MAB Posted October 21, 2019 Posted October 21, 2019 15 hours ago, Hive said: I've been having this problem more and more lately. Currently, I have a head stuck on a torso (put together brand new) water (both hot and otherwise), cold nor heat can help me with. Did anyone ever find a good solution for a fix that does not cause scratches or other deformations to the head? Pliers, but put some foam rubber (cut from craft sheets) in the jaws. It gives excellent grip and doesn't scratch. Quote
Hive Posted October 21, 2019 Posted October 21, 2019 9 hours ago, MAB said: Pliers, but put some foam rubber (cut from craft sheets) in the jaws. It gives excellent grip and doesn't scratch. I was reluctant to use pliers, but this worked. Thanks. Quote
MAB Posted October 22, 2019 Posted October 22, 2019 13 hours ago, Hive said: I was reluctant to use pliers, but this worked. Thanks. Yeah, so long as you have some padding in the jaws it helps grip the parts without allowing them to slip, but also stops scratching. Quote
