Posted February 15, 201114 yr So I was wondering if anyone had ever built a Lego Dome. Because I am working on a HP ravenklaw room and that requires a dome. I could use those Prince of persia pieces from the Temple to have a golden dome on the outside but having the effect on the inside would be awesome!
February 15, 201114 yr It really depends on how large you want it. The Lego Taj Mahal has a dome, perhaps you can reverse engineer it.
February 15, 201114 yr I should of thought of that. Check the lego Customer service page. There should be a place to locate instructions.
February 15, 201114 yr Easiest way is to use a Bram's Sphere Generator. Input a diameter, and the script will generate a .ldr file of a sphere similar to this.
February 15, 201114 yr You could use this piece (http://www.bricklink.com/catalogItem.asp?P=43086) upside down, but only for the interior. You should build something different for the exterior.
February 16, 201114 yr If you make the bram style sphere, you could cover it with lego sails the way TLG did with the Grand Carousel
