kyphur Posted May 7, 2011 Posted May 7, 2011 I'd like to see what everyone is doing for the bumper blocks at the end of track... Quote
mikka says Posted May 7, 2011 Posted May 7, 2011 a couple of 2x4 bricks and a coupler with no magnet usually does the trick (thanks to the old couplers) but a PF one could lock the cars into place if you make it a siding ;) Quote
dr_spock Posted May 7, 2011 Posted May 7, 2011 I use a couple 2x2 bricks and a 2x2 plate which put the bumper at the right height. Quote
mpec82 Posted May 7, 2011 Posted May 7, 2011 A modified (1 stud longer is more stronger) version of CaL Luetjens BUFFER STOP. Quote
Treadwah Posted May 7, 2011 Posted May 7, 2011 The one from railbricks mag. With the rubber band to ease a bit of the force. Quote
AllanSmith Posted May 7, 2011 Posted May 7, 2011 Heres a link to spring loaded buffer stops I built in 1998 (13 years ago ) Photos taken in the days of film cameras and flat bed scanners. Quote
The Yellow Brick Posted May 9, 2011 Posted May 9, 2011 I haven't really used anything for a bumper. I did use the one which was in the rail bricks magazine. After a while I did take it apart but now all I use is a pile of bricks . I want to make a proper bumper, Which looks realistic. Quote
patje Posted May 9, 2011 Posted May 9, 2011 on the link below you see line bumper blocks from several builders bumper bloks Quote
Duq Posted May 9, 2011 Posted May 9, 2011 I've yet to come up with something decent myself but these two are the best I've seen sofar: Both are by Karwik, on Flickr. Quote
jaster Posted May 11, 2011 Posted May 11, 2011 Heres a link to spring loaded buffer stops I built in 1998 (13 years ago ) Photos taken in the days of film cameras and flat bed scanners. The spring is very clever. I should like to modify it so that it looks more at home in North America (no buffers), but still retains the spring idea. Quote
Piranha Posted June 13, 2011 Posted June 13, 2011 Railbricks Issue 7 has a really nice one that is rather clever as well. (Page 10) I will have to make some of these nice ideas. Quote
Snapshot Posted June 14, 2011 Posted June 14, 2011 (edited) I'd like to see what everyone is doing for the bumper blocks at the end of track... If it's just decorative I use the one from BlokBricks but it's not very strong so, if I really want it to stop a train, I use a large pile of bricks.... Edited June 14, 2011 by Snapshot Quote
iDave Posted June 14, 2011 Posted June 14, 2011 I use this one, not the most beautiful thing, but it does the job Quote
LEGO Train 12 Volts Posted June 15, 2011 Posted June 15, 2011 For the 9 volts I use the solution proposed by Blokbricks in the accessories section: "spring buffer" Fot the 12 volts I use this solution (from the set n. 149) Quote
BillytheKid Posted June 15, 2011 Posted June 15, 2011 I used springs, for real stopping if it goes wrong. Here the design of how it works and it works perfectly. They stop the train with slow speed. Here at bottom-right you can see where I used them: And at the end of those 4 trains, they're placed: Quote
Pet-Lego Posted June 16, 2011 Posted June 16, 2011 I used springs, for real stopping if it goes wrong. Almost the same design as I am working on, got 8-10 spare springs and what you have shown here is about 90% my intention. Nice work. Quote
Piranha Posted June 17, 2011 Posted June 17, 2011 For the 9 volts I use the solution proposed by Blokbricks in the accessories section: "spring buffer" do you have inventory or instructions for it? Quote
peterab Posted June 17, 2011 Posted June 17, 2011 (edited) do you have inventory or instructions for it? Blockbricks sells the instructions, at the link he gave. Edited June 17, 2011 by peterab Quote
Piranha Posted June 17, 2011 Posted June 17, 2011 Blockbricks sells the instructions, at the link he gave. I didn't see them it was the whole model. But I made a lxf LDD file already. Quote
Chumley Posted June 19, 2011 Posted June 19, 2011 This is what i came up with for the end of the line. Flickr Quote
JopieK Posted June 19, 2011 Posted June 19, 2011 do you have inventory or instructions for it? Well, they are easy to build, but they are not very realistic are they?!! Here are some real ones for inspiration: http://en.wikipedia....iki/Buffer_stop Here is my interpretation: Quote
architrains Posted June 19, 2011 Posted June 19, 2011 Until I grow my Lego collection some more I just use two 2x4 bricks staggered up over one rail as a makeshift wheel stop/derail. It works well enough at low speeds. Quote
vgsprites Posted June 20, 2011 Posted June 20, 2011 I got a light gray buffer beam awhile ago in a mixed train piece auction off eBay. So I put it to some good use: It keeps my 4563 in check on my only sliding with the rail cars on the 4 pieces of PF straight track and the 9 Volt engine on the powered switch. Quote
marook Posted April 2, 2015 Posted April 2, 2015 Hi All, Wanted to make one, had to use the bricks available. It's a version of the RailBricks v7 edition with elastic bands to soften the stop if needed. As you will notice, I had some Old Technic parts, that allows for added details, but they don't seem to be available in LDD.. :-/ The details, with parts available there, is here: Spor Bumber 02.lxf More pictures is available here: https://www.flickr.c...157651283746389 Quote
legotrainfan Posted April 2, 2015 Posted April 2, 2015 I bought lots of bricks to build bumper blocks that look like the one in set 4512, which I also have. I used white and red 1x2/2x2 tiles for the two printed 1x4 tiles that come with set 4512. Most of my bumper blocks have been disassembled. My train layout is very small at the moment. Quote
