  • Replies 2k
I agree with you while the mog is cool and I love it. all these attachments remind me more of a tractor I guess it more of a European thing having a truck with attachments. It would be awesome to see lego partner with John Deere and come out with John Deere green pieces and build either a big crwaler tractor or an articlated wheeled tractor but that might just be the farm boy in me.
heh....... i'd rather see a Massey Ferguson, Claas or maybe a Fendt :P
i personally don't like John Deere :P
hope these help..set up to use a small pneumatic piston
Looks good has anyone tryed it yet?
Just a question, would technic half pins work for improving the steering of 8110 with out touching the chassis?
Yes they work perfect and I'm using them,gives u a better lock without over doing it!
NXTified Unimog by Anika
Unfortunately the new 4.2.5 version of LDD still not contains the unimog steering parts 92908 - 92911.
The bright yellow parts in picture and lxf file only place holders.
LDD file
Next I will place the nxt modul into the chassis.
Here the attempt:
LDD file
Edited by PeterleB
Hi everyone,
I'm just new to EB.
Recently I bought the 8110 and in love it. Now I'm planning some add ons. First of all I ordered the whole parts for the snowplow at BL.
Next is a little trailer.
Further I'm trying to combine those two mowers...
So far
Pat
Edited by Pat-Ard
thanks for your welcome.
Yes, for sure... but I'll try this on the original model, just to find the most realistic look. And then "rebuild" it on the LDD. I'm still clean on a good idea for a flashing arrow in the upper frame.
Btw: how many pneumatic cylinder can I use with one pump? If I really can combine those two mowers I need about 5 pneumatic cylinders. Would be an air tank a solution?
So far
Pat
Edited by Pat-Ard
Here al mine UNI :wink: -MOCs
Greetings Edwin
I love your fire truck!
See earlier posts. I tried a ldd file.
Edited by PeterleB
Please dont quote the pictures repeatedly, it takes up a lot of space on the webpage and causes a lot of unnecessary scrolling.
@Pat-Ard
what i said was only an approximation. i meant that simultaneously you could run about 2-3 cylinders at a time. But you could power a lot more cylinders if you are not using the switches at the same time.
tim
Edited by timr
Hi everyone,
I'm just new to EB.
So far
Pat
Very nice!
Edited by PeterleB
PeterleB --> WOW!!! Good idea with the frame. I'll try it and post an update. I already had the idea of the clear 8 by 8 square plate, but it's not very good looking. My blue sign is mounted on a turntable, so the sign can be turned to the left and right.
@timr: Thanks, hmm, might be an option... But I'm just evaluating to add a second pump. I'll try to work it out.
again @timr: yes, some posts up it showed a picture of the trailer...
Only problem left are the fenders... Any ideas?
So far
Pat
Edited by Pat-Ard
So far
Pat
A simple test
PeterleB: tried the fenders, but no, doesn't work/look good.
Tried something with the parts 61070 and 61071. But they won't fit either... :hmpf_bad:
And tried some more... YIIIIIHHHHHHAAAAAA...
:grin:
So far
Pat
Edited by Pat-Ard
Maybe you could try building it out of Yellow or Orange, although I suspect Organge won't have some of the parts. Looking on the internet, it seems to be mostly this colour. Just a though, you could use them bendy beams used 8070 or similar, not sure what people call them, but the things that make the wheels arches.
