  • Replies 909
Posted Images
New instructions for the digicomp, I had plenty of demands, so this is :
Many thanks to Kevin Williams who has done a beautiful work on it. There are for sale at 5€ but there are also a free one based on conprehensive photo sequence :
But note that kevin has made a brilliant work also for improving the functionning and reliability of the digicomp and included also some program to run.
http://www.nico71.fr/lego-computer-digicomp/
Edited by nico71
13 hours ago, nico71 said:
lego under X-ray
That's a great idea, i love such images.
Have you uploaded them somewhere for us to download or should we screenshot from youtube?
Could you make images of the mechanics too for your next video?
This is very interesting. Do you think it would be possible to convert this bunch of photos into 3D model using Autodesk' 123D Catch. I have experiences only with non-see through objects. But X-ray pictures might confuse the program. Does anybody knows about freeware program that can made 3D models out of X-ray pics?
Hello, this is 150 to 230kv Xray generator which is made for view plastic and soft metal or strong metal until 20mm of depth. It is put in a leaded cabin. It is production machine we develope and produce except the generator and flatpanel which are bought.
For the pictures, you can find it on my blog in high resolution. For the mechanism, I will.
I am planing to pass small wind up motor, chinese parts, and axle.
For converting the 3D, it is in fact many many point in aera (STL), the standard tomography is about 1go to 10go but the 3D will be exact and real part, that is to say that the surface are not flat and hole perpendicular like in theorical part in ldraw, therefore it could be difficult to implement in a construction because of that.
A write the whole story of that moc on my blog so I copy paste here, I hope you enjoy :)
A reproduction of an iconic car from the 90’s : the honda NSX type 1 featured V6 fake engine with rear wheel drive, steering with steering wheel, double wishbone suspensions, pop-up headlight, opening doors, hood, trunk and rear glass roof, and adjustable seats.
IMG_6706
The story of this project
I am a big fan of Honda (no really ?), but it is not a big deal, I am trying to cure myself.. by buying Honda car and motorcycle. I own a 89′ Transalp, and recently a Honda legend Ka8, but having a NSX is still not in my budget ! So I planned a long time ago to make one in lego. In beginning of 2017, a fan of lego and honda named Elvis, contacted me for questions about the Honda Ra300 I made in lego. Following some discussions about Lego and Honda, I discovered that he ownes the legendary Honda NSX. After that we met in order that I give him some parts to finish his Honda RA300 and it gives me the opportunity to see in real the NSX, take detailed pictures and drive it ! Then, I decided to make the NSX in lego.
IMG_6709
Engineering
I have started to use the 53mm wheel instead of big 68mm because of the scale and the result in quantity of parts. I think it is a good scale for manual car. Then I started with the chassis, trans-axle, and finished by the bodywork. The reproduction of the NSX in lego is equipped with full suspensions, as double wishbone inspired by the Groupe B Rally Car.
IMG_6735
The trans-axle is a rear wheel drive, due to the scale it is always complicated to have wheel drive and double wishbone suspensions. On the Group B rally car I used soft ribbed hose to connected the wheel to the differential, because these parts are 2-stud wide, instead of the 3L U-join but it works only by friction, excluding motorization. But for the NSX, I figured out to find an other way. I use in fact a floating differential enables me to not use U-joint for the axle, only Cv-join connected to the wheel hub. For that I use a 4L old differential which drives couple of 16t gear, and then 24t/12t to drive the V6 engine. Of course at this scale this is not possible to have a gearbox, or with removing the detailed of the interior which I did not want.
The steering is classical made with rack and pinion on the front, with an axle for the hand of god (which is by the way removable) and an other with a gearing and 2 U-join to operate the steering wheel in the interior.
IMG_6725
The pop-up headlight are operated by a lever in the dashboard. This lever drives a connectig rod which is also connected to a lever. And this lever command the displacement of the headlight by pushing the base, which causes the small rotation of them. It was a bit tricky to pass the whole connecting rod and system in it but it works fine and can be operated from the interior which was important for me.
IMG_6718
Design
The design was of course the most difficult part to do. It was also the most important ! Because the Honda in lego need to be realistic but also easy identifiable, that is why there are some interesting and important parts to reproduce, like the rear wings, the black roof, pop up headlight, shape of opening parts and so on. The only compromise that I did is for the doors, which do not respect the airflow intake shape.
I started the design by the rear parts with the bumper, exhaust and rear wing. I wanted to reproduce the gap between the bodywork and the wing and use simple configuration of panels, which I did. Then I do the opening trunk and started to build the front. I made the front bumper, originally with more parts and more bulky but I restarted it by using some black parts to give the front bumper enough stiffness but also aggressive look. After that I build the black roof with the opening glass roof and the important C-pillars which are oblique. Then I finally make the windscreen and the opening hood and pop-up headlight.
IMG_6744
I have to restart many time to get the correct shape of this hood including the system for the headlight and have a correct opening shape, which was very difficult. You can see some holes without parts near the  headlight, which is a compromise because of the room I have a steering wheels. You can see also on the video that I implement (at the end) a system to release the hood with a lever between the hood and windscreen.
IMG_6728
Then I finished the design by the doors, which have been also complicated because of the airflow shape. I would like to reproduce the thickness and the curving shape of the doors, and also include the airflow shape, which was not possible at the end. Maybe with bigger scale. But at the end, the shape is a bit here and there are also the two big airflow intake just after the doors before the wheel arch.
I made the interior at the end, which was not complicated with the dashboard, central console, lever and parking lever. Then added two bucket seat thanks to many panel and made the adjustable position which is in fact a slidding connector on axle.
IMG_6748
Conclusion
To conclude, I have tried many time to do the honda NSX in lego, but this time I started by the most difficult parts : the rear with the wings, and then build the other parts. Make the correct opening shape with the functions like pop-up headlight was complicated, that is why I have to do compromise (like the hole near the headlight, and the shape of the doors) but at the end, I am really happy with this car. On some views, the shape of the car is well done and respected, plus the distinctive parts like the wing, roof, and headlight make it easy identifiable. I could say that I find the front parts a bit bulky and more heavy in style that the rear, and some continuity problems of the panels near the doors (again for enabling the opening). But making lego scaling is always compromise to find the correct parts and assembly to fit, with good homogeneity and  continuity, and respecting the functions ! I do my best for it and at final thing that the bodywork is rather successful.
IMG_6710
I love it! :wub: Wonderful shaping, instantly recognizable with great functions. The Lights are the topping on the cake. I'm also a fan of the rear window, congrats and thanks for sharing!
Congratulations on such a beautiful creation! It is instantly recognizable as a NSX. The rear is perfect! I agree with you Nico71 on the front bumper but even that is beautifully done with the amazing pop up headlights. And great idea for the rear differential! :laugh:
And you're so lucky you got to drive the original NSX! :wub_drool:
Edited by jotta93
Hello, thank you for the comments, I am glad that you apreciate.
For the topic, I prefer one because I do not pass many time on EB forum. That is simplier for me.
Yes very lucky to drive a NSX, but thanks to a Fan of lego who own one, but thanks to lego because it contact me for my Honda RA300 :)
Congratulations Nico71 for this new creation. I'm also a huge fan of this old NSX.
I can't wait to have the partlists to begin this amazing model ! Will you post it on rebrickable ?
Yes but I will wait until Kevin williams do the instructions, in order to add the whole .mpd file to rebrickable to have a correct bill of material.
There are not rare parts, but many panel (red and black) et some flex, an dof course wheel. except that, there are no rare part I think
