October 1, 201212 yr On 10/1/2012 at 8:47 PM, bb15080 said: your video has been blokked here in the netherlands And for those in the uk. Edited October 1, 201212 yr by Alasdair Ryan
October 2, 201212 yr Author I'm sorry, they blocked it because I used Ozzy's song. Now it is without music and are functional.
October 2, 201212 yr @ Tomik: You have the knack for building alternates of official Lego Technic sets!
October 23, 201212 yr Author After many grohl's alternates from set 8052 I'm adding one mine again - forklift truck. I have to admit that I've used one non-lego part - about 30 cm long thread. And what does this truck feature? motorized fork lifting via winch with thread (M-motor is used both for driving and braking forks) mast tilting via hand-operated linear actuator bearing capacity at least 250 g - I had to add little reinforcement that is not visible in pictures yet because mast was bending under load rear axle steering easy battery box removing many little details like steering wheel, seat, rearview mirrors, joystick for operating forks etc. I've also used few interesting structural tricks - crossing of steering axle and linear actuator driving axle without using gears and steering is made also without using any gear (except that 20 teeth double bevel gear on roof). I plan to do some little improvements during making building instructions. I'd like to add few lights (transparent round plates) and solve problem with lack of pins. And finally there are pictures here: And short video is here: Edited November 6, 201212 yr by Tomik
October 23, 201212 yr It looks beautiful I really like the blue. Are you sure this is an set alternate ?
October 23, 201212 yr Author On 10/23/2012 at 5:52 PM, legolijntje said: Are you sure this is an set alternate ? Yes, I am. It was built just out of set 8052 plus piece of thread so it is alternate. Edited October 23, 201212 yr by Tomik
November 5, 201212 yr Author Building instruction for RC hot rod is available at buildinst now and forklift truck video is coming soon.
December 28, 201212 yr Author Santa was little bit late this year so building instructions for forklift truck built out of set 8052 are available on buildinst only now.
April 1, 201311 yr Author It's Easter time and I've decided to celebrate it by publishing building instruction for Easter bunny built out of set 8048. Now you can build 3 different rabbits with help of buildinst. Happy Easter !
April 6, 201311 yr Author I'm back with new alternative model build out of set 9394. I've built another crazy animal - red shark. I have been thinking about building fish since TSATS contest was announced. So this shark is moving its tail and opening maw when it is moved around. I've used modified mahj's mechanism from his for shark tail.Video is coming soon. Edited April 8, 201311 yr by Tomik
April 7, 201311 yr On 4/7/2013 at 8:55 AM, VFracingteam said: It's flying under water :thumbup: i wonder if it flys as good as this underwater one! http://www.eurobricks.com/forum/index.php?showtopic=79893
April 8, 201311 yr Author Thank you for your positive cemments! I appreciate them and I've also added video.
May 28, 201311 yr Author I've finished new alternate of set 9393 few weeks ago. It is small helicopter with retractable landing gear and moving rotors. With retracted landing gear Little view inside
