - Select my model and set upload parameters to X, Y and "Test" respectively - Enter "1" in Number of models - Enter "3" in MyWanted ListNo (this is actually a bit confusing, is it ID number, name or index number? Anyway, I tried all possibilities with no luck...) - Paste the XML file into the textarea of "Wanted List Mass Upload", which only yields "<INVENTORY>" Software configuration: LDD Version 4.0.20 ; Brick Version 287 LDD Manager Version 0.95 for LDD 4 with Access Runtime 2010 Windows 7 Home Pro The model should be available here: LXF model (be sure to rename it to .LXF) Any help is greatly appreciated, Arild Quote
Superkalle Posted January 29, 2011 Posted January 29, 2011 Strange, it works fine here so I don't know what the problem could be. What happens if you try to paste in Notepad? Regarding wanted listNo, it's the ID (e.g 547865) EDIT: I see now you are using Access Runtime 2010. I haven't tried with that version to be honest. Can you try with the 2003 runtime and see if that works? Quote
legolijntje Posted January 30, 2011 Posted January 30, 2011 (edited) Strange, it works fine here so I don't know what the problem could be. What happens if you try to paste in Notepad? Regarding wanted listNo, it's the ID (e.g 547865) EDIT: I see now you are using Access Runtime 2010. I haven't tried with that version to be honest. Can you try with the 2003 runtime and see if that works? Yes, whit runtime 2010, it doesn't work (not at me). But if someone install runtime 2003 and he has 2010, he maybe get problems whit both runtimes (it happened whit me) Edited January 30, 2011 by legolijntje Quote
Superkalle Posted January 30, 2011 Posted January 30, 2011 OK, thanks for the info Legolijntje. I'll look into it. Quote
lgorlando Posted February 2, 2011 Posted February 2, 2011 OK, thanks for the info Legolijntje. I'll look into it. Great, It wasn't just me then. I got a new computer recently and it has runtime 2010 and I haven't been able to use the export list for bricklink. Just a blank <inventory>. Doesn't paste in note pad either. There is hope... Quote
