dr_spock Posted July 27, 2016 Posted July 27, 2016 I added a motor to the HOG steering. I have since reused the steering m-motor in a GBC module. Quote
Rishab N Posted July 27, 2016 Posted July 27, 2016 (edited) Not sure if its accurate to the real truck, but I rebuilt most of the rear axle to put in Sariel's 3 stud wide differential lock. I changed the mounting point for the towball after taking pictures as it was interfering with the gears Now to figure out how to do this on the front axle Edited July 27, 2016 by Rishab N Quote
MRP_ Posted July 27, 2016 Posted July 27, 2016 I probably should have looked it up before ordering it, but how make of those transmission setups does it come with? like, a setup being the 2 end gears, switch, and slidey thing in the middle? yes I know that sounds funny, I don't know the terminology and can't be bothered to look it up. Quote
Imanol BB Posted July 27, 2016 Posted July 27, 2016 That Diff-lock mod is amazing, now, for the front axle it will be a very hard way to make it, but it looks good. Quote
Imanol BB Posted September 2, 2016 Posted September 2, 2016 i have made some small improvements to my moded cabin, now it doesn't need any custom sticker to get an enough realistic grille: I know it doesn't look as you may expected, but that is because LDD, and in real life the 2x2 tile is placed in an "ilegal" position, i will try to post the real life picture soon (the LXF file: http://bricksafe.com/files/imanol/unimog/cab-v3/unimog%20u400%208110%20cab%20v3%2009-01-16.lxf) I have also started to make some "accesories", so far i have made an air conditioning, some roof mounted headlights and 2 (possibly train) horns, any suggestion to improve these accessories or to make other ones is well received: LXF file: http://bricksafe.com/files/imanol/unimog/cab-v3/unimog%20u400%208110%20cab%20v3%2009-01-16%20accesories.lxf Let me know what you think. Quote
Imanol BB Posted September 26, 2016 Posted September 26, 2016 (edited) Hello again, after many time watching some Unimogs, specially the series of the U400 and U500, i realized that none of the previous Mod´s that i made weren't enough to match the real shape of the Unimog, and i decided to make a drastic change in that, so here is the current model rendered in Bluerender (special thanks to Gabi_BC for helping me to finally install it): The first improvement i made was in the axles, as i wasnt satisfied with the wheels turning pivot i made a new system which uses knob gears based in Didumos69´s knob wheel drive axle, which lets the pivot point to stay 2 studs closer to the wheel, this also required some extra reduction from the differential with a 12:20 relation (Because the previous 1:3 reduction was removed to improve the turning pivot), this also made the planetary gears to have half stud less of clearance under them, but it is not a big problem because the overall clearance was improved with the removing of the previous gears: The final steering angle is about 30 degrees (After some testing, i found that the tires don´t collide with the chassis, even when compressed): I also added an axle guidance in the front axle, i borrowed this idea from Efferman´s Unimog UHN, and it resulted to work pretty good: A good thing is that i successfully kept the anti-roll bar system, it is the crossblocks connected to the connector with crossaxle: About the cabin, i changed many things, the front was heavily modified to be similar as possible to the real Unimog front angles and shapes, the turning lights are bigger and more vertical, the cab also ends 1 stud lower and the hood is 1 stud bigger: I also improved the locks, now they are easily accesible (I hide some parts to make the mechanism more visible, this part is actually much more reinforced): The mudguards were improved too, instead of the curved liftarms, i used curved axle connectors, and because wheels displacement is less, the mudguards are very close to the tires but they don´t collide too much, but if they do, the have a flexible design which lets the tires to keep their way, this also let me put the ladder 2 studs forward: The mudguards look a bit weird in LDD because they are not connected, but they do in real life, the other thing that has been one of the most important goals is to make all of this MOD´s with the cheapest parts as possible, i have changed all the 5L liftarms with 3L liftarms and 2L ones with axle hole, and like this many other improvements, other thing that you might see is that there are a few details which are not of the U400 but of the U500, like the lateral mounted lights and the roof small orange lights, i did this as the U500 sometimes has more cool details than a normal U400, but you are free to tell what do you think of this; so, the remaining functions and details needed are: Create a connection for the cabin and the chassis to enable tilting (Yes, i needed to remove the old mechanism and a improved one is required because of the new cabin design) Create a new mechanism in the cargo bed to allow the walls to drop Improve the rear mudguards Add an axle guidance to the rear axle Add a new exhaust pipe because the old one doesn't fit with the new cabin locks Make new mounts for the headlights Improve the rear part for better looking I hope you like it; as always, any suggestion in welcome. Edited October 3, 2016 by ImanolBB Quote
Imanol BB Posted September 26, 2016 Posted September 26, 2016 2 minutes ago, JJ2 said: Great MOD do you plan to build this? Yes, i am planning to build it (Or at least that is what i hope ), that is why i am doing my best to make it not too expensive, my main calculations are that all the parts to make this MOD from the standard version would cost about 350 to 400 Dollars,150-200$ in PF components (1 battery box, 1 IR receiver, 3 switches 4 L-motors and 2 XL-motors) and others 200$ in the remaining pieces, of course that this would be that expensive if you only have the 8110 and no extra pieces, but if you have many spare parts the cost can be drastically reduced. That U500 looks amazing Pat, the double cab and the extended chassis are really great details, i also see that you kept the the round plate for the MB logo on the hood, i wasn´t sure if the U500 should have or not the logo, but looking at your model and that the logo would still look good i think i will keep it. Quote
Pat-Ard Posted September 26, 2016 Posted September 26, 2016 Thanks... Wanna see some more? :) Some pieces are missing... Meanwhile I changed the round tile to a black one with a Mercedes logo... Quote
Imanol BB Posted September 26, 2016 Posted September 26, 2016 What a beautiful collection, i wish that i could get a collection of that size in near future, they look really amazing, maybe you could try to make one of those futuristic Unimogs, or one of those old Mercedes Benz Trucks; i really love how all those vehicles look together. Quote
Pat-Ard Posted September 26, 2016 Posted September 26, 2016 Thanks... No, those futuristic concepts are fugly... The last MOCs were this: Oh, and here's a picture of the printed tile :) Quote
Imanol BB Posted September 26, 2016 Posted September 26, 2016 Oh God, those windshield cleaners, i knew there was something missing in my mog, all those those details are very awesome, they give a lot of inspiration. Quote
Pat-Ard Posted September 26, 2016 Posted September 26, 2016 Glad you like it... If you want more pictures, just contact me via PM... Quote
Imanol BB Posted September 26, 2016 Posted September 26, 2016 Thanks for the help and the inspiration Pat, i will see if i can make some progress on my mog (And add those windshield cleaners) Quote
Pat-Ard Posted September 27, 2016 Posted September 27, 2016 The whole family story can be found here: my unimogs This is my favorite german forum... Quote
Gabi_BC Posted September 27, 2016 Posted September 27, 2016 15 hours ago, Pat-Ard said: ^^^ This thing, is there a thread for it or anything? It looks very interesting, i like it. Quote
Pat-Ard Posted September 27, 2016 Posted September 27, 2016 Hi Gabi, this thing is a WF trac 6x6s. Here's the link to the thread here on EB: http://www.eurobricks.com/forum/index.php?/forums/topic/118223-moc-wf-trac-6x6s/ There's also a detailed one on doktor-brick... WF trac Quote
Imanol BB Posted September 28, 2016 Posted September 28, 2016 I have finished the windshield cleaners, they are very similar to Pat-ard´s ones and they add a little bit more of realism (despite they are only for display), thanks to Pat for the inspiration: I have also made some small progress in the cabin tilting system, but it still needs a locking mechanism; and i find something great in YoutTube, it might give a little bit of inspiration for some builders: https://www.youtube.com/watch?v=R53WpYOkeCY Quote
Pat-Ard Posted September 29, 2016 Posted September 29, 2016 (edited) Looks good... Edited September 29, 2016 by Pat-Ard Quote
therealjustin Posted September 29, 2016 Posted September 29, 2016 On 9/26/2016 at 4:28 PM, Pat-Ard said: Oh, and here's a picture of the printed tile :) Can you please share how you attached the tile? Every solution I have tried in LDD is terrible :D Quote
Imanol BB Posted September 29, 2016 Posted September 29, 2016 I think that this is what Pat does: You must use specifically this round tile to make it work: http://rebrickable.com/parts/14769 Quote
Pat-Ard Posted September 29, 2016 Posted September 29, 2016 4 hours ago, ImanolBB said: I think that this is what Pat does: exactly :) Quote
Imanol BB Posted October 1, 2016 Posted October 1, 2016 (edited) Does anybody have an idea for a dropping sides bed? i know there are very simple designs, but the main problem here is that the bed has the same width of the mudguards, and it is not possible to make the pivot points directly under the sides: I have made an small experiment that could work, it uses sides built in two parts to enable them to bend above the mudguard and this way they cab be of the same width without colliding when they are dropped; but it is a bit ugly (and with "a bit ugly" i mean very very ugly and not very realistic): So, if you have any better system or you know a way to make this one better, or at least to look not that bad, i would really appreciate it. Edited October 1, 2016 by ImanolBB Quote
