Mr Man Posted September 3, 2011 Posted September 3, 2011 I'll build a Bomber next then - it has no spheres in it. Build a Borg TIE next . Quote
Superkalle Posted September 3, 2011 Posted September 3, 2011 Great job. Greetings from an LDD friend Quote
Brickdoctor Posted September 3, 2011 Author Posted September 3, 2011 Great job. Greetings from an LDD friend I'll post all the TIEs in the LDD forum with LXF files once I've done all the ones from the movies, by the way. Quote
andibandit Posted September 16, 2011 Posted September 16, 2011 how did you get the gray slope on the corner of each pair of the top and bottom wings? Quote
Fallenangel Posted September 16, 2011 Posted September 16, 2011 how did you get the gray slope on the corner of each pair of the top and bottom wings? With this. Quote
jasonsmith Posted September 16, 2011 Posted September 16, 2011 Classy with Style, well done Doc. Quote
andibandit Posted September 19, 2011 Posted September 19, 2011 With this. thanks, been bending my mind trying to figure it out, never seen that brick before. Quote
Eric W. Posted November 10, 2011 Posted November 10, 2011 The pylons are awesome! Getting them to connect and also having the hole is brilliant. The whole thing is brilliant! The curvature on the flat sections in the back of the craft cannot be built any way better. I HAD to use that same technique on my advanced. The way you made everything connect to the cockpit ball with little gaps remaining is my favorite thing in this build. My only gripe is the blockyness of the cockpit and the tiny windscreen. Other than that, this things pretty much spot on! Thank you for the inspiration!!! Quote
Brickdoctor Posted November 10, 2011 Author Posted November 10, 2011 The pylons are awesome! Getting them to connect and also having the hole is brilliant. The whole thing is brilliant! The curvature on the flat sections in the back of the craft cannot be built any way better. I HAD to use that same technique on my advanced. The way you made everything connect to the cockpit ball with little gaps remaining is my favorite thing in this build. My only gripe is the blockyness of the cockpit and the tiny windscreen. Other than that, this things pretty much spot on! Thank you for the inspiration!!! Thanks. The blockiness is one of my gripes with the model, but since Fallenangel informs me that this 5-wide core Lowell sphere cockpit is too small, I'm working on a bigger, 6-wide core cockpit ball for my forthcoming TIE/in that should look better. Quote
