Posted January 31, 201114 yr Hello all ! I tried to modify the set 6743 Street speeder LEGO CREATOR to put a minifig inside... I hope you'll enjoy this MOD. The part used are only the parts you can find in the set 6743. The minifig come from the set 7279 (new collection LEGO Police). Edited January 31, 201114 yr by Lumpy03
February 1, 201114 yr Author Great Mod! But 10 studs is pretty wide?! Right, 10 studs is a little wide so i'll try to do a best MOD next time in max of 8 studs.
February 1, 201114 yr Not bad.....not bad at all 'Lumpy03'......I also feel 10 wide is a bit much even for a hot rod. Great work anyway and Brick On 'Lumpy03' !
February 1, 201114 yr Author Not bad.....not bad at all 'Lumpy03'......I also feel 10 wide is a bit much even for a hot rod. Great work anyway and Brick On 'Lumpy03' ! Many thanks ;)
