Too poor to get a cool, shiny UCS Y-wing starfighter?
Well, I got a solution.
This y-wing uses a lot of parts from the TLC's 7658 set. However, it is much bigger.
It's supposed to be between the UCS and the "regular" set.
Here's a cockpit closeup.
On this picture you can clearly see it's a work in progress, since the left engine (when you look from the rear) isn't completed.
Here's the R5-D4 unit.
Rear view.
Please comment.
Wow, this is a really nice mod WIP. I like what you've done with the flick-fire missiles as well as the added greebling and the corrected astro-droid socket (though I would recommend that you just leave the legs out, as they are obtrusive). Overall I like the way this is headed.
A few things I would suggest:
- Make the engine nacelles larger - 6-wide domes are closer to the correct size.
- Shrink the cannons in front - the gun pieces don't look all that great.
- Make your own canopy - the LEGO version is too blocky.
- Greebling can make or break a good Y-wing. For effective greebling, follow the source material.
Oh, and one more thing - if the Y-wing seats one, it's a BTL-4A - if two, a BTL-S3.
Edited by fallenangel309
It looks awesome! :thumbup:
I guess I was lucky enough to see it at your house.
Since I told you my opinion there, I don't need to repeat how good it looks again. :laugh:
