  • Replies 49k
  • Flipz
    3840
  • Endgame
    3508
  • CMP
    3190
  • Zepher
    2635
Posted Images
When a Witch is healing and rolls a shield, what should happen, Sandy?
I'm not sure if Sandy has ever said anything specifically on this, but shield is always shield no matter what. Look at it this way, if a mage is using a spell instead of physically attacking and they roll shield, they still get a magic burst. Same with clerics, it doesn't matter if they're attacking or healing, a shield roll grants a miracle. So in a witch's case, even if they are healing, a shield roll grants a hex (or whatever it's being called these days).
Edited by Waterbrick Down
This probably is not going to be game-changing, regardless of the answer, but at the end of quest 32, Mizuki's dagger was envenomed. It's been upgraded since then, but hasn't been used in a fight. Is the venom still on it?
I believe rumble said yes. I'll go fix that.
QM NOTE: thank you all for signing up! Please make sure all the stats are correct. Palathadirc, what does the arm-mounted shield do, and what is the explanation behind the (+1, +1) in front of your health? I couldn't find the shield in the treasury, sorry. :blush:
That is the explanation, and it's in there. :sweet:
What element are beasts weak to? Wood?
Fire and Ice, usually. Nocturnal beasts (slightly different, type being used for the proggs) are weak against fire and light and strong against light and ice.
"I have my reasons for desiring a healing staff, but seeing as none of you have it, I shall go."
You cannot post in the Hall; you are on Quest #36. The Party has already left. :wink:
Unless, of course, Eric is speaking on your behalf. Where is he, anyway?
He has yet to post in the quest topic, it's fine.
